Question about the classic Image Problem
In summary, the conversation discusses the potential in a region above an infinite grounded conducting plane with a point charge held at a distance above it. The method used is to create another system with the same boundary conditions using the uniqueness theorem of Laplace's equation. However, there is a singularity at the point where the charge is located, which violates the equation. The region of interest is the space above the plane, excluding the point where the charge is located.
zhuang382
Question about Laplace' equation and the classic Image Problem
##\nabla^2 V = 0##
##\nabla^2 V = \frac{-p}{\epsilon_0}##
I am studying the classic image problem (griffins, p. 124)
Suppose a point charge ##q## is held a distance ##d## above an infinite grounded conducting plane. Question: What is the potential in the region above the plane?
boundary conditions:
1. V = 0 when z = 0 (since the conducting plane is grounded)
2. V ~ 0 far from the charge ( that is ## x^2 +y^2 + z^2 >> d##)
The method is basically to use uniqueness theorem of Laplace's equation to create another system with the same boundary conditions. Therefore the potential function will be uniquely determined.
My question is:
since the region we are interested in is all the region of ##z > 0##, the Laplace's equation has to be satisfied i.e. ##\nabla^2 V = 0##
But the problem is that there is a point charge within this region, at ##z = d##. How to understand this?
At that point the potential has a singularity. No wonder: ##\rho = \infty## there.
Your problem exists whether there is a grounded plane present or not
Likes zhuang382
So we are actually interested in the region that ##\{(x,y,z)| z > 0, (x,y,z) \neq (0,0,d)\}##?
Or a singularity at ##z = d## do not violate ##\nabla^2 V = 0##?
Of course it does. The equation you want to solve is
$$\Delta V(\vec{r})=-\frac{1}{\epsilon_0} \rho(\vec{r})=-\frac{q}{\epsilon_0} \delta^{(3)}(\vec{r}-\vec{r}_0),$$
where ##\vec{r}_0=(0,0,d)## with the boundary condition mentioned in #1.
Likes PhDeezNutz, Abhishek11235 and zhuang382
Related to Question about the classic Image Problem
1. What is the classic Image Problem?
The classic Image Problem is a concept in psychology that refers to the discrepancy between a person's self-perception and how others perceive them. It can also be described as the difference between one's ideal self and actual self.
2. How does the classic Image Problem affect people?
The classic Image Problem can have negative effects on a person's self-esteem and self-confidence. It can also lead to feelings of inadequacy, anxiety, and depression.
3. What are some common causes of the classic Image Problem?
The classic Image Problem can be caused by a variety of factors, such as societal pressures, unrealistic expectations, past experiences, and personal insecurities.
4. Can the classic Image Problem be overcome?
Yes, the classic Image Problem can be overcome through self-reflection, building self-awareness, and seeking support from others. It is also important to challenge negative thoughts and replace them with more positive and realistic ones.
5. How can we help others who are struggling with the classic Image Problem?
We can help others by being understanding and supportive, encouraging them to seek professional help if needed, and promoting a culture of acceptance and self-love. It is also important to avoid making negative comments or comparisons that may contribute to their negative self-image.
9K
