I Question on proof ##\Lambda^{\perp}(AU) = U^{-1} \Lambda^{\perp}(A)##
Peter_Newman
Say we have as special lattice ## \Lambda^{\perp}(A) = \left\{z \in \mathbf{Z^m} : Az = 0 \in \mathbf{Z_q^n}\right\}##. We define ##U \in \mathbf{Z^{m \times m}}## as an invertible matrix then I want to proof the following fact:
$$ \Lambda^{\perp}(AU) = U^{-1} \Lambda^{\perp}(A) $$
My idea:
Let ##y \in \Lambda^{\perp}(A)## that is ##y \in Az = 0##, now ##U^{-1}y = (U^{-1}Az = 0) \in U^{-1}\Lambda^{\perp}(A)## and let ##y' \in \Lambda^{\perp}(AU)## that is ##y' \in AUz = 0##, this implies ##y \in y'## which shows one direction.
I hope that this is not too simple thinking and therefore I am interested in your opinions.
Your notation is confusing. You don't mean y \in Az = 0 etc.; you mean y \in \{ z \i n\mathbb{Z}^m: Az = 0 \}, but you can just write "Let y \in \Lambda^{\perp}(A). Then Ay = 0."
The central point is that if Ay = 0 then we can write Ay = AUU^{-1}y so that U^{-1} y \in \Lambda^{\perp}(AU); hence U^{-1}\Lambda^{\perp}(A) \subset \Lambda^{\perp}(AU). But conersely, if AUy = 0 then Uy \in \Lambda^{\perp}(A) so that <br /> U\Lambda^{\perp}(AU) \subset \Lambda^{\perp}(A). But if U is invertible then U(B) = C \Leftrightarrow B = U^{-1}(C) for any subsets B and C of \mathbb{Z}^m. The result follows.
The requirement that a matrix have integer entries and have an inverse with integer entries is somewhat restrictive; the only ones which come to mind are \pm I and matrices which permute the standard basis vectors.
Likes Peter_Newman
Thanks for your great help @pasmith ! Yes my notation is a bit confusing and also kept myself from seeing the result directly.
In the second part, you could have done the following: ##y \in \Lambda^{\perp}(AU)## then ##AUy = 0##, then ##Uy \in \Lambda^{\perp}(A)## which implies ##y \in U^{-1}\Lambda^{\perp}(A)## , right? The "advantage" would be that then ##\Lambda^{\perp}(AU) = U^{-1} \Lambda^{\perp}(A)## is directly recognizable, but this is more or less a rewriting.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
