Question on derivative of conjugate
In summary: Of course, the derivative obtained depends on the choice of u, and so is not a property of the point x alone."I suspect that the definition of the directional derivative in your book is for unit vectors only.Furthermore, the complex numbers are not an ordered field, and therefore are not an ordered vector space either. This means that the concept of a positive or negative directional derivative does not make sense in the complex plane. So the directional derivative can only have magnitude, not direction or sign.In summary, the conversation discusses finding the derivative of the complex conjugate function and whether it is a differentiable function. It is concluded that the function is not differentiable anywhere, but directional derivatives can still be calculated
  • #36
While on the topic of dz and dz-bar, it's nice to note that using differential forms in complex analysis brings out the deep connections with multivariable calculus. (After all, C is just R^2 with multiplication.)
First, note that if f is holomorphic in some region, then f dz is closed in that region. Upon applying Stokes' theorem, Cauchy's integral theorem follows as a trivial corollary. (The integral of f dz over the boundary equals the integral of d(f dz)=0 over the interior.) Once this connection is established, it gives the theorem a wonderful physical interpretation: a conservative force does no work over a closed path.
If f is instead meromorphic in a region, then the residue theorem follows similarly: this time the integral of f dz over a loop gives the sum of the integrals of small loops around the poles, which give the residues (up to winding numbers and a multiplicative constant).
  • #37
some of the confusion is the distinction between ∂/∂z and d/dz. As defined in usual complex analysis courses, df/dz does not exist unless f is holomorphic, but ∂f/∂z exists for every smooth f.
Hence if f(z) = zbar, then df/dz does not exist, but ∂f/∂z = 0.
  • #38
Moreover, now the Cauchy-Riemann equations take the suggestive form ∂f/∂z-bar=0, i.e. f is only a function of z.
  • #39
this is what i tried to say at the bottom of post 29.
