Question on Laplace eq. in a ball
In summary, the forum post discusses the Laplacian in spherical coordinates and its solution, which is a function of r, θ, and φ that satisfies the equation ##\nabla^2 u(r,\theta,\phi)=0##. The solution must also satisfy certain boundary conditions, leading to a modified form of the solution ##R=r^{(n+1/2)}##.
yungman
5,755
292
For ##\nabla^2 u(r,\theta, \phi)=0##, ##u(r,\theta, \phi)=r^{n}Y_{nm}(\theta,\phi)##.
But I have issue with this, for spherical coordinates:
[tex]\nabla^2u=\frac{\partial^2{u}}{\partial {r}^{2}}+\frac{2}{r}\frac{\partial{u}}{\partial {r}}+\frac {1}{r^{2}}\left(\frac{\partial^2{u}}{\partial {\theta}^2}+\cot\theta\frac{\partial{u}}{\partial {\theta}}+\csc\theta\frac{\partial^2{u}}{\partial {\phi}^2}\right)[/tex]
Let ##u=R(r)Y(\theta,\phi)## where ##Y(\theta,\phi)## is the spherical harmonics.
[tex]\Rightarrow\; r^{2}\frac{\partial^2{R}}{\partial {r}^{2}}+2r\frac{\partial{R}}{\partial {r}}-\mu R=0[/tex]
and
[tex]\frac{\partial^2{Y}}{\partial {\theta}^2}+\cot\theta\frac{\partial{Y}}{\partial {\theta}}+\csc^2\theta\frac{\partial^2{Y}}{\partial {\phi}^2}+\mu Y=0[/tex]
For Euler equation: ##r^{2}\frac{\partial^2{R}}{\partial {r}^{2}}+r\frac{\partial{R}}{\partial {r}}-\mu R=0## where ##\mu=n^2##. and the solution is ##R=r^n##.
Here, because of the condition, only ##\mu=n(n+1)## is used for bounded solution.
[tex] r^{2}\frac{\partial^2{R}}{\partial {r}^{2}}+2r\frac{\partial{R}}{\partial {r}}-\mu R=r^{2}\frac{\partial^2{R}}{\partial {r}^{2}}+2r\frac{\partial{R}}{\partial {r}}-n(n+1) R=r^{2}\frac{\partial^2{R}}{\partial {r}^{2}}+r\frac{\partial{R}}{\partial {r}}-(n+1/2)^2R[/tex]
Which gives
[tex]R=r^{(n+1/2)}[/tex]
What have I done wrong?
Hello,
Thank you for sharing your thoughts on this topic. It seems like you have a good understanding of the mathematics involved, but there are a few things that may have led to your confusion.
Firstly, the equation you have written for the Laplacian in spherical coordinates is correct, but it is not the one that is being used in the forum post. In the post, the Laplacian is written as ##\nabla^2 u(r,\theta,\phi)=0##, which means that the solution is a function of r, θ, and φ that satisfies this equation. This is different from the equation you have written, where the Laplacian is acting on a function that is a product of two separate functions of r and θ, respectively. This difference is important because it means that the solution to the forum post equation will not necessarily be of the form ##R(r)Y(\theta,\phi)##.
Secondly, in your solution for the Euler equation, you have correctly identified ##\mu=n^2##, but you have not taken into account that the solution must also satisfy the boundary conditions of the problem. In this case, the boundary conditions are that the solution must be bounded at the origin and must approach zero as r approaches infinity. This means that the solution cannot simply be ##R=r^n##, as this would not satisfy the boundary conditions. Instead, the solution must be a modified version of this, as you have correctly stated in your last equation.
Overall, it seems like you have a good understanding of the mathematics involved, but you may have made some small mistakes in your calculations and interpretation of the problem. I hope this helps to clarify things for you. Keep up the good work!
FAQ: Question on Laplace eq. in a ball
1. What is the Laplace equation in a ball?
The Laplace equation in a ball is a partial differential equation that describes the distribution of a scalar field within a spherical region. It is often used in problems involving electrostatics, fluid dynamics, and heat transfer.
2. What are the boundary conditions for the Laplace equation in a ball?
The boundary conditions for the Laplace equation in a ball depend on the specific problem being solved. In general, they involve specifying the values of the scalar field on the surface of the ball, as well as any constraints on the behavior of the field at the center of the ball.
3. How is the Laplace equation in a ball solved numerically?
There are several numerical methods that can be used to solve the Laplace equation in a ball, including finite difference methods, finite element methods, and spectral methods. The choice of method depends on the specific problem and the desired level of accuracy.
4. What are some applications of the Laplace equation in a ball?
The Laplace equation in a ball has numerous applications in science and engineering. It is commonly used in the study of heat transfer, fluid flow, and electrostatics. It is also often used in the analysis and design of spherical objects, such as lenses and mirrors.
5. What are some techniques for solving the Laplace equation in a ball analytically?
In general, the Laplace equation in a ball does not have a closed-form analytical solution. However, there are some special cases where solutions can be found using techniques such as separation of variables and integral transforms. These solutions are often used as benchmarks for testing numerical methods.
