- #36
Physics4
- 5
Thanks Bruce. Allow me to elucidate. Home experiments reveal the principles of the effect, but don't actually use single photons or single electrons because the equipment isn't capable of doing that. I've also seen several computer animations of the experiment, but nothing that describes the method and principle that allows the detector to both detect a single particle and allow that same particle ( wave form or whatever ) to pass through the detector undisturbed to the target.
Typically we simply see a simplistic portrayal where an artist inserts an eye or camera into the animation that is supposed to represent a detector. The problem with such interpretations is that for our eyes or a camera to detect a single photon, that photon has to strike the surface of our retina or the camera sensor where it's converted into energy that is sent down a signal path and registered. The photon has been absorbed. Therefore if you were to actually use such a detector in the double slit experiment, the detector will catch the particle and the particle will never never reach the target. Logically this should have the same effect as covering one slit, and consequently the interference pattern should disappear.
The missing information is therefore, how does the detector actually work to detect a single particle? Logically, if it cannot interact with the particle in some way it cannot detect it, and if it does interact with it in some way it must have some interactive effect, and that interactive effect may well be the cause of the change in the pattern seen on the target. Am I making any sense here?
