Question from trigonometry -- prove that the largest angle is greater than 120°
In summary, in a triangle with sides 3, 4, and √38 meters, it can be proven that the largest angle is greater than 120° by using the law of cosines and showing that the longest side is too long for a 120° angle. This can also be seen by taking the sine of both sides of the equation and observing that it does not follow that the angle is greater than 60°.
prashant singh
56
Thread moved from the technical forums, so no HH Template is shown.
In a triangle whose sides are 3,4 and root 38 metres respectively, prove that the largest angle is greater than 120°
  • My answer: Here angle C > B...(1) and C > A ...(2) adding (1) and (2) we get 2c > A+B, taking sine both side , sin2C = sin(A+B) = sin(C), therefore cosc > (1/2) therefore angle C> 60°
  • I am not getting C> 120°, what is the problem please help
(180-60)=120 is also a solution, now you should think how to prove that particular solution
Why not use the law of cosines? Find the angle between the short sides.
## 38 = 3^2 + 4^2 - 2(3)(4)cos(θ) ##
Now solve for θ.
Now solve for θ.
There's a typo in the equation above. The 38 should also be squared.
No. It's ##\ \sqrt{38}\ ## which is being squared.
Missed the root in the OP.
I guess you meant sin 2C > sin(A+B), but that does not follow. Once the angle exceeds 90 degrees the sine function is decreasing. Indeed, sin(2C) would be < sin(A+B) here.
That's backwards. If sin(2C) were > sin(A+B), it would follow that C is less than 60.
@mfig's method is fine, but you do not need to solve for theta. Just show that the longest side is too long for a 120 angle.
Likes prashant singh
Related to Question from trigonometry -- prove that the largest angle is greater than 120°
1. How do you prove that the largest angle in a trigonometry question is greater than 120°?
To prove that the largest angle is greater than 120°, we can use the fact that the sum of the angles in a triangle is 180°. If the other two angles are less than 120°, then the largest angle must be greater than 120°.
2. Why is it important to prove that the largest angle is greater than 120° in trigonometry?
In trigonometry, angles are often used to calculate various measurements, such as distances and heights. If the largest angle is less than 120°, it may not provide an accurate or meaningful solution to the problem at hand.
3. Can you provide an example of a trigonometry question where proving the largest angle is greater than 120° is necessary?
One example would be a question that involves finding the height of a tall building using the angle of elevation. If the largest angle is less than 120°, the calculated height may not be accurate.
4. Are there any specific trigonometric identities or formulas that can be used to prove that the largest angle is greater than 120°?
Yes, there are several identities and formulas that can be used depending on the given information in the question. Some examples include the Law of Sines, Law of Cosines, and the Pythagorean Theorem.
5. Can you use a proof by contradiction to show that the largest angle is greater than 120°?
Yes, a proof by contradiction can be used by assuming that the largest angle is less than or equal to 120° and then showing that it leads to a contradiction. This would prove that the initial assumption was false and the largest angle must be greater than 120°.
