Question on relationship between drift velocity and resistance
In summary, there is not a direct relationship between a charge carrier's drift velocity and a material's resistance. The cross sections of particles in the material do not directly affect resistance, but rather the average time it takes for each electron to collide. This is related to the drift velocity in the free electron gas model or the electron mobility, which is inversely related to resistance. More information on electron mobility can be found at the provided link.
arjose
Is there a relationship (or equation) between a charge carrier's drift velocity through a conducting material and that material's resistance? I'm trying to reconcile the idea that drift speeds are bigger when cross sections are smaller and the idea that resistance is bigger when cross sections are smaller. How can the drift speed be faster in smaller cross sections when resistance is bigger? I have this idea that drift speeds are proportional to current and inversely proportional to resistance. Am I right?
it is not quite appropriate to think of cross sections of particles in a material to be directly related to the resistance. the number density will come into play and without a clear knowledge of the composition, it will not be possible to formulate resistance. Instead one thinks of the average time it takes for each electron to collide, and this is related to the drift velocity in the free electron gas model. More commonly, one defines a quantity called the electron mobility, and this is related directly to the conductivity, hence inversely related to resistance of the material. here's more information on electron mobility:
http://en.wikipedia.org/wiki/Electron_mobility
Related to Question on relationship between drift velocity and resistance
1. What is drift velocity?
Drift velocity is the average velocity at which electrons or charged particles move in a particular direction in a conductive material, due to the application of an electric field.
2. What is resistance?
Resistance is the measure of how much a material or device impedes the flow of electric current. It is caused by collisions between electrons and atoms in a material.
3. How are drift velocity and resistance related?
Drift velocity and resistance are inversely proportional to each other. This means that as drift velocity increases, resistance decreases, and vice versa.
4. What factors affect the relationship between drift velocity and resistance?
The relationship between drift velocity and resistance is affected by the material's conductivity, temperature, and the strength of the electric field applied.
5. Why is the relationship between drift velocity and resistance important?
The relationship between drift velocity and resistance is important because it helps us understand how electric current flows in a material and how different factors can affect its movement. This knowledge is crucial in designing and optimizing electronic devices and circuits.
