Question about the Bohr model of atom and and electron in an orbital
In summary, when an electron gains energy, it gains potential energy and kinetic energy. Higher energy levels correspond to a greater expected value of r, and the electron doesn't become only "quicker" around the orbit.
aaronll
23
I have a question about what happen when an electron in the Bohr model of atom, gains energy because for example is "hitting" by a photon.
Electron have an energy, and it is the sum of potential and kinetic.
When they gain energy, they gain potential energy so they go further away from nucleus and become slower, or they gain kinetic energy so they become faster but near to nucleus? and why?
thanks
thanks
In general, the greater the energy the further the electron is from the nucleus. This is true for QM atomic orbitals - and also true for classical orbits in an inverse square potential.
Thank you
But my question is because for an energy E i think there is ( if the orbit is circular with a definite radius r) an "infinite" amount of pairs of velocity and distance (v,r) with the same energy, so in what way when energy increase the electron be?
higher speed? higher potential?
aaronll said:
Thank you
Unlike the classical case, the orbitals are not well-defined trajectories. So, you have to calculate the expected values of ##r## and kinetic energy. These, however, follow the same principle that higher energy levels correspond to a greater expected value of ##r##.
It should be clear that if you give an electron too much energy then the atom is ionised and the electron is released - i.e. the energy takes it beyond any bound orbital.
Maybe is the fact that higher energy levels correspond to a greater expected value of r, why the electron doesn't become only "quicker" around the orbit?
... because the orbitals must satisfy the Schroedinger equation.
Ok... that is.
Thank you
Maybe it is interesting to first consider the classical case, e.g. a comet being hit by another one. This will primarily induce a change of the comets velocity including it's direction. If the comet was on a circular orbit before the collision, it will end up on an elliptical or even unbound hyperbolical orbit after the collision. On an elliptical orbit, both kinetic and potential energy will periodically change (anticyclically) between their maximum and minimum values.
By the virial theorem, however, their average values are always related as 2<T> = -<V>, at least for the bound elliptical orbits.
So besides a change in energy, there will in general be a change in angular momentum, which is also true in the atomic case.
The classical theory applies also to atoms if they are in highly excited states, so called Rydberg atoms.
FAQ: Question about the Bohr model of atom and and electron in an orbital
What is the Bohr model of the atom?
The Bohr model of the atom is a model proposed by Danish physicist Niels Bohr in 1913 to describe the structure of an atom. It suggests that electrons orbit the nucleus in specific energy levels, similar to how planets orbit the sun.
How is the Bohr model different from the modern atomic model?
The Bohr model is a simplified version of the modern atomic model. It only considers electrons orbiting in specific energy levels, while the modern model takes into account the wave-like nature of electrons and their probability of existing in certain regions around the nucleus.
What is an electron orbital?
An electron orbital is a region of space around the nucleus of an atom where there is a high probability of finding an electron. It is described by the modern atomic model and is represented by a three-dimensional shape.
How does the Bohr model explain the stability of atoms?
The Bohr model explains the stability of atoms by proposing that electrons can only exist in specific energy levels. This means that they cannot spiral into the nucleus and release energy, which would cause the atom to become unstable.
What are the limitations of the Bohr model?
The Bohr model does not fully explain the behavior of electrons, as it does not take into account their wave-like nature and their probability of existing in certain regions. It also does not explain the existence of subatomic particles such as protons and neutrons, which make up the nucleus of an atom.
