Undergrad Question about the Pauli equation
  • Thread starter Thread starter Airton Rampim
    Pauli
The discussion centers around understanding the Pauli equation, specifically expression (2.2.15) and the relationship between the commutator and anticommutator of the operators involved. The user seeks clarification on how the Levi-Civita tensor cancels the anticommutator in the context of the vector product of the operators. Through calculations, they realize that the approach is valid for any operator, including the angular momentum operator, and identify an oversight regarding an additional Levi-Civita tensor in their previous work. Ultimately, they confirm their understanding of the relationship between the commutator and the vector product, concluding that the calculations align with expected results.
Airton Rampim
I have a question about this note: https://ocw.mit.edu/courses/physics...i-spring-2018/lecture-notes/MIT8_06S18ch2.pdf
I don't understand the expression (2.2.15). The complete relation would be
$$ \pi_i \pi_j = \frac{1}{2}\left(\left[\pi_i, \pi_j\right] + \left\{\pi_i, \pi_j\right\}\right), $$
where
$$ \vec{\pi} = \vec{p} - \frac{q}{c}\vec{A} $$
in gaussian unit. How can I prove that {πi, πj} = 0?
In (2.2.15) you don't need the anticommutator, because the ##\epsilon_{ijk}## cancels this contribution identically. The commutator is most easily calculated in the position representation, where ##\hat{\vec{p}}=-\mathrm{i} \hbar \vec{\nabla}## or ##\hat{p}_i=-\mathrm{i} \partial_i##.
Likes Airton Rampim
Sorry, but I can't see how the Levi-Civita tensor cancels the anticommutator. I calculated the commutator using the position representation, as you mentioned. What I can't figure out is how I relate the commutator with the vector product ##\vec{\pi}\times\vec{\pi}##.
You have
$$(\vec{\pi} \times \vec{\pi})_k=\epsilon_{ijk} \pi_i \pi_j=\frac{1}{2} \epsilon_{ijk} (\pi_i \pi_j-\pi_j \pi_i)=\frac{1}{2} \epsilon_{ijk}[\pi_i,\pi_j],$$
because ##\epsilon_{ijk}=-\epsilon_{jik}##.
Likes Airton Rampim
vanhees71 said:
You have
Hmmm, so this is valid for any operator, right? Now I got it. I did in this way before, but I thought that was wrong, because it wasn't working with the ##\vec{L}## operator. But I forgot an extra ##\epsilon_{ijk}## that appears in ##\left[L_{i},L_{j}\right]##. So this gives
$$ {\displaystyle \left(\vec{L}\times\vec{L}\right)_{k}=\sum_{i,j}\frac{\epsilon_{ijk}}{2}\underbrace{\left[L_{i},L_{j}\right]}_{{\displaystyle i\hbar\sum_{k}\epsilon_{ijk}L_{k}}}=\frac{i\hbar}{2}\left(\sum_{i,j}\epsilon_{ijk}\epsilon_{ij1}L_{1}+\sum_{i,j}\epsilon_{ijk}\epsilon_{ij2}L_{2}+\sum_{i,j}\epsilon_{ijk}\epsilon_{ij3}L_{3}\right)} $$
$$ {\displaystyle =\frac{i\hbar}{2}\left[\left(\epsilon_{23k}\epsilon_{231}+\epsilon_{32k}\epsilon_{321}\right)L_{1}+\left(\epsilon_{13k}\epsilon_{132}+\epsilon_{31k}\epsilon_{312}\right)L_{2}+\left(\epsilon_{12k}\epsilon_{123}+\epsilon_{21k}\epsilon_{213}\right)L_{3}\right]} $$
$$ {\displaystyle =\frac{i\hbar}{2}\left[\left(\epsilon_{23k}-\epsilon_{32k}\right)L_{1}+\left(\epsilon_{31k}-\epsilon_{13k}\right)L_{2}+\left(\epsilon_{12k}-\epsilon_{21k}\right)L_{3}\right]} $$
$$ {\displaystyle =\frac{i\hbar}{2}\left[2\epsilon_{23k}L_{1}+2\epsilon_{31k}L_{2}+2\epsilon_{12k}L_{3}\right]} $$
$$ {\displaystyle =i\hbar\epsilon_{k23}L_{1}+i\hbar\epsilon_{1k3}L_{2}+i\hbar\epsilon_{12k}L_{3}} $$
$$ {\displaystyle =i\hbar L_{k}}, $$
which is the correct answer. It makes sense to me now. Thank you very much for your help :)
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 19 ·
