Question for electromagnetic induction
In summary, a conducting rod of length 1 m is rotated with an angular frequency of 400/s about an axis normal to the rod, with one end in contact with a circular metallic ring. In this setup, a constant magnetic field of 0.5T parallel to the axis is present. To find the induced EMF between the ends of the rod, the time derivative of magnetic flux can be taken, with the formula being Flux = A(B)cos(wt), where A is the area, B is the field strength, and w is the angular frequency.
shubhxxx
a conducting rod of length 1 m is rotated with an angular frequency of 400/s about an axis normal to the rod passing through one of its ends .the other end of the rod is in contact with a circular metallic ring. a constant magnetc field of 0.5T parallel to the axis exists in the region.find the emf induced between the ends of the rod.
I think you might be able to take the time derivative of magnetic flux which is voltage.
So it will be , Flux= A(B)cos(wt)
where A is the Area B is the field strength
FAQ: Question for electromagnetic induction
What is electromagnetic induction?
Electromagnetic induction is the process of generating electricity in a conductor by moving it through a magnetic field or by changing the magnetic field around it.
How does electromagnetic induction work?
Electromagnetic induction works by creating a magnetic field around a conductor, which can be achieved by either moving the conductor through a stationary magnetic field or by changing the magnetic field around the conductor. This movement or change in magnetic field creates an electric current in the conductor.
What are some real-life applications of electromagnetic induction?
Electromagnetic induction has many practical applications, such as in generators, transformers, motors, and wireless charging technology. It is also used in devices like induction cooktops and metal detectors.
Who discovered electromagnetic induction?
Electromagnetic induction was discovered by English scientist Michael Faraday in 1831. He found that when a magnet is moved through a coil of wire, it induces a current in the wire.
How is electromagnetic induction related to Faraday's law?
Faraday's law of electromagnetic induction states that the magnitude of the induced electromotive force (EMF) in a closed circuit is proportional to the rate of change of the magnetic flux through the circuit. In other words, the faster the magnetic field changes, the greater the induced EMF and current in the circuit. This is the basis for understanding and applying electromagnetic induction in various technologies.
