How Can I Easily Tackle Binary and Hexadecimal Problems?
In summary, the person is explaining how to change a decimal number to binary. They say that the easiest way to do this is by dividing the number by 2 and placing 1 or 0 in the appropriate column, depending on whether the number is odd or even.
Amathproblem22
I don't need help with a problem just help with easy ways of tackling the problems. Below are my current methods. (Hopefully, all is correct I was in a rush).
Binary to Decimal:
1286432168421
11110001
I already know \(\displaystyle 128+64+32= 224\) so then \(\displaystyle 16+1=17\), meaning \(\displaystyle 224+17=241\)
Decimal to Binary:
\(\displaystyle 79\)
1286432168421
01001111
So I do this by basically figuring what adds up to 79 or by figuring if the number can fit into any (hopefully that makes sense).
Binary to Hexadecimal:
84218421
10100101
I break it up into two sets of 8-4-2-1 and add up the 1's below it accordingly. \(\displaystyle 10=A\) in the first column, and \(\displaystyle 5\) in the scond column so \(\displaystyle A5\)
Hexadecimal to Binary:
\(\displaystyle B4\)
\(\displaystyle B=11,4=4\) so I but ones in the columns above so it adds up to the desired numbers leaving me 10110100.
Hexadecimal to Decimal
Using B4 from above = 11, then times that by 16 which in this case is easy and = 176 then adding 4 = 180
Technology news on Phys.org
The simplest way to change decimal to binary repeated division by 2. 79/2= 39 with remainder 1. 39/2= 19 with remainder 1. 19/2= 9 with remainder 1. 9/2= 4 with remainder 1. 4/2= 2 with remainder 0, 2/2= 1 with remainder 0 1/2= 0 with remainder . So 79= 100111. Notice that "1"s and "0"s are the reverse of those calculations.
Binary to hexadecimal is easy because 16= 2^4 = 10000 in binary. Divide the binary number into groups of 4 digits: 10100101= 1010 0101. Yes, 1010 is 8+2= 10 which is represented by "A" in hexadecimal and 0101 is 4+ 2= 6. 10100101 in binary is A6 in hexadecimal.
To go from hexadecimal to binary is also easy- convert each hexadecimal "digit" to binary.
B= 8+ 3= 1011 and 4 is 0100 so B4 is 10110100.
For something more complicated, E423BF: E= 8+ 4+ 2= 1110. 4= 0100, 2= 0010, 3= 0011, B= 1011, and F is 1111 so E423BF is 111001000010001110111111 in base 2.
This is an easier version of what you were saying I guess halving by two and put a 1 if the number above is odd and a 0 if the number is 0.
01249193979
01001111
Assuming you added A6 wrong? and dropped a 1 off 100111? Or was I wrong lol
Except that I would never say "halving by 2" (what else can you halve by?) that is essentially what I said.
Related to How Can I Easily Tackle Binary and Hexadecimal Problems?
What is binary?
Binary is a numbering system that uses only two digits, 0 and 1, to represent numbers and data.
What is hexadecimal?
Hexadecimal is a numbering system that uses 16 digits, 0-9 and A-F, to represent numbers and data.
What is the relationship between binary and hexadecimal?
Each hexadecimal digit represents four binary digits, making it a more compact and convenient way to represent large binary numbers.
Why are binary and hexadecimal commonly used in computer systems?
Binary and hexadecimal are used in computer systems because they are the basis of digital data and can be easily translated into electrical signals that computers can process.
How are binary and hexadecimal used in programming?
Binary and hexadecimal are commonly used in programming to represent and manipulate data, such as memory addresses and machine instructions.
