Question about this interaction in QFT
In summary, the conversation is about a student's attempt to understand the effects of self-interaction in QFT and their search for a simple and explicit example. The expert explains that their intuition is correct and suggests looking into more advanced topics in the field. The student asks for references for exactly solvable models, and the expert recommends some resources.
giova7_89
31
Question about this "interaction" in QFT
Hi, I started two months ago my course in QFT, and since I heard about the fact that the bare mass appearing in the Lagrangian of a theory isn't the physical mass of a particle (due to self interaction, I guess), I tried to find an example explicitly solvable where one could see this effect directly. That is find the one particle states of the theory and their energy, E^2= p^2+m^2_physical.
To do so, the simplest model i could think of was the "generalization" of the external current problem presented at the end of the second chapter of Peskin & Schroeder. That is I added to that Lagrangian the free term for the scalar field j(x).
I'm attaching a short .pdf (5 pages) with my calculations and conclusions. The "conclusions section" of my .pdf was a bit rushed, since I hoped that we could discuss it directly on the forum (the very last line, however, seemed very important to me, since it could help to answer some of my other questions i wrote in the .pdf)...
  • Scalar-scalar (neutral) interaction.pdf
Your intuition in the last sentence is correct. This is not an interacting theory at all. Once you rewrite the Lagrangian in terms of the eigenvectors of the mass matrix, you find two free bosons.
If you really wanted to see mass renormalization, you could read on later in the book where a boson with the self-interaction [itex]V = \lambda \phi^4[/itex] is considered. After reading that, you could work out the case of two bosons coupled by [itex]V = \lambda \phi_1^2\phi_2^2[/itex] as an example.
Ok, but I tried that example because I was able to treat it nonperturbatively (after all we agreed that it is a free theory!). We just started feynman diagrams in our course and didn't get to renormalization theory yet (I don't even knopw if we will do it in this course) so my knowledge of these things is limited.
Thanks for the reply, however.
May I ask if someone could tell me if there are some articles or references where there is an exact solution for a theory, presented in a "simple way" (that is, a way that I can follow with my current knowledge)? I'd like to have that because I always understand things better if I have a "exact model" to refer to...
As far as I know, there aren't any exactly solvable interacting QFTs in four dimensions.
In two dimensions (one space + time), there are exactly solvable models, at least in the sense that exact correlation functions can be written down. The best studied examples are the Thirring and sine-Gordon models, which can actually be shown to be different, "dual," formulations of the same physics. There is a very brief review in ch 2 of this dissertation, but I'm not sure how easy it will be to follow along. Other references are the chapter on "lumps" in Coleman's "Aspects of Symmetry," as well as Rajaraman, "Solitons and Instantons."
Related to Question about this interaction in QFT
1. What is QFT?
QFT stands for quantum field theory, which is a theoretical framework for understanding the behavior of particles at a subatomic level. It combines principles from quantum mechanics and special relativity to describe the interactions between particles and their corresponding fields.
2. How does QFT explain interactions between particles?
In QFT, particles are described as excitations in their corresponding fields. These fields permeate all of space and time, and when particles interact, they exchange energy and momentum through their respective fields.
3. What is an interaction in QFT?
An interaction in QFT is a process in which particles exchange energy and momentum through their corresponding fields. This can result in the creation or annihilation of particles, or the change in properties of existing particles.
4. What are the four fundamental interactions in QFT?
The four fundamental interactions in QFT are gravity, electromagnetism, the strong nuclear force, and the weak nuclear force. These interactions are described by different field theories and have varying strengths and ranges of influence.
5. How does QFT differ from classical field theories?
QFT differs from classical field theories in that it takes into account the principles of quantum mechanics, such as uncertainty and particle-wave duality, to describe the behavior of particles and their interactions. Classical field theories, on the other hand, do not incorporate these quantum principles and are limited in their ability to accurately describe subatomic phenomena.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
