Question of enthelpy of vaporization the diference from ln to log
In summary, the vapour pressure of benzene between 10°C and 30°C fits the expression log(p/Torr) = 7.960 - 1780/(T/K). Calculate (a) the enthalpy of vaporization and (b) the normal boiling point of benzene.
demander
hi, I'm new around here but i really need your help this question is similar to one already solved here some years ago
Vapour pressure of a liquid in the temperature range of 200Kto 260K is given by this expression
ln (p/Torr) = 16.255 - 2501.8(T/K)
Calculate the enthaly of vaporization of hte liquid
since this is the liquid vapour boundary
and
so then the ratio of Ln p to ln p* would yield the expression for chi which i cna then solve for delta H but it doesn't yield that same answer
what am i doing wrog here can you push (or shove) me iin the right direction
i have an exam today thus i need to answer this once and for all
thank you for help!
so my problem is:
1.The vapour pressure of benzene between 10°C and 30°C fits the
this exercise is in atkins 8th edition physical chemistry page 133 for someone who could have it
3.i try to solve the problem using the same idea as the you said for the exercise i quoted that was:
Calculate the enthalpy of vaporization of the liquid
First of all it is important to get the question right if you want people to help you. Your expression is unintelligible as it is. The expression must be:
where P is the ambient pressure in Torr (mm/hg) and T is in Kelvins. Now it makes sense.
The expression for vapour pressure is given by:
where is the Heat or Enthalpy of vaporization in J/mol.
From the expression for this gas, it is apparent that:
AM
seem that something changes from ln to log if it helps the solution is supposed to be around +34,08Kj mol^-1
the b) is not important if you could help me in a) i would thank a lot
that question of enthalpy of
vaporization will appear in a next test so i will await you're help thanks
thin i have said all necessary any necessary chnage say it please
but it's making me crazy how a simple change from a ln to log can make so much difference :S
PS: i tried to put the link to the post instead of the quote but i was not allowed
State all of the relevant equations not just the equations that you were given.
complementation to the first post
well usually when we learn about clausius clapeyron equation we learn with ln
[tex]ln(P) = constant - \frac{\Delta H_{vap}}{RT}[/tex]
however the problem i shown has log instead of ln
instead of this shot thing i think the resolution must be something like using this [tex]\frac{\Delta H_{vap}}{R} = 1780[/tex] I'm not sure
1780 is the number i give in the question log(p/Torr) = 7.960 - 1780/(T/K), but maybe my error starts just here :S
but now i don't know how the change from ln to log can influence the method cause the original equation is in ln not in log
i think is this what was missing,
can a admin add this to original post please?
Solve the Clasius Clapeyron equation for P and also the equation that you were given for P - set these two equations equal to each other then utilize some math to relate the two sides in a linear fashion - someone else here may be able to give you a simpler solution. The equations should be the same except for the constants however you are simply concerned with the term that has the delta Enthalpy value so it should not be a problem.
That is set the two equations for P and then set the independent portions equal to each other. Next take the Ln of both sides - use a special rule for the Ln to simplify one of the sides into linear form - what happens is that you get your equation for Ln (P) and it turns out that it is nearly the same as your Log (P) except for an additional constant which is - Ln (10) .
in value terms
Ln (P) = -1780/T - -7.960 -Ln (10)
that ln10 seem to be a big key in this situation
cause with this i was cheking and found the following propertie that i really didn't know that
substituting
[tex]\frac{\ln n}{ln 10}= constant - \frac{\Delta H_{vap}}{RT}[/tex]
so passing the ln10 to the other side became:
[tex]ln n= constant*ln 10 - \frac{\Delta H_{vap}}{RT}ln 10[/tex]
so using the expression and not forgeting the multiplication with ln10
[tex]\frac{\Delta H_{vap}}{R}ln10 = 1780[/tex]
and puting in order to [tex]\Delta H_{vap}[/tex]
[tex]\Delta H_{vap} = 1780*R*ln10[/tex]
the last pass is making the product of the ln10 with the result of the last expression
i've tried and as R=8,314
[tex]\Delta H_{vap} = 1780*8,314*ln 10 [/tex]
the result is 34075J =34,075KJ the solution
is this reasoning right? sometimes the result is right but the method can be wrong
i would never remember to work the log to obtain the ln, if i didn't put this question here... :)
You would actually have the ln(10) on the denominator when solving for the Enthalpy - so 34.075kJ is the right answer?
yeah the result on solutions is that 34,075
Yeah I just found that log to ln relation myself - your work seems fine forget what I mentioned about multiplying and dividing - it seems that the only value with units is R ; were you given the units for the value of 1780? I would be just concerned with how you show the steps in the cancellation of the units - that's all.
Related to Question of enthelpy of vaporization the diference from ln to log
1. What is enthalpy of vaporization?
Enthalpy of vaporization is the amount of energy required to transform a liquid substance into a gas at a constant pressure. It is also known as the heat of vaporization.
2. How is enthalpy of vaporization measured?
The enthalpy of vaporization is typically measured in units of joules per mole (J/mol). It can also be expressed in kilojoules per mole (kJ/mol) or calories per gram (cal/g).
3. What is the difference between ln and log in relation to enthalpy of vaporization?
Both ln and log refer to mathematical functions used to calculate the natural logarithm and the logarithm base 10, respectively. In the context of enthalpy of vaporization, ln and log are used interchangeably to represent the natural logarithm of the vaporization constant, which is a measure of the rate at which a liquid evaporates.
4. How does enthalpy of vaporization affect the boiling point of a substance?
The enthalpy of vaporization is directly related to the boiling point of a substance. In general, substances with higher enthalpies of vaporization will have higher boiling points, as more energy is required to change the substance from a liquid to a gas at a constant pressure.
5. What factors can influence the enthalpy of vaporization?
The enthalpy of vaporization can be affected by several factors, including the type of substance, temperature, and pressure. Generally, substances with stronger intermolecular forces will have higher enthalpies of vaporization, and increasing temperature and pressure can also increase the enthalpy of vaporization.
