Question Involving Conservation of Momentum
In summary, the question asked for the velocity of two cars before a collision. The correct method to find this is by using conservation of momentum. The first step is to find the velocity of the cars immediately after the collision by using the equations for final velocity in the x and y directions. However, in the attempt at a solution, the equations used for final velocity were incorrect and the resulting velocities were wrong. The proper way to solve this problem is by using the equation for conservation of momentum.
Jay520
A 1500-kg sedan goes through a wide intersection traveling from north to south when it is hit by a 2200-kg SUV traveling from east to west. The two cars become embeshed due to the impact and slide as one thereafter. On-the-scene measurements show that the coefficient of kinetic friction between the tires of these cars and the pavement is 0.75, and the cars slide to a halt at a point 5.39 m west and 6.43 m south of the impact point. How fast was each car traveling just before the collision.
vxf2 = vx02 + 2aΔx
vyf2 = vy02 + 2aΔy
The question asks to find the velocity of both cars before the impact. I figure this could be solved by applying conservation of momentum. Since friction would be so small compared to the force from the collision, we could set the initial momentum equal to the momentum after the collision. This would allow me to find initial velocities for both cars.
But before I do this, I would need to find the velocity for both cars after collision. I found this by using the two equations above. I know the acceleration (due to friction) after the collision, and I know the displacement after the collision, so I should be able to find velocity immediately after collision. First, I find acceleration.
F = mgμ = ma
∴ a = gμ
Using the above equations:
vx = √(2aΔx) = √(2gμΔx) = √(2*9.8*0.75*5.39) = 8.901 m/s
vy = √(2aΔx) = √(2gμΔy) = √(2*9.8*0.75*6.43) = 9.72 m/s
These are the components for the velocity of the two cars after the collision. Using conservation of momentum, I can find the velocity of the cars before the collision. Note that the sedan is the only car with momentum initially in the y direction, and the SUV is the only car with momentum initially in the x direction.
(subscript a is for SUV; subscript b is for the sedan)
mava = (ma+mb)vx
∴va = 14.97 m/s
mbvb = (ma+mb)vy
∴vb = 23.98 m/sUnfortunately, I am told that these answers are wrong. The answers from the back of my textbook are 12 m/s and 21 m/s. I even tried using the work energy theorem (to calculate the velocities after the collision), and I still get the same answer. Anyone see what I'm doing wrong, or if there is a problem with the textbook perhaps? Maybe something wrong with my calculator?
I figured out the proper way to do this problem. Does anyone know why the above method does not work?
Yep - by the two step method you used:
Step 1: find the relationship between the velocity immediately after the collision and the stopping distance.
lets be a bit more careful with notation: - but putting x and y as the components of the displacement after the collision and d as the total displacement this time, then you did:
$$\begin{align}v^2 & =2ad\\ \implies v_x^2+v_y^2 & = 2\mu g x + 2\mu g y\end{align}$$
... but: ##d=\sqrt{ x^2+y^2}##
What is the proper way to do this?
Try Simon's method. Note that he is saying equation (2) is wrong. See if you can write it correctly.
Likes Simon Bridge
Related to Question Involving Conservation of Momentum
1. What is conservation of momentum?
Conservation of momentum is a fundamental principle in physics that states that the total momentum of a closed system remains constant, unless acted upon by an external force.
2. How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. It is represented by the symbol "p" and has units of kg*m/s in the SI system.
3. What is an example of conservation of momentum in action?
An example of conservation of momentum is when a billiard ball hits another billiard ball, causing the second ball to move with the same momentum as the first ball before the collision.
4. What are the implications of conservation of momentum?
The conservation of momentum has many implications, including the ability to predict the motion of objects in collisions and explosions, as well as understanding the behavior of objects in space.
5. Are there any exceptions to conservation of momentum?
Conservation of momentum is a well-established law in physics, but there are a few exceptions, such as when there are external forces acting on a system or when there is a loss of momentum due to friction or other dissipative forces.
9K
