Question concerning the mechanics of a magnet's attractive force
  • Thread starter Thread starter BernardRio
    Force Mechanics
The discussion centers on whether the attractive force of a magnet changes when its direction is altered without changing the distance to the object. It suggests that the type of magnet and the nature of the object significantly influence the outcome. For instance, rotating a bar magnet 180 degrees while maintaining its distance from an iron rod may not change the force exerted. However, if both objects are magnets facing each other, the interaction will differ based on their orientations. Ultimately, the mechanics of magnetic attraction are complex and depend on specific conditions and configurations.
BernardRio
New user has been reminded to show their work on schoolwork questions
no equation
Does a force exerted by a magnet change if we do not change the distance between a magnet and the body, but change the direction of the magnet (tilt)?
:welcome:
You need to attempt this question yourself. What do you think?
By the way, why no equation?
What shape magnet? Horseshoe magnet, bar magnet, cylindrical magnet? Try using Google Images to find images of the lines of force coming out of the poles of the type of magnet you are asking about. See if that helps... :wink:
I think the answer depends on what the "body" is.
Consider an actual physical situation, then ask the question again. For example, you have a bar magnet and an iron rod at some distance apart with their axes along the same line. Rotate the magnet about its mid point by 180o. Does the force that the magnet exerts on the rod change? What if the iron rod is replaced with an identical magnet, initially oriented so that the north poles of the two face each other, and then one of the magnets is rotated?
Interesting question: You are given two identical-looking bars and you are told that one is a piece of soft iron and the other a bar magnet. How can you tell which is which?
