Question on electric cars coming in the future
In summary: The lotus uses electric motors in the wheel hubs. The chevy is a hybrid vehicle so keeps the existing engine and power train and adds an electric motor. Both can do regenerative braking = using the motor as an alternator to recover energy and increase battery life.
sangackt
Hi. I've been planning to get an electric car around 2010 or after when most manufacturers will have cars out. After some searching I've seen Chevy will have their Volt which can go 40 miles on a charge. Mitsubishi is making one (the Colt) that will go 90 miles on a charge. I'm not sure of the charge times of the two cars but I think they are relatively long. Then I find Lotus teaming with Zap to make a car that goes 350 miles. This Lotus will be 4-6 times more powerful than the former cars also (I'm assuming). Also the Lotus car will be able to charge in 10 minutes.
Now here are my questions,
How does the Lotus car get such a big difference? I'm imagining that Lotus has better engineers? Maybe they're engineering systems on the car that will charge the battery on deceleration (like Prius cars do) and then another system that "supercharges" the car during acceleration? By supercharging I mean giving it extra power to accelerate, like superchargers do on petrol cars.
If I remember my electromagnetism correctly, could they be doing something like wrapping the axles with coiled wire and magnetizing the axles? Doing this, as you accelerate the axles turn faster and faster creating bigger and bigger current. The increasing current could produce and increasing magnetic force that can help propel the vehicle.
Then when the driver releases the "throttle" the vehicle switches this system to a charging system to charge the battery.
I'm curious to figure this stuff out so maybe it'll be possible to buy an electric Colt, for example, and outfit it with a "supercharging" system.
edit - The chevy is a little smarter than existing hybrids like the prius, it runs on the electric motor all the time and uses the IC engine to power it when needed, this makes the drive train simpler.
The main difference with the lotus is likely to be the batteries, the ones in the chevy need to built for a mass market - taking into account price, lifetime, reliability etc. The lotus battery technology isn't published but it's going to be a bit more specialised.
I'm not sure I believe the 10min chargeup, I suspect that some marketing spin is involved, it's a 10min top-up.
I have heard that the Tesla (an obvious tribute to Nikola) is quite a performer.
http://www.teslamotors.com/
...and not bad looking.
I see. So this Lotus car is 4-6 times more powerful because it has 4 motors rather than 1 like the Volt?
Why couldn't these makers harness the vehicle's momentum and turn that into electric energy too? I'm talking about while accelerating.
You cannot get more energy out of a system than you put into it. PERIOD! Whatever energy you get out of whatever system you use to get it will have come from the battery...and you won't get all of it back.
In a sense, they are harnessing the momentum when they use generation in the motor to slow the car and charge the battery (taking the place of scrubbing off the kinetic energy by heating the brake discs)...but that only works in deceleration.
I remember now. Putting 4 electric motors parallel, all 4 will get equal amounts of current (current takes path of least resistance). So the differences in power of the cars is in the battery.
Do inductors produce an opposing force to a magnetic field moving through it? This area I forgot. I see the energy stored in an inductor is equal to the amount of work required to get the current moving through it. This is why this inductor effect isn't used during acceleration?
No, but it might be lighter since it doesn't have a transmission, differential and drive shafts. As you said the power is limited by how much you can take from the battery.
It's not really correct to call it an inductor.
An electric motor also behaves as a generator. If you put electricity in it turns, alternatively if you turn it you get electricity out. Exatcly the same motors are used to charge the batteries under breaking. All the brake pedal does is reverse the connections to the battery.
Nikola Tesla had a 1930 Pierce Arrow which he demonstrated. The car had an electric engine and a box of vacuum tubes and antennae which pulled broadcast energy to power it. Like many of Tesla's inventions, how it was done remains a mystery. (Note, please, this is not a "water car.")
Reading his biographies (one of which claimed he must be an alien), most of his work defied conventional wisdom. He invented the Radio, (Marconi was denied the patent - it belongs to Tesla), Alternating current, almost all the energy-generating dynamos and generators in use today, and more inventions than any inventor I've studied. Edison hated Tesla, because Tesla was the superior inventor. When Tesla won the bid to power the Chicago World's Fair with AC rather than DC, Edison refused to let Tesla used any of his light bulbs, so Tesla invented a light bulb virtually overnight that did not infringe on any of Edison's work.
His Wardenclyffe Tower was never finished, because J.P.Morgan realized belatedly, that free energy powering transportation, lighting, and communication that did not go through any meter would not make him any money. After Westinghouse reneged on the handshake agreement to pay Tesla for his inventions, Tesla rarely drew out his inventions in any manner that could be stolen. He invented things that he never built, but after getting them straight in his mind went on to make second and third generation inventions based on his unpatented thought. Many lesser inventors and engineers backward-engineered his inventions and crafted the inventions he had perfected, taking the inventions as their own and not giving him credit.
That Pierce Arrow would come in handy today, wouldn't it?
FAQ: Question on electric cars coming in the future
What are the benefits of electric cars compared to traditional gasoline cars?
Electric cars have several benefits, including being more environmentally friendly and producing no emissions. They also have lower operating costs, require less maintenance, and can be powered by renewable energy sources.
Will electric cars eventually replace traditional gasoline cars?
It is likely that electric cars will become more prevalent in the future, but it is unlikely that they will completely replace traditional gasoline cars. Instead, there will likely be a mix of both types of vehicles on the road.
How long does it take to charge an electric car?
The charging time for an electric car depends on the type of charger being used and the size of the car's battery. It can range from a few hours for a home charger to 30 minutes or less for a fast charger.
What advancements can we expect to see in electric car technology in the future?
As technology continues to improve, we can expect to see advancements in electric car batteries, allowing for longer driving ranges and quicker charging times. There may also be developments in autonomous driving technology and improvements in energy efficiency.
How will the increase in electric cars impact the environment?
Electric cars have the potential to significantly reduce emissions and improve air quality, as they produce no direct emissions. However, the environmental impact also depends on the source of the electricity used to power the cars. If it comes from renewable sources, the impact will be minimal, but if it comes from fossil fuels, it may not be as beneficial.
