Question about water flow through a PC watercooling system
In summary, the conversation discusses the design of a water cooling system and the placement of the in and out ports on the waterblock. The original poster suggests having the ports on opposite faces for better flow and cooling, but others argue that slower flow is actually better because it allows for turbulence and prevents hot spots. The idea of "water moving so fast it doesn't touch the sides" is also brought up, but it is not clear whether this is true or not. Overall, there is a debate about the best design for optimal cooling.
DyslexicHobo
251
So I decided that I want to machine my own water cooling system from scratch. I know it's going to take a lot of time for virtually no money saved, but I want some experience machining and it'd be really cool to make something that I'd actually use.
So anyway, I can't figure out why all CPU waterblocks have the in port and out port on the same face. It seems to me like if they were on opposite faces (so the flow is parallel to the motherboard) that it would flow easier. Better flow means better cooling, right?
Right now I'm still in the design stage, and my first thought was to have a larger cavity than most waterblocks (approx 5/8x5/8" for 1/2" tubing) and have grooves in the copper base for increased surface area. I am not taking fluids until this semester, so I don't completely understand everything that's going on with the water. Would a design such as this cool better than a typical waterblock with the in port and out port on the same plane?
Thanks for any help/advice!
No ,better flow means LESS cooling.
Imagine the perfect case of a flow that went through a high speed not touching the sides, the water would exit at the same temperature it went in at and there would be no cooling.
The point of having lots of pipes in a radiator or cooler is for the fluid to touch the sides as much as possible and reach the temperature of the block.
Having the in-out ports on the same side simply makes the connections easier
Really? That's quite counterintuitive.
You'd think that, while the water would exit at a lower temperature if the flow were faster, there would be more water replacing it in the reservoir to take its place in absorbing heat.
If heat flows more quickly for a larger temperature difference, which I imagine it does, it would seem that this scenario - faster moving water, where any segment of water absorbs proportionally less heat but you have proportionally more segments absorbing it - would be better.
It seems, in fact, like there should be an optimal speed depending on the temperature to which you can cool the water in the cooling portion of the apparatus.
I'm not sure I really believe the idea that slower is better... in the limit, you just put a pool of water with no flow at all, and this is clearly not going to work. Intuition would seem to indicate that, if the water were moving infinitely fast, it would be the same physical situation as the pool of water without the water raising in temperature (not because it doesn't absorb heat, mind you, but because the cooling portion removes it as fast as it is put in). The static situation would be the same, except the temperature of the water would raise until it reached thermal equilibrium with the thing it was cooling.
If you're right, that's a very interesting phenomenon. Why is it like this? I don't by the idea of "water moving so fast it doesn't touch the sides".
I think he means that if I have a waterblock where the water is moving very quickly, it means there is no turbulence in the water. If there is no turbulence, then there are going to be hot spots near the sides of my waterblock. It's not necessarily that less flow creates a better heatsink, but that there needs to be some contact with the sides of the pipe (or in this case, a waterblock) in order for it to work well.
I'm not really sure if that's what he meant, but that's what I thought of after reading his post.
Edit: But I completely agree with everything you say, and the way MGB worded his post definitely does confuse me for the same reason it does you.
Oh no, I agree that increasing surface area of the water/heat source interface is good, and keeping hot water away from the interface seems better. I just don't see how less flow achieves this better than more flow.
I could be wrong, but I *think* what he was getting at is that with lack of flow comes turbulence. Without turbulence there will be hot spots.
This is the part that I don't agree with:
"Imagine the perfect case of a flow that went through a high speed not touching the sides, the water would exit at the same temperature it went in at and there would be no cooling."
Edit: Or maybe he misunderstood? Because the water will be touching the sides...
Related to Question about water flow through a PC watercooling system
1. How does water flow through a PC watercooling system?
Water flows through a PC watercooling system in a closed loop. The pump pushes the water from the reservoir to the waterblock, where it absorbs heat from the CPU or other components. The heated water then flows to the radiator, where it is cooled by fans before returning to the reservoir to complete the loop.
2. Why is water used instead of air for cooling a PC?
Water has a higher heat capacity and thermal conductivity than air, which allows it to absorb and transfer heat more efficiently. This makes water cooling more effective at keeping PC components at lower temperatures, which can improve performance and prolong the lifespan of the hardware.
3. How do I know if my PC watercooling system is working properly?
You can check the effectiveness of your watercooling system by monitoring the temperatures of your PC components. If the temperatures are significantly lower than they were with air cooling, then your watercooling system is likely working properly. You can also check for any leaks or unusual noises from the pump, as these can indicate issues with the system.
4. Do I need to maintain my PC watercooling system?
Yes, it is important to regularly maintain your PC watercooling system to ensure optimal performance and prevent any potential issues. This includes regularly cleaning the waterblocks and radiators, checking for leaks, and replacing any worn out or damaged parts.
5. Can I install a watercooling system on any PC?
In most cases, watercooling systems can be installed on any PC as long as there is enough room for the components and proper mounting options. However, it is important to check compatibility with your specific PC case and components before purchasing a watercooling system to ensure a proper fit.
