Question about the fundamental theorem of Calculus
In summary, the solution to finding the derivative of the given integral is obtained by using the chain rule for derivatives. The upper limit of integration is plugged into the solution because of the composition rule for derivatives. If both limits of integration are functions, the integral can be rewritten as two integrals with one limit being a function and the other a number. The derivative of the rewritten integral is then found by using the chain rule and the fundamental theorem of calculus.
James889
192
Hi,
Suppose we're asked to find the derivative of the integral
[tex]f(x)~=~\int_{-13}^{sin~x} \sqrt{1+t^2}~dt[/tex]
Now, the solution apparently looks like this:
[tex]f(x)^{\prime} = \sqrt{1+sin^2(x)}\cdot~cos(x)[/tex]
Why?
Why does the solution contain the upper limit `plugged in` ?
A more sensible answer (to me) would be [tex]\sqrt{1+x^2}[/tex]
Denote the integrand as a derivative of some unknown function:
[tex]\sqrt{1+t^2} = F'(t)[/tex]
Now calculate the integral and then take a derivative of f(x).
Because of the composition rule for derivatives. You have:
[tex]
F\left(y\right)=\int_{-13}^{y}\sqrt{1+t^{2}}dt
[/tex]
And [tex] f(x) = F(sin x) [/tex]. What is the derivative of that?
Your answer would be sensible if the upper limit of integration were simply x, which is the situation the FTC deals explicitly with. Not to worry though...the chain rule comes to the rescue. Perhaps you could try defining another function [tex]F(x)=\int_{-13}^x \sqrt{ 1 + t^2 }\ dt[/tex]. Then think about what F'(x) is and what F(sin x) is equal to.
EDIT: beaten to the punch by jsuarez
[tex]f(x)^{\prime}=\int_{-13}^{sin~x}\sqrt{1+x^2} - \sqrt{1+(-13)^2}[/tex]
[tex] == \sqrt{1+sin^2x} \cdot cos~x[/tex] because the second part is just zero.
But what would happen if we had sin x in the upper limit and another trig function in the lower limit like cos x ?
? You're f(x)' makes no sense to me. If you had functions as both limits of integration, simply rewrite it as two integrals where each has one limit that's a function and one limit that's a number. (Think about how you rewrite one integral as two.)
Then you would have a second term with cos x plugged in times its derivative, -sin x:
[tex]\frac{d}{dx} \int_{\cos x}^{\sin x} \sqrt{1 + t^2} ~dt = \sqrt{1 + \sin^2x} ~\cdot ~\cos x ~+ ~\sqrt{1 + \cos^2x} ~\cdot ~\sin x[/tex]
If you have something like:
[tex]
F(x) = \int_{g(x)}^{h(x)}f(t)dt
[/tex]
Where [tex]f(t)[/tex] is continuous (not strictly necessary, I'll assume it just to guarantee integrability) [tex]g(x), h(x)[/tex] differentiable, then you have:
[tex]
F(x) = \int_{g(x)}^{h(x)}f(t)dt = \int_{a}^{h(x)}f(t)dt + \int_{g(x)}^{a}f(t)dt
= \int_{a}^{h(x)}f(t)dt - \int_{a}^{g(x)}f(t)dt
[/tex]
For a suitable a, so:
[tex]
F'(x) = f(h(x))h'(x) - f(g(x))g'(x)
[/tex]
FAQ: Question about the fundamental theorem of Calculus
What is the fundamental theorem of calculus?
The fundamental theorem of calculus is a mathematical concept that links the two branches of calculus: differential calculus and integral calculus. It states that the definite integral of a function can be calculated by finding the antiderivative of that function.
How does the fundamental theorem of calculus work?
The fundamental theorem of calculus works by using the concept of an antiderivative to evaluate a definite integral. This means that we can find the area under a curve by finding the antiderivative of the function and evaluating it at the upper and lower bounds of the definite integral.
What are the two parts of the fundamental theorem of calculus?
The fundamental theorem of calculus has two parts: the first part, also known as the first fundamental theorem, states that the definite integral of a function can be calculated by finding the antiderivative of that function. The second part, also known as the second fundamental theorem, states that the derivative of an integral is equal to the original function.
Why is the fundamental theorem of calculus important?
The fundamental theorem of calculus is important because it provides a powerful tool for solving problems in both differential and integral calculus. It allows us to easily find the area under a curve and also helps in solving various physics and engineering problems involving rates of change.
Can the fundamental theorem of calculus be applied to any function?
Yes, the fundamental theorem of calculus can be applied to any continuous function. However, the function must have a finite derivative at every point in the interval over which the definite integral is being evaluated. In cases where this condition is not met, other methods, such as the generalized fundamental theorem of calculus, can be used.
