Question on Baryons and Specific Decays
In summary, beta decay occurs when the daughter nuclei has a mass that is lower than the parent nuclei. The reason for beta decay is to reduce the mass of the constituent particles.
olv
1) We know in case of beta decay if there is excess of protons or neutrons in the nucleus beta decay take place.
Force involved - weak interaction
Reason involved - to stabilize, to obtain proton neuton 1:1 ratio in the nucleus.
E. g., Beta minus - Carbon 14 transforms into Nitrogen 14
2) Case of Lambda & Sigma baryons -
Reason involved - ?
Does anyone know the reason why Lambda Λ0 (uds - quark composition) decays into,
p+ + π−
or
n0 + π0
Also why Sigma Σ+(uss - quark composition) decays into,
p+ + π0
or
n0 + π+
What mechanism make them go decay into proton or neutron( ignore the π0 & π+) ? What is the reason involved ?
Beta decay of nuclei occur when the daughter nuclei has lower mass than the parent nuclei.
You have to specify what "stabilize" means. Here it means minimizing the mass.
Decays occur whenever it is possible. If something is possible in quantum physics, there is a non zero probability for it to happen.
Likes Vanadium 50, ohwilleke, vanhees71 and 1 other person
Reason involved - ?
p+ + π−
or
n0 + π0
p+ + π0
or
n0 + π+
The short answer is the answer to the question "Why does any particle decay?" It's always the same answer: because the decay products are more stable than the particle that is decaying.
The reason ##C^{14}## decays into ##N^{14}## is because ##N^{14}## has a more stable nucleus than ##C^{14}## does, not that we need the number of protons to equal the number of neutrons. (That reasoning only works for the smaller atomic numbers.)
Also, note that the ##\Lambda ^0## has two decay modes:
##\Lambda ^0 \rightarrow p^+ + \pi ^-##
and
##\Lambda ^0 \rightarrow p^+ + e^- + \overline{ \nu }_e##
When it comes to subatomic particles it is almost always true that the higher the mass, the quicker it decays. So (generally, not always) the reason for the decay is to reduce the mass of the constituent particles.
-Dan
Likes vanhees71 and malawi_glenn
"More stable" has nothing to do with why particles decay.
Particles decay if the sum of the masses of the decay products is less than the mass of the decaying particle.
Likes vanhees71, mfb and malawi_glenn
That's more or less the content of the lifetime amplitude. But wouldn't that define the measure of the stability of a particle? That's the way I've always looked at it, anyway. Is there a more exact definition of stability?
-Dan
I usually consider the lifetime to be a measure of stability, with the shorter the lifetime, the less stable.
Likes topsquark and malawi_glenn
And if the conservation laws are fulfilled, like electric charge etc
Likes Vanadium 50, vanhees71 and topsquark
Of course.
Uranium-238 with a half life of 4.5 billion years decays to thorium-234 with a half life of 24 days (which then decays to 234mPa with a half life of just 1 minute). I see no way how the thorium isotope could be called "more stable" than its parent.
##\Lambda## with a lifetime of 2.6*10-10 seconds has a 1/3 chance to decay to a neutron plus ##\pi^0##, the latter has a lifetime of just 8*10-17 seconds.
Likes topsquark, vanhees71 and PeroK
A very good point. Even though the problem started with a nucleus, I hadn't really thought that one through. (I usually ignore anything bigger than a proton. :) )
Thanks for the catch!
-Dan
Likes mfb and malawi_glenn
FAQ: Question on Baryons and Specific Decays
What are baryons and how do they differ from other hadrons?
Baryons are a class of subatomic particles that are composed of three quarks, making them a type of hadron. They differ from other hadrons, such as mesons, which are made up of a quark-antiquark pair. Baryons, including protons and neutrons, are found in the nucleus of atoms and have half-integer spin, classifying them as fermions.
What are some common decay processes involving baryons?
Common decay processes involving baryons include beta decay, where a neutron decays into a proton, an electron, and an antineutrino. Another example is the decay of hyperons, which can decay into nucleons and pions through weak interactions. Baryon decays are crucial for understanding the stability of matter and the processes occurring in stars.
What role do baryons play in the universe's matter content?
Baryons are a significant component of the universe's matter content, constituting ordinary matter, which makes up stars, planets, and living organisms. They account for approximately 4.6% of the total energy density of the universe, with baryonic matter being primarily composed of protons and neutrons. Understanding baryons helps scientists study the formation and evolution of cosmic structures.
How do baryon decays relate to the conservation laws in physics?
Baryon decays are governed by several conservation laws, including the conservation of energy, momentum, charge, and baryon number. In most decay processes, the total baryon number before and after the decay remains constant, which is essential for ensuring the stability of baryonic matter. Violations of these conservation laws can lead to new physics beyond the Standard Model.
What experimental methods are used to study baryon decays?
Experimental methods for studying baryon decays include particle colliders, where high-energy collisions can produce baryons and allow for the observation of their decay products. Detectors such as bubble chambers, wire chambers, and calorimeters are used to track and measure the properties of particles resulting from baryon decays. Additionally, experiments at facilities like CERN and Fermilab provide insights into baryon behavior and decay mechanisms.
