Question on form of differential
In summary, the conversation discusses the equation p(uAx) / px = pu(Ax)/px + up(Ax)/px and its validity. The equation involves the use of the chain rule and the role of u as a function is clarified. The conversation also mentions the benefits of using LaTex for presenting mathematical problems.
Noone1982
83
My book says:
let p stand for partial, u is a function
How can it be valid?
Noone1982 said:
My book says:
First of all, what is u a function of? Second, did you mean A(x)?
u is just say xyz and Ax means A subscript x
It would help us all if you would take a few minutes to read through this thread . LaTex is really very easy and it makes it much easier to present problems such as yours.
[tex]\frac{\partial }{\partial x}\left( uA_{x} \right)\; =\; \frac{\partial u}{\partial x}\left( A_{x} \right)+u\frac{\partial A_{x}}{\partial x}[/tex]
To me, the right hand of the equation is saying the left hand twice rather than reworking it.
That's just the straight-up definition of the chain rule.
Thanks! :)
FAQ: Question on form of differential
What is the general form of a differential equation?
The general form of a differential equation is dy/dx = f(x,y), where y is the dependent variable, x is the independent variable, and f(x,y) is a function that relates the two variables.
What is the order of a differential equation?
The order of a differential equation is the highest derivative present in the equation. For example, if the equation contains only first derivatives, it is a first-order differential equation.
Can a differential equation have multiple solutions?
Yes, a differential equation can have multiple solutions. In most cases, the solution will have one or more constants that can take on different values, resulting in different solutions.
How do you solve a differential equation?
The method for solving a differential equation depends on its type and order. Some common methods include separation of variables, substitution, and using integrating factors. It is important to choose the appropriate method based on the equation.
Are differential equations used in real-world applications?
Yes, differential equations are used in many real-world applications, including physics, engineering, economics, and biology. They are particularly useful for modeling systems that change over time, such as population growth, heat transfer, and chemical reactions.
