B Question about the nature of an implosion of a vacuum chamber
The implosion of a vacuum chamber is primarily driven by external atmospheric pressure acting on the chamber walls. Initially, the walls counterbalance this external force, but failure occurs when the walls can no longer withstand the pressure differential. Upon failure, the walls accelerate inward towards the vacuum, potentially fragmenting and causing further collisions within the chamber. The discussion emphasizes that a strong vacuum imposes minimal additional stress on the chamber compared to moderate vacuums, and proper design should prevent implosions. Ultimately, the balance of pressures determines the structural integrity of the vacuum chamber.
fizzchem
TL;DR Summary
I work as a chemist with practically zero physics education, so apologies in advance, but this question about implosion popped into my head this morning ;)
Can the implosion of a vacuum chamber (for example) be thought of in terms of an external force (atmosphere) acting upon the chamber walls, or is the material of the chamber wall itself that which applies the force?
Welcome to PF.
The atmospheric pressure applies the external force to the chamber.
Initially, the walls of the chamber equally oppose the external force.
When the chamber wall fails, the unbalanced forces accelerate the wall towards the vacuum.
If the wall fragments, those fragments pass into and collide within the volume, or continue outwards on the other side.
Likes Lord Jestocost
fizzchem said:
TL;DR Summary: I work as a chemist with practically zero physics education, so apologies in advance, but this question about implosion popped into my head this morning ;)
Remember, there's no such thing as suck so a very deep vacuum will impose very little extra stress on the chamber than for a moderate one. Leakage will increase pro rata but the chamber walls should have been mad with plenty of strength in hand. if a vacuum chamber implodes then someone should be getting the sack.
The force must start with the external pressure and pass through the distorting canister to compress the gas inside. The canister will always compress a small amount for any increase in the differential pressure but when the limiting strength of the walls is reached, you can get a implosion. Equilibrium will arise when the inner and outer pressures are the same. In a catastrophic event there would be some oscillation at the end of the implosion.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
