I Question about the vector cross product in spherical or cylindrical coordinates
The discussion centers on the feasibility of calculating the vector cross product in spherical or cylindrical coordinates using a determinant format similar to that used in Cartesian coordinates. It is confirmed that this method is valid as long as the basis vectors form a right-handed system, allowing for the use of the determinant with the appropriate unit vectors. However, it is noted that the curl operation does not apply in the same way due to the position-dependent nature of the basis vectors in polar coordinates. The simplest approach suggested is to convert vectors to Cartesian coordinates for the cross product calculation and then revert to spherical or cylindrical coordinates. Overall, the cross product can be computed directly in non-Cartesian coordinates, but understanding the underlying principles is essential.
dyn
Hi
If i calculate the vector product of a and b in cartesian coordinates i write it as a determinant with i , j , k in the top row. The 2nd row is the 3 components of a and the 3rd row is the components of b.
Does this work for sphericals or cylindricals eg . can i put er , eθ , eφ in the top row with the relevant components in the 2nd and 3rd rows ?
I know that for the formula for grad , div and curl in sphericals or cylindricals then scale factors appear but is the cross product of 2 vectors independent of scale factors ?
Thanks
Mathematics news on Phys.org
The simplest solution is to convert both vectors to cartesian, do the cross product and convert backup to spherical or cylindrical.
However, doing the cross product spherically or cylindrically directly boils down to find a vector that is perpendicular to both vectors following the right hand rule convention and recalling that the magnitude of the resultant vector is:
##\vec A \times \vec B = |A||B|sin(\theta)##
where ##\theta## is the angle between ##\vec A## and ##\vec B## and |A| and |B| are the magnitudes of the respective vectors ##\vec A## and ##\vec B##.
There is an old thread on it here:
https://www.physicsforums.com/threa...ame-way-i-do-in-cartesian-coordinates.772165/
A more detailed answer may be found here:
https://math.stackexchange.com/questions/1358590/cross-product-spherical-coordinates
dyn said:
Hi
Thanks
THe determinant method works for any set of orthogonal unit basis vectors which form a right-handed triple, so if in your convention \mathbf{e}_r \times \mathbf{e}_\theta = \mathbf{e}_{\phi} then <br /> \mathbf{a} \times \mathbf{b} = \left| \begin{matrix}<br /> \mathbf{e}_{r} &amp; \mathbf{e}_{\theta} &amp; \mathbf{e}_{\phi} \\<br /> a_r &amp; a_\theta &amp; a_\phi \\<br /> b_r &amp; b_\theta &amp; b_\phi<br /> \end{matrix}\right|. Curl doesn't work this way because in polar coordinates the basis vectors are functions of position and not constants.
Likes jedishrfu, Delta2 and dyn
Thank you
Since I've seen you post in some physics sections before, here is an excerpt on how to use the levi-cievta sign from notes i wrote years ago (since physicists love the following two ideas, it's worth getting use to it):
We will now introducte the Levi-Cievta symbol as follows: $$\epsilon_{ijk} = \begin{cases}
1 & 123, 312, 231 \\
-1 & 321, 132, 213 \\
0 & i=j=k
\end{cases} $$
Where the numbers represent the subscripts. So that means ##\epsilon_{123} = 1##. So how do you keep track of which is which? When I was younger, it was introduced to be a permutation, and a bunch of other nomenclature that I couldn't quite grasp until I was older. So I'll give you the secret I used! I simply start with 123, and then bump up the numbers to get 312, then again to get 231. Then, to get the -1, you just start with 321, and do the same. This is essentially what a permutation is, but when you're seeing all this for the first time, and a new symbol, even the simple things seem hard! So, how exactly does this relate to cross product? Well, let me throw out this equation (Note I am using Einstein summation): $$\vec{A} \times \vec{B} = \epsilon_{ijk}A^jB^k\hat{e_i}$$ Pretty obvious now, right? Okay, if it isn't obvious how they're related, don't worry! ##A^j## ##B^k## are the components of our vector, and ##\hat{e_i}##is our basis vector. Let's explicitly write out the sum to see if it will give us the same result as the cross product. \\
\epsilon_{ijk}A^jB^k\hat{e_i} = $$
\begin{align*}
\epsilon_{111}A^1B^1\hat{e_1} + \epsilon_{112}A^1B^2\hat{e_1} + \epsilon_{113}A^1B^3\hat{e_1} + \\ \epsilon_{123}A^2B^3\hat{e_1} + \epsilon_{122}A^2B^2\hat{e_1} + \epsilon_{121}A^2B^1\hat{e_1} +\\
\epsilon_{131}A^3B^1\hat{e_1}+\epsilon_{132}A^3B^2\hat{e_1}+\epsilon_{133}A^3B^3\hat{e_1} +\\ \epsilon_{211}A^1B^1\hat{e_2}+ \epsilon_{212}A^1B^2\hat{e_2} + \epsilon_{213}A^1B^3\hat{e_2} + \\
\epsilon_{223}A^2B^3\hat{e_2} + \epsilon_{222}A^2B^2\hat{e_2} + \epsilon_{221}A^2B^1\hat{e_2} + \\
\epsilon_{231}A^3B^1\hat{e_2} + \epsilon_{232}A^3B^2\hat{e_2} + \epsilon_{233}A^3B^3\hat{e_2} +\\
\epsilon_{311}A^1B^1\hat{e_3} + \epsilon_{312}A^1B^2\hat{e_3} + \epsilon_{313}A^1B^3\hat{e_3} + \\
\epsilon_{323}A^2B^3\hat{e_3} + \epsilon_{322}A^2B^2\hat{e_3} + \epsilon_{321}A^2B^1\hat{e_3} +\\
\epsilon_{331}A^3B^1\hat{e_3} + \epsilon_{332}A^3B^2\hat{e_3} + \epsilon_{333}A^3B^3\hat{e_3}
\end{align*}
So, I know what you're thinking... 27 terms from such a simple line?! That's the power of the Einstein summation convention! However, I only wrote this out so you can get a feel for that power. In reality, we just use what the Levi-Civita symbol tells, that is any ##i=j=k## just go to zero, so our 27 equations zoom down to 6.
So we're left with
\begin{align*}
\epsilon_{123}A^2B^3\hat{e_1} + \epsilon_{132}A^3B^2\hat{e_1} \\
\epsilon_{231}A^3B^1\hat{e_2} + \epsilon_{213}A^1B^3\hat{e_2} \\
\epsilon_{312}A^1B^2\hat{e_3} + \epsilon_{321}A^2B^1\hat{e_3}
\end{align*}
I've specifically put them in this order for a reason, we can now factor out the specific basis vector on each line and let's see what we get.
We now see that our equation becomes
\begin{align*}
\hat{e_1}(A^2B^3 - A^3B^2) + \\
\hat{e_2}(A^3B^1 - A^1B^3)+ \\
\hat{e_3}(A^1B^2 - A^2B^1)
\end{align*}Which, as you can see, makes no mention of the particular coordinate system you're in. I do go into more details in my notes, but I think this is long enough for you to get the idea!
Likes dyn and jedishrfu
Nice tensor exposition! However, it may be overkill for the OP as Tensor Analysis is seldom taught until needed in grad school for either Differential Geometry or General Relativity.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
