Question i had in my quiz about sequences.
In summary, the conversation discusses a sequence {a_n} that satisfies certain conditions. The question being discussed is whether the subsequence {a_2n} converges if {a_n} is bounded. Various counterexamples are proposed, including a sequence with even terms following a non-convergent path and odd terms being the reciprocal of a point between two even terms. Ultimately, a formal proof using the properties of continuity and uniform continuity is presented.
MathematicalPhysicist
372
we have a sequence {a_n}, such that for every n natural, a_n>0 and it satisfies:
lim (a_n*a_n+1)=1
prove/disprove:
if {a_n} is bounded then {a_2n} converges.
i haven't found any counter example, is this statement true or false, if is false then what's the counter example?
p.s
couldn't you say that this sequence is bassically a sequence of a positive number and its reciprocal?
Mathematics news on Phys.org
ofcourse also, a_n=1-1/n satisfies the priliminary criteria, and it's not a number and its reciprocal.
but still i couldn't find a counter example.
you could have said that if anan+1 = 1. that's not what is given. but lim (anan+1) = 1. the two are different.
i know that, but do you have a counter example for the statement that if
{a_n} is bounded then {a_2n} converges?
so...?
anyone?!
it's a great question. without boundedness 1/1, 2, 1/3, 4, 1/5, 6,... would be a counterexample.
i haven't found a solution, but my hunch is there is no counter example. this means proving it and that means (by above counter example) we have to use the bounded property. this is tricky.
scratch that i think i have a CE
a_n = 2+Sin [Ln[n]], n even
a_n = 1/(2+Sin[Ln[n]]), n odd
idea is anything that oscilates without converging (hence sin), but with the each term getting closer, but not converging (hence log), and its reciprocal. haven't checked it, lol
the whole point of this problem is that it's bounded.
the problem if it's correct then how to prove it, but I am not sure that's correct so i asked for counter example.
see my edit to my above post
but does lim a_n*a_n+1=1
if n is even then a_n=2+sin(ln(n)) a_n+1=1/(2+sin(ln(n+1))
lim (2+sin(ln(n))/(2+sin(ln(n+1)) does this converges to 1?
ln(n)diverges but sin(ln(n)) it's limit isn't defined.
i dunno. it looks like it does, but you need to do the legwork, it's your quiz. it's probably easier to define a similar sequence in a more awkward way that makes working out the product limit easier. the idea is that even terms follow a non convergent path (such as sin wave) but with terms ever closer along such a path, but without converging. odd terms, being the reciprocal of a point between the two even terms, should allow the limit of the product to converge. I'm not sure it's right, but i can't be bothered with pursuing this line tonight
which is what we want
i don't think you example works, cause I am not sure it stisfies lim a_n*a_n+1=1.
i'm taking that a_n+1 to be the n+1 term of the sequence, not the n term plus 1
like i say i haven't done an epsilon delta proof as the manipulation is messy. i just took it as far as mathematica would go in reasonable time and got it limiting to 1. certainly not a proof, just a good candidate for one
do you get the basic idea of an oscilating a_2n subsequence with terms "getting closer", but not converging?
another even subsequence that might do it. 2, 3, 2 1/2, 2, 2 1/3, 2 2/3, 3, 2 3/4, 2 1/2, 2 1/4, 2, 2 1/5, 2 2/5, 2 3/5, 2 4/5, 3, etc
set the odd members appropriately
in fact if you set odd terms to just be 1/even terms you get a_n*a_n+1 = 1 or a_n * a_n+1 = (2 + i/p)/(2+(i-1)/p) = (2p + i)/(2p + i-1) which definitely limits to 1. you also have to take care of the "corners" of the oscilation, but i don't see these being a problem
yes i know, but according to your sequence:
when n is even then a_n=2+sin(ln(n))
and n+1 is odd ofcourse so we have (the n+1 term)a_n+1=1/2+sin(ln(n+1))
i don't see how the limit of this multiplication gives one, even by arithematics of limits.
It does work out. Remember ln(n+1)-ln(n)->0 as n->infinity (to see this, just exponentiate it), and since sin is uniformly continuous (which follows from being continuous and periodic), we have that for any e>0 there is a d>0 with |x-y|<d => |sin(x)-sin(y)|<e. Combining these gives the result.
you missed some brackets/ that limit doesn't have to give 1. you've forgotten your own question, the product of two succesive (so even and odd) terms has to limit to 1
and StatusX a big thankyou for formalising my intuition, if that's what you did (hungover)
and OP I'm unsubscribing. if you don't get it now you never will
i don't understand stauts, we have something like this:
[2+sin(ln(n))]/[2+sin(ln(n+1)]
we don't have here ln(n+1)-ln(n) outside the sin function, how do you justify that this converges to one, i still don't see it.
perhaps ln(n+1)->ln(n)
and thus sin(ln(n+1))->sin(ln(n)) cause sin is continuous.
ok, i think i get.
perhaps someone knows an example which doesn't use the fact of continuity of functions?
What about:
[tex]1, 3,\, 2.5^{-1},\, 2,\, 2.25^{-1},\, 2.5,\, 2.75^{-1},\, 3,\, \left (2\frac{5}{6}\right )^{-1},\, 2\frac{2}{3},\, 2.5^{-1},\, 2\frac{1}{3},\, \left (2\frac{1}{6}\right )^{-1}, 2, 2.125^{-1},\, 2.25,\, \dots[/tex]
The 1 at the beginning serves little purpose except to make (a2n) consist of the terms that oscillate between 3 and 2, and never converge. But the overall sequence is bounded, and at a glance, it appears to satisfy the property [itex]\lim _{n\to \infty}a_na_{n+1} = 1[/itex].
AKG said:
What about:
which is very like my 2nd counter example #13
Related to Question i had in my quiz about sequences.
1. What is a sequence?
A sequence is a list of numbers or objects in a specific order. It can be finite or infinite, and each number or object in the sequence is called a term.
2. How do you find the next term in a sequence?
To find the next term in a sequence, you can look for a pattern in the sequence, such as an arithmetic or geometric pattern. You can also use a formula, if one exists, to calculate the next term.
3. What is an arithmetic sequence?
An arithmetic sequence is a sequence in which each term is found by adding a constant number to the previous term. For example, in the sequence 2, 5, 8, 11, 14, the constant difference is 3.
4. What is a geometric sequence?
A geometric sequence is a sequence in which each term is found by multiplying the previous term by a constant number. For example, in the sequence 2, 6, 18, 54, 162, the constant ratio is 3.
5. How can you determine if a sequence is arithmetic or geometric?
To determine if a sequence is arithmetic or geometric, you can look for a constant difference or ratio between terms. If there is a constant difference, it is an arithmetic sequence. If there is a constant ratio, it is a geometric sequence. You can also graph the sequence and see if it forms a straight line (arithmetic) or a curved line (geometric).
