Question on Boltzman statistics and numbering of states
In summary: I guess I would need to solve the TDSE to get the exact form.In summary, the conversation discusses the use of Boltzmann statistics to calculate the probability of finding an atom in a particular energy state in a monatomic gas of hydrogen at temperature T. The formula for the probability takes into account the state degeneracy and the partition function. The conversation also touches upon the issue of highly excited states and their impact on the population of low-energy states. It is concluded that for a finite volume, the number of excited states is finite and therefore, highly excited states do not significantly impact the population of low-energy states. However, in an infinite volume, the number of excited states is infinite and their impact
Sonderval
234
Consider a monatomic gas of hydrogen (just to make the example as simple as possible) at a temperature T. If I use Boltzmann statistics, I would say that the probability of finding any arbitrary atom at energy E should be proportional to
##g_i e^{-E_i/(k_BT)} / Z(T)##
where ##g_i## is the state degeneracy (number of states at each level).
Thinking about this, I utterly confused myself in two ways, so I hope someone can help me out.
1. Since the states become more and more dense at higher quantum numbers n (only looking at bound states), it seems as if even at small temperatures, most atoms should be in an excited state with very large n: If I use 1Ry as the energy difference between ground state and a highly excited state (which should be a reasonable approximation), I can always find enough states close to the ionisation energy that the summed probability of each of these states is larger than that of the ground state. Obviously I'm making a mistake here, but I have no clue what it is.
2. Consider just the first to shells. Is the ratio of the probabilty of finding an atom in the ground or in the first excited state given by ##e^{-(E_2-E_1)/(k_BT)}## or do I need an additional factor of 4 because the second shell has one s and three p orbitals?
Likes 1 person
I don't understand how you get a high population in high-energy states. Even though the degeneracy increases as ##n^2##, the exponential factor dominates even at relatively high temperatures, such as the sun's atmosphere (5800 K). Even at that temperature, the ratio of ##n=2## atoms over ##n=1## is of the order of ##10^{-9}##.
Yes, you need the factor of 4.
Likes 1 person
@Dr Claude
Thanks for the answer. At least #2 assures me that I'm not totally off in how to count states.
Considering question 1, since we have an infinite number of states with energy less than 1 Rydberg above the ground state, I don't see how the exponential factor can dominate that. For simplicity, let's assume that all excited states are at 13,6eV above the ground state, so they all have the same Boltzmann factor.
If the Boltzmann factor has a value of x, I need 1/x excited states to get equal probability for the excited and the ground state.
You're right, I was thinking of only the first few excited states. If you take into account all states, the partition function is actually infinite.
The "solution" to this problem is that the sum over all states of hydrogen doesn't make sense. It is strictly valid only for non-iteracting particles, and works only if a hydrogen atom is always a hydrogen atom. Highly-excited atoms can be seen as having an electron with a very low binding energy, and a relatively low-energy collision will be sufficient to ionize it. Therefore, highly-excited states are not significantly populated at any temperature.
... and to handle the unbound states: to have many of them (or even a continuum), you need a single atom in a very large ("infinite") volume, where ionization is indeed the most probable result in equilibrium. With a finite volume, the number of states is lower, and you get the more realistic case of rare ionizations.
Thanks for the help, but I'm not sure I understand this solution. (Probably I'm overlooking something obvious) If the excited (but still bound) atoms can also ionize completely, how does this skew the occupation numbers in favor of low-energy states? (I understand that the number of states in a finite volume is bounded, but this still increases the - already infinite - number of possible states.) I still don't see how I can apply the Boltzmann formula and get a correct result, with or without the continuum states, if I have to sum over infinitely many states that are close to the ionisation energy.
The excited states are not proper eigenstates of the energy - they don't exist long enough for the single atom, and they don't exist at all if you look at the whole system.
And their number is finite if the volume is finite.
Likes 1 person
@mfb
I'm not sure I accept the first part of your statement - in principle, these states as calculated from the SGL are eigenstates and would be stable if not for external influences. (And the argument would hold for any Eigenstate of the SGL; making every thermodynamic analysis of a QM system - like the Sommerfeld model - very problematic.)
"And their number is finite if the volume is finite."
I think this hits the nail on the head: In a finite volume, there is no "n=1googolplex"-state because this would be extremely extended. And thinking further, I would assume that for the same reason we cannot really excite these states because the electron would have to delocalise extremely. So even in an infinite volume, to excite a single hydrogen atom into one of these states would probably be very difficult - a perfectly tuned photon could do the trick, but the energy density of all photons in the required energy range (13,6eV above ground state) would be finite.
And thinking further on the problem, the same holds for the higher angular-momentum states of these levels - there is simply no mechanism to excite a hydrogen atom in its ground state into the n=1000000 level with angular momentum number l=999999.
There is infinity of eigenfunctions near ionization (energy = 0) if the hydrogen atom is the only thing in infinite space.
If we enclose the hydrogen atom in a box of finite volume, only first few eigenfunctions will resemble the the same number of previous ones; gradually, as ##n## increases, the eigenfunctions will begin to resemble those of a free particle in a box. The number of the latter is still infinite, but this time, they are well spaced on the energy axis as ##n^2## with increasing gaps, which makes the partition function ##Z## to converge. There is no longer infinite density of eigenfunctions anywhere on the energy axis - the box removes this.
Now, the box does seem artificial, but it can be estimated that the resulting probabilities for first few eigenfunctions depend very weakly on the volume of the box, so it does not matter whether you take ##V^{1/3}## equal to the mean inter-atomic distance or its twice.
Likes 2 people
@Jano
Nicely explained, thanks.
Related to Question on Boltzman statistics and numbering of states
1. What is Boltzman statistics?
Boltzman statistics is a mathematical model used to describe the behavior of a large number of particles in a system, such as atoms or molecules. It takes into account the energy levels and probabilities of the particles in order to calculate the overall behavior of the system.
2. How is Boltzman statistics related to the numbering of states?
Boltzman statistics is used to determine the number of possible states that a system can exist in, based on the energy levels and probabilities of its particles. This allows us to understand the distribution of particles among these states and predict the behavior of the system.
3. What is the significance of the Boltzman factor in Boltzman statistics?
The Boltzman factor, represented by the letter 'k', is a constant used in Boltzman statistics to relate the energy of a system to its temperature. It is an important factor in determining the probability of a particle being in a certain state at a given temperature.
4. How does Boltzman statistics apply to real-world situations?
Boltzman statistics is used in many fields of science, including physics, chemistry, and biology, to understand the behavior of systems at a molecular level. It has applications in various fields, such as studying the distribution of energy in a gas, predicting the behavior of chemical reactions, and understanding the behavior of biological systems.
5. Are there any limitations to the use of Boltzman statistics?
While Boltzman statistics is a useful model for understanding the behavior of systems, it does have some limitations. It assumes that the particles in a system are in thermal equilibrium, and it does not account for quantum effects. Therefore, it may not accurately describe systems with low temperatures or particles with high energy levels. Additionally, it does not consider interactions between particles, which can be important in certain systems.
  • Classical Physics
  • Quantum Physics
  • Classical Physics
  • Atomic and Condensed Matter
