Question about this Radial function Rl(r)
  • Thread starter Thread starter physicss
    Radial
physicss
Helllo, I have to show that ∆(R1(r)Y11(ϑ,ϕ)) = 0. I already solved the Y11 part but what is R1(r) or generally written Rl(r) written out? I only know the radial function Rn,l(r). Thanks in advance
Y11
I can´t find Rl(r) written out on the internet.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
