Question finding Vf of a charge moving through potential difference
In summary: I deal with the fact that the velocity is less than the speed of light?In summary, the homework statement said that a 2kg charge of +3C moves through a potential difference of 6V and begins at rest. What is its final velocity? The Attempt at a Solution said that if we use the propert 1 N/C = 1 V/m then the final velocity is 4.0x10^-9 N.
pcleary
A 2kg charge of +3C moves through a potential difference of 6V and begins at rest. What is its final velocity?
m = 2kg
q = +3C
dV = 6V
Vi = 0 m/s
Vf = ?
F = m*a
(Vf)2 = (Vi)2 + 2(a)(d)
dV = (ke)(q)/(r)
1 N/C is equal to 1 V/m
Okay I am not sure if this was some mistake given by our professor. This is one of the review questions at the end of his presentation. These are to be done as extra practice. We didn't go over anything like this in class so I finagled my way to what I believe is the answer.
I used the propert 1 N/C = 1 V/m to move over and get 1 N = (V)(C)/(m)
so F (Newtons) = (V)(C)/(m)
now from here I said **** I don't have a distance. What equation could I use to find it (r = distance is assumed here)
Using the dV = ke(q)/r I solved for r = d = 4.5x10^9 m
Plugging into my finagled force formula
F = (6N*m/C)(3C) / (4.5x10^9m) --> F = 4.0x10^-9 N
a = F / m --> a = (4.0x10^-9kg*m/s^2) / (2kg) --> a = 2.0x10^-9 m/s^2
putting this back into my kinematic equation (from christ..3 years ago) I got
Vf = sqrt [2(2.0x10^9m/s^2)(4.5x10^9m)] --> sqrt [18m^2 / s^2]
Vf = 4.24 m/s
Now I know this is an outrageous stretch here. And chances are that I am a fool and wasted my time trying to solve an incomplete / misplaced problem. However being that I calculated all of this using proper units and they all canceled out accordingly I think I am right. Can anyone please chime in on whether or not this is right and if not how it could (if at all) be calculated differently. This is more for my own personal sanity and pride because like I said we didn't go over this type of problem and I don't expect it on the test.
Thanks in advance.
You should recall what "potential" means.
Potential difference is voltage is it not?
Electrical potential energy is (U) in J no?
Can you please explain how to do the problem as it seems inferred that I did it wrong.
So the "electric potential" is the potential energy due to the electric field. When a particle moves under the influence of a potential force from A to B, what can be said about the change of its kinetic energy from A to B?
So the "voltage" is the U due to the E(lectric field). Sorry I am trying to get it in terms that I understand. What is the potential force you're talking about?
If I am reading it right I would say the dKE is 0 because once it reaches B it stops moving / has used all its KE?
The potential force is the force due to the electric field. Which simply means that there is potential energy related to the force.
"Has used all its KE" makes no sense because we do not even know, in general, if there WAS any KE to begin with. In this problem, what is the initial KE?
Now that I think about it doesn't the KE = PE. Or in this case the KE = potential electric energy (U).
So could I have just skipped all that **** and just used the KE = 1/2 mv^2?
Setting U = 1/2 mv^2 and solving for v?
More correctly, ΔKE = -ΔPE.
Not exactly. ΔPE = Uq.
Oh you're right. So ΔPE = potential energy of the charge (Uq).
Could I say that ΔPE = -ΔKE? So it would be
ΔKE = -1/2 mv^2?
Just curious was my answer to velocity correct? If the sign was wrong how could I have anticipated that when doing it my (long and unnecessary) way?
So working it out that way I found.
ΔV = ΔU / q
ΔU = Uq = (6V)(+3C) = 18J
KE = -PE = -Uq
KE = -18J
KE = 1/2*m*v^2
-18J = 1/2 (2kg) (v^2)
v = i sqrt(18)
V = 4.24 m/s , 4.24i m/s
How do I account for the negative (unreal) component?
You can only get negative ΔKE if (initial KE) + ΔKE > 0. If initial KE is not big enough, then this motion is impossible. Physically, that means that a positive charge can move through a positive potential difference only of its initial velocity is high enough. However, it can move in the opposite direction with any initial velocity.
Related to Question finding Vf of a charge moving through potential difference
1. How do you find the final velocity (Vf) of a charge moving through a potential difference?
To find the final velocity of a charge moving through a potential difference, you can use the equation Vf = √(2qV/m), where q is the charge of the particle, V is the potential difference, and m is the mass of the particle. This equation is derived from the conservation of energy principle.
2. What is potential difference?
Potential difference, also known as voltage, is the difference in electric potential energy between two points in an electric field. It is measured in volts (V) and represents the work done per unit charge in moving a charge from one point to another.
3. How does potential difference affect the final velocity of a charge?
Potential difference directly affects the final velocity of a charge. As the potential difference increases, the final velocity of the charge also increases. This is because a higher potential difference means a greater change in electric potential energy, which leads to a greater change in kinetic energy and ultimately a higher final velocity.
4. Can the final velocity of a charge be negative?
Yes, the final velocity of a charge can be negative. This indicates that the charge is moving in the opposite direction of the electric field. For example, if a positive charge is moving towards a negative plate, its final velocity will be negative as it is moving in the direction opposite to the electric field.
5. What are the units of potential difference?
The units of potential difference are volts (V) in the SI system. In the CGS system, the unit of potential difference is called the statvolt (statV). Other common units of potential difference include joules per coulomb (J/C) and electron volts (eV).
