Question on Mass transfer coefficient (Sc Number)
In summary, the mass transfer coefficient for natural convection from a rock salt crystal, assuming flow over a horizontal cylinder of length 2cm and diameter 0.5cm, can be calculated using the equation Sh = C2 (Gr.Sc)^p. The Sc number can be found by dividing the kinematic viscosity by the diffusivity, which should be the diffusivity at the maximum concentration of salt in the aqueous solution. The Grashof number should be calculated using the densities of the bulk aqueous solution and the surface layer, divided by the film density and multiplied by the kinematic viscosity at the film density.
sero2000
27
What is the mass transfer coefficient for natural convection from rock salt (assume flow is over a horizontal cylinder (salt crystal) of length 2cm, diameter 0.5cm).
Given:
Temperature = 24degrees
Density of salt 2165kg/m^3
Density of mixture when salt concentration is saturated = 1310kg/m^3
Sh = C2 (Gr.Sc)^p
Sc = Kinematic viscosity/Diffusivity
I am having trouble finding the correct diffusivity to use for the Sc number. I have previously calculated the maximium concentration of the salt in the water. Which is 6kmol/m^3 and i also a table of values for the diffusivity for different solute concentrations.
So the qn is do i use the maximium concentration of salt to find my diffusivity or do I have to use the actual concentration? Thats because I am not given the volume of the solvent even though i am able to find the mass of the solute by finding the volume of solute x the density.
A great big load of thanks in advance.
I assume what you mean by maximum concentration is the concentration of an aqueous solution saturated with salt. That is certainly the concentration at the rock salt interface. This is the appropriate diffusivity value to use. I also assume that, far from the rock salt, the concentration of the salt in the solution is zero.
Chet
Chet
Hi there, thanks!. Another question though, for the grashof number, I am given the formula as
Gr = [g ( Densitybulk - Densitysurface)]/film density x Kinematic viscosity.
So I found the density of the bulk which is 1000kg/m^3 and the density of the surface layer which is 2156kg/m^3. For the film density I just took the sum of the 2 densities and divided by 2.
Question is, for the kinematic viscosity, do i use the dynamic viscosity of the bulk fluid at 24°C which is 855x10^-6 and divide by it's density which is 1000kg/m^3 or do I divide it by the film density?
You don't use the density of the solid salt. You use the density of the saturated aqueous salt solution.
I would divide by the film density. What does your book recommend? It doesn't matter much because, if I remember correctly, p = 0.25.
Chet
Chet
Is there a reason we use the saturated aqueous salt solution density? Does it have something to do with the interface?
My notes don't really say much about all these. It just mentions use properties at the film density. I borrowed a textbook from the library but it does not explain much as well. I just find it weird that I am taking the dynamic viscosity of water divided by the density of something that is not water.
The equations you are using apply to mass transfer in the liquid phase.
How different is the viscosity of saturated salt water from the viscosity of pure water?
FAQ: Question on Mass transfer coefficient (Sc Number)
What is the mass transfer coefficient?
The mass transfer coefficient is a measure of how quickly a substance moves from one phase to another in a mass transfer process, such as diffusion or convection.
How is the mass transfer coefficient calculated?
The mass transfer coefficient can be calculated using various equations, depending on the specific mass transfer process being studied. For example, for diffusion, the mass transfer coefficient can be calculated using Fick's law of diffusion.
What is the significance of the Sc Number in mass transfer?
The Sc Number, or Schmidt Number, is a dimensionless number that represents the ratio of momentum diffusivity to mass diffusivity in a fluid. It is used to characterize the relative importance of diffusion and convection in mass transfer processes.
How does the Sc Number affect mass transfer?
The Sc Number can affect the rate of mass transfer by influencing the relative contribution of diffusion and convection. A lower Sc Number indicates a higher rate of mass transfer due to a higher diffusion coefficient, while a higher Sc Number indicates a lower rate of mass transfer due to a lower diffusion coefficient.
What factors can affect the Sc Number?
The Sc Number can be affected by various factors, such as temperature, pressure, and the properties of the substances involved in the mass transfer process. It can also be influenced by the geometry and conditions of the system in which the mass transfer is taking place.
