Question on MOSFET modes of operation
In summary, the three modes of operation for a MOSFET are cutoff, triode, and saturation. These modes are determined by the voltage applied to the gate, with lower voltages resulting in cutoff mode, intermediate voltages resulting in triode mode, and higher voltages resulting in saturation mode. A MOSFET can only operate in one mode at a time, and its behavior is controlled by the gate voltage, allowing it to be used in various electronic circuits for switching, amplification, and voltage control.
Helena Wells
125
TL;DR Summary
I just came across some videos on youtube which aren't correct or so I think
I have studied the modes of the MOSFETs from this site https://www.electronics-tutorials.ws/transistor/tran_6.html however in many videos such as this : they don't agree with each other.Which is correct and which isnt?
There are many videos on the internet that get wrong.
Videos are usually a waste of time.
Refer to wikipedia for introductory information.
Understanding an electronic component, so you can use it in a design, does not require you understand the process used in it's manufacture.
Likes Klystron and Averagesupernova
FAQ: Question on MOSFET modes of operation
1. What are the different modes of operation for a MOSFET?
The three main modes of operation for a MOSFET are the cut-off, triode, and saturation modes. In the cut-off mode, the MOSFET acts as an open switch and no current flows between the source and drain. In the triode mode, the MOSFET acts as a variable resistor and the current between the source and drain is controlled by the gate voltage. In the saturation mode, the MOSFET acts as a closed switch and the current between the source and drain is at its maximum.
2. How does the gate voltage affect the MOSFET's mode of operation?
The gate voltage is the main control parameter for the MOSFET's mode of operation. When the gate voltage is lower than the threshold voltage, the MOSFET is in the cut-off mode. As the gate voltage increases, the MOSFET enters the triode mode and the current between the source and drain increases. Once the gate voltage reaches a certain value, called the pinch-off voltage, the MOSFET enters the saturation mode where the current between the source and drain is at its maximum.
3. What is the difference between enhancement and depletion mode MOSFETs?
The main difference between enhancement and depletion mode MOSFETs is the presence or absence of a channel between the source and drain when no voltage is applied to the gate. In an enhancement mode MOSFET, there is no channel and the MOSFET is normally off. When a positive gate voltage is applied, a channel is created and the MOSFET turns on. In a depletion mode MOSFET, there is a channel present when no voltage is applied to the gate and the MOSFET is normally on. When a negative gate voltage is applied, the channel is depleted and the MOSFET turns off.
4. What is the importance of the MOSFET's mode of operation in circuit design?
The MOSFET's mode of operation is crucial in circuit design as it determines the behavior of the MOSFET and the overall circuit. By controlling the gate voltage, the MOSFET can be used as a switch or a variable resistor, allowing for precise control of current and voltage in a circuit. Understanding the different modes of operation also helps in selecting the appropriate MOSFET for a specific application.
5. Can a MOSFET operate in multiple modes simultaneously?
Yes, a MOSFET can operate in multiple modes simultaneously. For example, in a switching circuit, the MOSFET may transition from cut-off to saturation mode as the gate voltage changes. However, it is important to design the circuit in a way that only one mode dominates at a given time to avoid instability and potential damage to the MOSFET.
