Question about the formal definition of conservative force
In summary, the mathematical description of a conservative force on Wikipedia states that the three conditions for a force field to be conservative are not equivalent in cases where the force depends on velocity. However, this section is inaccurate and does not take into account the Poincare lemma, which is only valid in simply-connected regions of space. This is demonstrated by the potential vortex, which is a well-known counter example.
physics user1
So, I was reading the mathematical description of a conservative force o wikipedia : https://en.m.wikipedia.org/wiki/Conservative_force and at the line "Many forces (particularly those that depend on velocity) are not force fields. In these cases, the above three conditions are not mathematically equivalent".
Why these statements are not mathematically equivalent?
Likes physics user1
Related to Question about the formal definition of conservative force
What is the formal definition of a conservative force?
The formal definition of a conservative force is a force that does not depend on the path taken by an object, but only on its initial and final positions. This means that the work done by a conservative force is independent of the path taken by the object.
What are some common examples of conservative forces?
Some common examples of conservative forces include gravity, electric forces, and magnetic forces. These forces are conservative because they do not depend on the path taken by an object, but only on its initial and final positions.
How is a conservative force related to potential energy?
A conservative force is related to potential energy through the work-energy theorem, which states that the work done by a conservative force is equal to the change in potential energy of an object. This means that as an object moves through a conservative force field, its potential energy changes in a predictable way.
What is the significance of a conservative force in physics?
The significance of a conservative force in physics is that it allows us to simplify and analyze systems using the principle of conservation of energy. Conservative forces also play a crucial role in understanding and predicting the behavior of objects in nature.
How can you determine if a force is conservative or not?
A force is conservative if it meets two criteria: 1) the work done by the force is independent of the path taken by an object, and 2) the work done by the force is equal to the negative change in potential energy. If both of these criteria are met, then the force is considered conservative.
  • Classical Physics
  • Classical Physics
  • Electromagnetism
