Question about the periodic table arrangement
In summary: I'm trying to understand how nucleosynthesis works. It starts with hydrogen (or helium?) and then goes through many transition before it ends up being Iron (if i understood correctly)
Signur
Hi, I'm new here.
I'm actually studying the periodic table and while collectting the data on excel i noticed something. I wouldn't see it with the usual display of a periodic table but when you put it all in a sheet, ligns after ligns it become obvious to me.
Argon Ar (noble gaz) is followed by Potassium K (Alkali metal) and then Calcium Ca (Alkaline Earth metal)
Same goes for H, Li, Br or Ne, Na, Mg or Kr, Rb, Sr or Xe, Cs, Ba or Rn, Fr, Ra
so a noble gas is followed by an alkali metal then an alkaline Earth metal.
Why ?
Chemistry news on Phys.org
Signur said:
Hi, I'm new here.
Why ?
This is the essence of the periodicity that Mendeleev noticed: elements with similar chemical properties repeat cyclically.
Later, quantum mechanics helped to explain the observed periodicity by describing the way that electrons get added to atoms (orbitals and the Aufbau principle).
Signur said:
Hi, I'm new here.
Why ?
There's a certain organization to the periodic table.
http://en.wikipedia.org/wiki/Periodic_table
The columns in the table are called groups, and the elements in each group have similar electron configurations in the outer shell. Thus, all the elements with only one electron in the outer shell are in Group 1 and are all metals except for hydrogen. All the noble gases are in Group 18, at the other end of the table, and each of these gases has a full complement of electrons in its outer shell. If you take the next element after neon (atomic number 10), for example, that additional electron can't fit into the outermost shell for neon; it must go into its own shell, thus sodium (atomic number 11), an alkali metal.
It's called a "periodic" table because these properties and relationships repeat after progressing thru a certain number of elements. This was the great insight of Mendeleev, who published the first periodic table.
so it's not related to elemental transition ? simply an indication that the number of electron is close ?
scientists believe: Elements have similar chemical properties because their electron configurations are similar. Ne: [He]2s^2 2p^6; Ar: [Ne]3s^2 3p^6, etc. The outermost electrons are ns^2 np^6.
if i get it right, the element 119 (Uuo) would be followed by a (yet unknown) Alkali metal ?
Could be. Most tables only go up to element 118 (which should be a noble gas).
It's not clear what these two statements mean. What sort of transition? The number of electrons is close to what?
i'm working on a star system generator on excel, for RPG purpose.
So I'm now studying nucleosynthesis to know how a star work so that my generator is able to provide the composition of a star (or a planet athmosphere or crust, or whater)
Now I'm on the stellar part and I'm trying to understand how nucleosyntheisis works. It start with hydrogen (or helium?) and then goes throught many transition before it end up being Iron (if i understood correctly)
that is the process I'm tryingto understand and that's why i ended up studying the periodic table.
Well, nucleosynthesis is a little more complicated than you have described. The Periodic Table was developed primarily for chemists; in order to understand nucleosynthesis, you need to know something about atomic physics rather than chemistry:
http://en.wikipedia.org/wiki/Nucleosynthesis
"Well, nucleosynthesis is a little more complicated than you have described."
yeah i know :)
I'm still struggling to understand it. I've got a very basic idea of what it is.
Related to Question about the periodic table arrangement
1. What is the periodic table arrangement?
The periodic table arrangement is a way of organizing all known elements based on their atomic structure, chemical behavior, and physical properties. It is a tabular chart that displays elements in rows and columns according to their increasing atomic number.
2. Why is the periodic table arranged in a specific way?
The periodic table is arranged in a specific way to highlight the similarities and patterns among elements. Elements in the same column, also known as groups or families, have similar chemical and physical properties due to their shared electron configurations. Elements in the same row, also known as periods, have increasing atomic numbers and display a trend in properties from left to right.
3. Who created the periodic table arrangement?
The modern periodic table was created by Russian chemist Dmitri Mendeleev in 1869. However, the concept of organizing elements in a periodic manner was proposed by other scientists such as Antoine Lavoisier, Johann Wolfgang Döbereiner, and John Newlands in the early 1800s.
4. How many elements are there in the periodic table arrangement?
As of 2021, there are 118 known elements on the periodic table. These elements are organized into 7 periods and 18 groups, with some elements yet to be officially named or discovered. However, the periodic table can continue to expand as new elements are discovered through scientific research.
5. What is the significance of the colors used in the periodic table arrangement?
The colors used in the periodic table arrangement represent different categories of elements. The blue color indicates elements that are gases at room temperature, the green color indicates elements that are liquids at room temperature, and the red color indicates elements that are solid at room temperature. The gray color is used for transition metals, while the purple color represents lanthanides and actinides.
