Question about this double integral
In summary, on the interval [0, 2], the minimum of ##x^2## and ##x## is chosen depending on the value of ##x##. When ##x \in [0, 1]##, the minimum is ##x^2## and when ##x \in [1, 2]##, the minimum is ##x##. This can be seen by comparing the graphs of ##y = x## and ##y = x^2## on the interval [0, 2].
DottZakapa
239
TL;DR Summary
double integral
could please some one explain the inequality on the right?
in particular how should i see
and
thanks
You are working with ##0\leq x\leq 2##. If ##0\leq x\leq 1##, then ##\text{min}\{x^2,x\}=x^2## and if ##1\leq x\leq 2##, then ##\text{min}\{x^2,x\}=x## (and other other way around for ##\text{max}##).
why?
DottZakapa said:
why?
Look at the graphs of ##y = x## and ##y = x^2## on the interval [0, 2]. When ##x \in [0, 1]##, which graph is higher? Same question when ##x \in [1, 2]##.
The ##min\{x^2,x\}## with x between 0 and 2 inclusively means comparing ##x^2## to ##x## and selecting the lesser number of the two.
As an example, if ##x=-2## then the comparison would be 4 vs -2 and so -2 is the lesser one.
In this case, ##x=0.5## vs ##x^2=0.25## so that ##x^2## is the lesser when ##x## is between 0 and 1.
and for the case, ## x=1.5## vs ##x^2= 2.25## then ##x## is the lesser one when ##x## is between 1 and 2.
Aw ok now is clear, thanks a lot
Related to Question about this double integral
1. What is a double integral?
A double integral is a type of mathematical operation used to calculate the volume of a three-dimensional object. It involves integrating a function over a two-dimensional region.
2. How is a double integral different from a single integral?
A single integral involves integrating a function over a one-dimensional interval, while a double integral involves integrating a function over a two-dimensional region. This allows for the calculation of volume rather than just area.
3. What is the purpose of using a double integral?
The purpose of using a double integral is to calculate the volume of a three-dimensional object or the area of a two-dimensional region. It is a useful tool in many fields of science and engineering, such as physics, economics, and fluid mechanics.
4. How do you evaluate a double integral?
Evaluating a double integral involves breaking down the two-dimensional region into smaller, simpler shapes such as rectangles or triangles. Then, the integral is calculated for each of these shapes and added together to get the final result.
5. What are some real-life applications of double integrals?
Double integrals have many real-life applications, such as calculating the volume of a solid object, finding the center of mass of an irregular shape, and determining the probability of an event in statistics. They are also used in fields such as engineering, economics, and physics to solve various problems and make predictions.
