Question about Waves on a String
  • Thread starter Abdullah Almosalami
  • Tags
    String Waves
In summary: However, if the frequency is lowered, the opposite is true. If the wavelength is increased, the short wavelength travels faster. This is because the short wavelength waves have more energy. If the frequency is lowered, the amplitude of the short waves decreases, so the short waves will travel faster than the long waves. If the frequency is increased, the amplitude of the long waves increases, so the long waves will travel faster than the short waves.
Abdullah Almosalami
49
Thread moved from the technical forums
Summary:: Could you send a second wave pulse down a string that would overtake an earlier wave pulse?
Got this question in my physics textbook. Ignoring reflection (i.e., you had a very long string), say you send a transverse wave pulse down a string fixed on its other end to a wall. Could you somehow send another wave pulse that overtakes this initial pulse?
My Initial Answer
My thinking is the second wave pulse obviously must move faster through the string than the first pulse, and at least as far as the book has derived, the speed of a transverse wave on a string is given by ##v = \sqrt \frac{F_T}{\mu}##, where ##F_T## is the tension in the string and ##\mu## is the string's mass per unit length. The only way then that the speed of the second string could be higher would be to increase the tension in the string. So I'm imagining ok, you send the first pulse then you pull the string tighter. I think longitudinal waves travel faster than transverse waves, and pulling the string tighter I think amounts to doing that (sending a longitudinal wave pulse). If the longitudinal pulse is much faster, then you would be able to increase the tension quickly and then send another wave pulse down that now moved at a higher speed.
Oopsies
I'm stupid. I forgot that both waves are moving through the same medium, so their speed is set. I guess it isn't possible in this situation. Anybody else?
Very interesting question. It sounds like the question is asking if there is any way that you could make one transverse wave on the string completely catch up to the lead one, right? I can see some variations in linear mass density that would help the trailing tranverse wave to catch up and get close, but that would not make it catch the lead pulse.
But you mention an interesting thing about longitudinal waves, since that could alter the tension in the string locally -- do you have an equation for the propagation speed of longitudinal waves, or is it the same as for transverse waves?
Likes LCSphysicist and Abdullah Almosalami
I think is interesting to think about if the string is a dispersive medium. Or if it is with uniform density.
If it is dispersive, we can find different velocities.
If it is non uniform too.
λ = 2L/n
f = 2*fo*sin(n*π/(2(N+1))
Pure sinusoidal waves on the string with high frequencies, and longer wavelength travels faster than short wavelengths.
Related to Question about Waves on a String
1. What is a wave on a string?
A wave on a string is a disturbance or oscillation that travels along a stretched string, rope, or wire. The disturbance moves along the string, but the particles of the string itself do not travel with the wave.
2. What causes waves on a string?
Waves on a string are caused by a disturbance or energy input at one end of the string. This can be created by plucking, striking, or shaking the string, or through an external source such as a speaker or motor.
3. What are the properties of waves on a string?
Waves on a string have several properties, including amplitude (height of the wave), wavelength (distance between two consecutive peaks or troughs), frequency (number of waves per second), and velocity (speed of the wave). These properties can be altered by changing the energy input or characteristics of the string.
4. How do waves on a string transfer energy?
Waves on a string transfer energy through a series of oscillations. As the wave travels along the string, the particles of the string vibrate back and forth, transferring energy from one particle to the next. This energy transfer allows the wave to continue propagating along the string.
5. What is the relationship between tension and wave speed in a string?
The speed of a wave on a string is directly proportional to the tension in the string. This means that as the tension increases, the wave speed increases. This relationship is described by the wave equation, v = √(T/μ), where v is the wave speed, T is the tension, and μ is the linear mass density of the string.
