Question about straight-line ballistics
  • Thread starter AndrewCStuart
  • Tags
    Ballistics
In summary, the conversation in the Economist sparked a physics debate about straight-line trajectories. The argument centered around the balance of horizontal and vertical forces on a projectile in motion, particularly in a gravitational field. The possibility of non-Euclidean spherical geometry and aerodynamic lift were also discussed as potential factors in achieving a straight trajectory at high speeds. However, further clarification is needed on the specific forces involved in order to fully understand the concept.
AndrewCStuart
This article in the Economist magazine sparked a physics debate in my pub, on the topic of straight-line trajectories:
The slugs can be heavy. General Atomics has produced a railgun able to hurl a 10kg projectile more than 200km in less than six minutes (that’s 2,000kph). Some slugs fly fast enough to hit a target 30km away with a straight trajectory, says John Finkenaur, a railgun expert at Raytheon
My protagonist was arguing that anybody in a gravitational field will be subject to downward forces, no matter how fast it was going horizontally. His beermat calculation was (doubling the speed of the 30k shot) 4000kph = 1,111.1 m/s and therefore a travel time of 27 seconds over 30km. With a gravitational constant of 9.81 vertical falling distance ought to be 9.81*27*27*0.5 or 3,575m. Rather a lot.
But alas, the Earth is not vacuous. So I plugged some numbers into this terminal velocity calculator here and a 10kg mass, 0.02 cross-section, 0.3 drag co-efficient gives me around 140m/s. Let's assume 5 seconds to reach terminal velocity and decent is additive after, 140*22 still gives me over 3km vertical decent.
So, my question is, how can our beermat estimates (and assumptions) be so at odds with the statement in the article? This thread https://www.physicsforums.com/showthread.php?t=281635 says
At these speeds [small arms], the math to calculate the drag is so complex that tables of coefficients are required to do the ballistics calculations
- accepted, and I'm not asking for anything exact, something else is missing here.
Could Mr Finkenaur be referring to a non-Euclidean spherical geometry straight line that meant the slug was always 20ft (say) off the ground and in effect in orbit? I'd go with that kind of 'straight-line'. But orbital velocity is way over atmospheric speeds.
Side note: A Distance to the Horizon Calculator tells me that I'd need to be at least 18m above the ground in order to fire 30km tangentially at the Earth and the target would also have to be 18m above the ground. Doesn't suggest its useful against tanks if truly Euclidean.
The projectile could have lift, depending on its orientation. At those speeds, even small effects can get significant.
Those things don't reach terminal velocity over 30km, not even speeds close to it. I remember speed estimates as high as 3km/s. That would give 10 seconds flight time, and 500m corresponding drop. Too much for a straight line (still just 1 degree deviation), but add a bit of aerodynamics (and the curvature of Earth as a smaller effect) and it can fit.
If the author is indeed referring to non-Euclidean spherical geometry in an article for the Economist, it's probably the first time such a reference has been made in that august, albeit non-physics, publication.
ok I buy that, it seems to be a good candidate for my missing factor...
..so as the slug drops as a result of gravity it we get an aerodynamic lift component via an angle of attack, so it effectively becomes a symmetrical airfoil. I was imagining the projectile was bullet-like plus fins (for spin stability and accuracy) so the forces would be balanced. Seems like a tiny force against the constancy of gravity but magnified by its speed?
@steamking; indeed. Its true the conversation quoted in the Economist is inadequate for not qualifying the speakers geometry in his assertion about a "straight line". There is a great deal of information about the forces required to move the slug horizontally but little about the forces balancing it vertically to produce the straight-line effect. Hence my interest.
I would like to address the question of straight-line ballistics raised in this article and the ensuing debate. First, it is important to note that the concept of a straight trajectory in ballistics is a simplification used in calculations and does not necessarily reflect the actual path of a projectile.
In the case of the railgun mentioned in the article, the slugs may be traveling at high speeds and in a relatively straight path, but they are still subject to the forces of gravity and air resistance. This means that the trajectory of the projectile will not be perfectly straight, but rather a curved path that is constantly being influenced by these forces.
The calculations made on the beermat and using the terminal velocity calculator are good approximations, but they do not take into account the complexities of ballistics at high speeds. As mentioned in the Physics Forums thread, the math to calculate drag at these speeds is complex and requires tables of coefficients. Therefore, it is not surprising that there may be discrepancies between the beermat estimates and the statement in the article.
It is also important to note that the Earth is not a perfect sphere and has varying atmospheric conditions, which can further affect the trajectory of a projectile. This means that the actual descent of a projectile may not be as straightforward as the calculations suggest.
In regards to the question of a non-Euclidean spherical geometry, it is possible that Mr. Finkenaur was referring to the fact that the Earth is not a perfect sphere and therefore the path of the projectile may not follow a Euclidean straight line. However, this does not mean that the projectile is in orbit, as orbital velocity is much higher than atmospheric speeds.
In conclusion, the concept of a straight-line trajectory in ballistics is a simplification and does not accurately reflect the actual path of a projectile. Factors such as gravity, air resistance, and atmospheric conditions must be taken into account when making calculations and these can greatly affect the trajectory of a projectile. Therefore, it is not surprising that there may be discrepancies between different calculations and statements.
FAQ: Question about straight-line ballistics
What is straight-line ballistics?
Straight-line ballistics is the study of the movement and behavior of projectiles, such as bullets or missiles, as they travel in a straight path through the air.
How is straight-line ballistics different from other types of ballistics?
Straight-line ballistics specifically focuses on the linear path of projectiles, while other types of ballistics, such as forensic ballistics, also take into account factors like gravity, wind resistance, and curvature of the Earth.
What factors affect the trajectory of a projectile in straight-line ballistics?
The trajectory of a projectile in straight-line ballistics is affected by factors such as initial velocity, gravity, air resistance, and any external forces acting on the projectile.
How is straight-line ballistics important in real-world applications?
Straight-line ballistics is important in a variety of fields, including military, law enforcement, and sports. It is used to predict the path and impact of projectiles, such as bullets or missiles, and can help with accuracy and safety in these applications.
What tools and methods are used in straight-line ballistics research?
Scientists use a variety of tools and methods in straight-line ballistics research, including mathematical models, computer simulations, and experiments using specialized equipment such as ballistic pendulums or high-speed cameras.
