Question about Trigonometric Substitution
In summary, the conversation is about a trigonometric substitution problem and the correct solution to the integral is found through setting up a triangle with legs of 5x and 1, leading to the hypotenuse of \sqrt{25x^2+1}. The mistake was forgetting to include a 5 in the final solution.
MacLaddy1
52
Hello again,
I have a question about a trigonometric substitution problem that I am struggling with. I was able to get the correct answer, which I know is correct because of Wolfram verification, and my school has a way of showing an example which showed the steps... Anyway, see below.
\(\displaystyle \int_0^\frac{1}{5}\frac{dx}{\sqrt{25x^2+1}^\frac{3}{2}}\)
Without going through all the steps, I can tell you that the solution to this integral is,
\(\displaystyle [\frac{1}{5}sin\theta]_0^\frac{1}{5}\)
which SHOULD simplify to
\(\displaystyle [\frac{1}{5}*\frac{x}{\sqrt{25x^2+1}}]_0^\frac{1}{5}\)
However, the book shows that \(\displaystyle \frac{1}{5}\) is omitted, and this ends up being the final correct answer by taking 1/5 out.
Can anyone explain to me what is happening here?
Thanks,
Mac
I believe when you set up the triangle for trig substitution you have the legs as 5x and 1, thus the hypotenuse is \(\displaystyle \sqrt{25x^2+1}\). If I'm not switching the orientation of the legs then that means \(\displaystyle \sin(\theta)=\frac{5x}{\sqrt{25x^2+1}}\) so you forgot a 5.
Ah, of course. I tried that problem repeatedly and continued making the same mistake.
Thanks again, Jameson.
FAQ: Question about Trigonometric Substitution
What is Trigonometric Substitution?
Trigonometric Substitution is a technique used in calculus to simplify integrals involving radical expressions or expressions containing trigonometric functions. It involves substituting a trigonometric expression for a variable in the original integral, allowing it to be solved using known trigonometric identities.
When should I use Trigonometric Substitution?
Trigonometric Substitution is most useful when the integral involves a radical expression or a combination of trigonometric functions. It is also helpful when the integral involves a polynomial of high degree, making it difficult to integrate using other techniques.
How do I choose the appropriate trigonometric substitution?
The substitution should be chosen based on the form of the integral. For example, if the integral involves a2 + x2, then a sine or cosine substitution would be appropriate. If the integral involves a2 - x2, then a tangent substitution would be appropriate.
Can Trigonometric Substitution be used for definite integrals?
Yes, Trigonometric Substitution can be used for both indefinite and definite integrals. When using it for a definite integral, be sure to adjust the limits of integration based on the chosen substitution.
Are there any specific tips or tricks for using Trigonometric Substitution?
One helpful tip is to rewrite the integrand in terms of only one variable before making the trigonometric substitution. This can make the integration process easier. Additionally, it is important to carefully check the limits of integration when using Trigonometric Substitution for definite integrals.
