I Question about the Photoelectric Effect and the Work Function of a Metal
ParsaEF
TL;DR Summary
A question about the quantum theory of the photoelectric effect
By the results of the photoelectric effect experiment, the photoelectric effect does not occur at all if the frequency of the light source is below a certain value.
We have the Work Function for a metal. Why when the energy of the photons of the light source is W/2, we don't have the photoelectric effect when two photons hit one electron? because I think that the energy of the photons will be absorbed by electrons anyway, no matter what is the Work Function. so when the photon's energy is less than the Work Function, it just absorbs the energy but they don't get emitted from the surface.
If it absorbes the photon of W/2, it just need W/2 more energy to get emitted. and this energy will be given to it by the next photon and then it has enough energy to get emitted.
A metal is not a bank. It does not store energy, waiting for the right moment where it finally has enough to eject an electron.
You are assuming that there are available states for the electrons to go to when they absorb any amount of energy. But that's not correct. Bound states of electrons are quantized; there are only specific energies that are available. For the case of electrons in a metal, the electrons that the photoelectric effect ejects are in the conduction band, so there are no states of higher energy available that are still bound. So either an electron absorbs enough energy to be ejected from the metal (and the minimum energy for that to happen is the Work Funcfion energy), or it can't absorb any energy at all.
Likes vanhees71 and Vanadium 50
I believe that the two-photon photoelectric effect (PEE) is possible under the right conditions. But the probability is very low (typically several orders of magnitude smaller than single-photon PEE).
I don’t understand the details but this might help: https://chem.libretexts.org/Bookshe...Electronic_Spectroscopy/Two-photon_absorption
A similar process is used in two-photon photoelectron spectroscopy, e.g. see here.
EDIT: But, as noted by @PeterDonis in Post #5, in this case the photon absorptions are sequential rather than simultaneous.
As you note, the probability of this is very low. More pertinent to this discussion, however, is the fact that this process involves two photons being absorbed simultaneously, not sequentially. So it is not an example of the kind of process the OP is asking about.
Yes indeed. That's why I used the word 'similar'.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
