Question On Resonance- Intuitive feeling required
  • Thread starter jrm2002
  • Tags
    Resonance
In summary, resonance occurs when a periodic excitation matches the natural frequency of a structure, causing it to vibrate strongly. This can be demonstrated through experiments with a flexible structure or tuning forks. A building's response time, determined by factors such as its size and material properties, can be equated to its resonant frequency. Diving off a springboard can provide a physical demonstration of this concept.
jrm2002
57
I am not able to intuitively sense the concept of resonance.
Let us say we have a building having a fundamental frequency of 5.5 Hertz .
If the ground moved to and fro(during an earthquake) with a frequency of 5.5 Hertz, the building would vibrate strongly, or resonate.Right?
I am not able to sense the phenomenon of resonance intuitively---
IF the fundamental frequency of the ground and building are same, then the building would vibrate strongly.How to sense this intuitively??
jrm2002 said:
I am not able to intuitively sense the concept of resonance. Let us say we have a building having a fundamental frequency of 5.5 Hertz. If the ground moved to and fro(during an earthquake) with a frequency of 5.5 Hertz, the building would vibrate strongly, or resonate. Right?
Right. If a periodic excitiation (energy source) oscillates at the structures natural frequency, then vibration or oscillation may be excited, i.e. the driving force will excite one of the natural modes of vibration in the structure. This is somewhat like constructive interference.
jrm2002 said:
I am not able to sense the phenomenon of resonance intuitively--- IF the fundamental frequency of the ground and building are same, then the building would vibrate strongly.How to sense this intuitively??
Perhaps get a long plastic ruler, hold it upright (vertical) and slowly push (deflect) the top and then slowly release the contact (reduce the deflection). Note the response. The repeat but increase the speed (frequency) of the deflection. Try to match the natural frequency.
Alternatively, construct a flexible structure with a known natural frequency on a movable platform. Slowly move the platform backwards and forwards (oscillate) and note the response. Start below the natural frequency, then increase frequency up to the natural frequency and not the change in response.
if you have these, use two tuning forks of the same frequency and hit one. then place that one next to, but not touching, the other and listen closely to the sound of the "unhit" one because you will hear the soft tone of it because resonance caused it to vibrate.
When you apply a force to, using your example, a building, it can only respond with a certain speed, which, in the case of a building depends on a whole host of factors, including the dimensions of the building and the material properties such as Young's modulus.
If the applied force varies at exactly the same speed as the buildings 'response time' then the force and the movement of the building remains in phase, i.e. the force always pushes in the same direction that the building is moving, and the amplitude of the oscillation (assuming the driving force is oscillatory of course) will be a maximum. We can equate this 'speed of response' of the building to a characteristic frequency we call the resonant frequency.
If we drive the oscillator far from resonance, then the force will spend much of its time opposing the movement of the building, hence the reduced amplitude.
This argument of course does not just apply to mechanical oscillators, but electrical, optical etc...
Claude.
jrm: to get a feel for resonance, go down to your local swimming pool. And practice some diving off the springboard.
FAQ: Question On Resonance- Intuitive feeling required
What is resonance?
Resonance is a phenomenon that occurs when an object vibrates at its natural frequency in response to an external force. This results in a larger amplitude of vibration and a transfer of energy between the two objects.
How do you determine if resonance will occur?
Resonance can occur when the frequency of the external force matches the natural frequency of the object. To determine if resonance will occur, you can calculate the natural frequency of the object using its mass and stiffness, and compare it to the frequency of the external force.
What are some examples of resonance in everyday life?
Some common examples of resonance include the vibration of a guitar string, the sound produced by blowing across the top of a bottle, and the swinging of a pendulum in a clock.
How can resonance be beneficial?
Resonance can be beneficial in a variety of ways. In music, it allows for the production of clear and amplified sound. In engineering, it can be used to improve the efficiency of machines. In medicine, resonance imaging (MRI) uses the principles of resonance to create detailed images of the body.
Can resonance be harmful?
Yes, resonance can be harmful in certain situations. For example, if the natural frequency of a bridge matches the frequency of strong winds, it can result in destructive vibrations known as resonance disaster. In addition, repeated exposure to high levels of sound at its natural frequency can cause damage to the human body.
