Question on drawing a diff.equation
  • Thread starter transgalactic
  • Tags
    Drawing
In summary, the conversation is discussing finding the slope of isoclines for the equation y'=1+x-y and the solution y=x+(1-c). It is mentioned that for c=0, the tangent lines are not perpendicular and the slope of each isocline can be assigned based on the equation. There is also mention of finding the slope for specific values of c.
transgalactic
1,395
i got this equation
y'=1+x-y
i got y=x+(1-c)
for the isocline c=-1
i got tangent lines which are perpendicular
for c=0 the are not
why is that??
how do i find the slope of each isocline?
What do you mean you "got y= x+ (1-c)"?
this is a solution of this y'=1+x-y differential is y=x+(1-c)for the isocline c=-1
for c=0 the are not
why is that??
No, it isn't. If y= x+ (1-c), then y'= 1, obviously. The general solution to y'= 1+ x- y is
y= ce-x+ x.
for c=0 the are not
why is that??
ok
so generally how do i find the slope of each isocline
(those lines that we draw on the isoc lines)
You don't find the slope of an isocline- you assign it. For example, with dy/dx= 1+ x- y, the isocline ("iso-cline": equal slope) corresponding to slope 0 must include points (x,y) such that 1+ x- y= 0 or y= x+ 1. Draw that line. The isocline corresponding to slope 1 must include all points (x,y) such that 1+ x- y= 1 or y= x. Draw that line. choose whatever values, s, you want for the slope. The corresponding isocline is the line dy/dx= 1+ x- y= s or y= x+ (1-s).
FAQ: Question on drawing a diff.equation
What is a differential equation?
A differential equation is a mathematical equation that describes how a variable changes over time, based on its current value and rate of change. It is commonly used to model physical, biological, and economic systems.
How do you draw a differential equation?
Drawing a differential equation involves graphing the solutions of the equation on a coordinate plane. The x-axis represents the independent variable, while the y-axis represents the dependent variable. The solutions can be plotted using various techniques, such as slope fields or phase portraits.
What is the purpose of drawing a differential equation?
Drawing a differential equation helps to visualize and understand the behavior of a system over time. It can also be used to predict future outcomes and make informed decisions in various fields, such as physics, biology, and economics.
What are some common techniques used to draw differential equations?
Some common techniques used to draw differential equations include slope fields, phase portraits, and direction fields. These techniques involve graphing the solutions of the equation and can provide insight into the behavior of a system over time.
Can differential equations be solved without drawing them?
Yes, differential equations can be solved without drawing them. There are various analytical and numerical methods, such as separation of variables and Euler's method, that can be used to find exact or approximate solutions to a differential equation without the need for graphing.
