Question on Tachyon Correlator (Green Schwarz Witten)
  • Thread starter earth2
  • Tags
    Tachyon
In summary: You are trying to derive the M-tachyon correlation function from the two equations 7.A.12 and 7.A.22. However, you are having trouble understanding the factor that appears on the right-hand side of the first equation. This factor is caused by the exponent of z in the zero-mode part of the tachyon vertex operator. To solve this problem, you need to look back at the equation that defines the zero-mode part of the tachyon vertex operator. This equation is found in eq (7.1.6). The 2nd term in this equation computes the zero-mode contribution to a modified version of 7.A.12. You can
earth2
86
I'm reading through chapter 7 of Green-Schwarz-Witten and I have a problem with the derivation of the M-tachyon correlation function. Basically I'm trying to get 7.A.17 from 7.A.12 and eq 7.A.22 in the appendix of the first volume.
Basically I want to prove:
$$\langle\frac{V(k_1,y_1)...V(k_M,y_M)}{y_1...y_M}\rangle=\prod_{i < j}(y_i-y_j)^{k_ik_j}$$
with $$V(k_i,y_i)=e^{ik_iX(k_i)}$$
If I try to get this by just plugging everything into $$\langle:e^{A_1}:...:e^{A_M}:\rangle=e^{\sum_{i<j}<A_iA_j>}$$ using $$\langle X(y_i)^{\mu}X(y_j)^\nu\rangle=-\eta^{\mu\nu}log(y_i-y_j)$$ I somehow still have the $$\frac{1}{y_1...y_M}$$ factor in the formula above existing on the right hand side of the first equation. How is that canceled in this approach? I don't see it.
More specifically I have
$$\langle\frac{V_1...V_M}{y_1...y_M}\rangle=\frac{1}{y_1...y_M}\langle V(k_1,y_1)...V(k_M,y_M)\rangle=\frac{1}{y_1...y_M}e^{(\sum_{i<j}k_i^\mu\langle X_iX_j\rangle k_j^\nu)}$$ $$=\frac{1}{y_1...y_M}e^{(\sum_{i<j}k_ik_jlog(y_i-y_j))}=\frac{1}{y_1...y_M}\prod_{i<j}(y_i-y_j)^{k_ik_j}$$
which is the result I want to have up to that nasty prefactor that I can't make sense of.
Edit: I also posted this on stackexchange but didnt get an answer :(
Btw, this is not a homework question. I'm reading it on my own.
You have to look back at eq (7.1.6), where the zero-mode part of the tachyon vertex operator was computed. The ##\pm 1## in the exponent of ##z## comes from normal-ordering the zero mode operators ##\hat{x}^\mu, \hat{p}^\mu##. It is precisely this exponent that leads to the factors of ##y_i## in the n-pt function.
Hi fzero,
Thanks for your answer but I'm not sure I understand it in the context of the equations above. Would you be so could to make it more precise w.r.t. the formulae I used above. That would be very nice since I'm banging my head against this for a while now. Moreover, this point is important for all the computations in this chapter after that...so i would really like to understand it.
To fzero :
The question of earth2 is in fact, how to obtain [itex]7.A.17[/itex] from [itex]7.A.12[/itex] and [itex]7.A.22[/itex] (appendix of the first volume), because you have a curious overall term [itex]y_1...y_M[/itex]
Thanks Trimok for clearing that up :) As mentioned on phys stackexchange, I would like to understand this, since GSW say in the appendix that getting 7.A.17 is possible from 7.A.12 and 7.A.22... :)
If we really want to understand this factor, then we should restore the factors of ##\alpha'## and note that it is
$$\prod_i y^{\alpha' k_i^2 }.$$
GSW refer to 7.A.22 as a mnemonic to recover 7.A.17, but don't actually tell you what value of ##\lambda## you need. It seems that the appropriate version of 7.A.22 is something like
$$\langle X^\mu (y_i) X^\nu (y_j) \rangle = - 2\alpha' \eta^{\mu\nu} \log (y_i-y_j) - 2\alpha' \eta^{\mu\nu} \delta_{ij} \log y_i. $$
The 2nd term computes the zero-mode contribution to a modified version of 7.A.12, which is something like
$$\begin{split}
\langle :e^{A_1}: :e^{A_2}: \cdots :e^{A_M}: \rangle & = \exp \left[ \frac{1}{2} \sum_{i,j} \langle A_i A_j \rangle \right] \\
& = \exp \left[ \sum_{i<j} \langle A_i A_j \rangle \right] + \exp \left[ \frac{1}{2} \sum_i \langle A_i A_i \rangle \right] .
\end{split}~~~(*) $$
The term in the correlator gives something like
$$ \exp \left[ 2\alpha' \sum_{i<j} k_i\cdot k_j \log y_i + \alpha' \sum_i k_i^2 \log y_i \right]
= \prod_i y_i ^{\alpha'k_i^2} \prod_{i<j} y_i^{2\alpha' k_i\cdot k_j }, $$
which should be compared with 7.A.16.
This isn't a clean-cut derivation, since (*) introduces some divergences from the nonzero mode part that must be regularized away. For this reason, it is advisable to look at Polchinski, who is more careful about how to deal with the normal ordering regularization in the CFT correlators, as well as in the discussion of zero-modes and momentum conservation.
Likes 1 person
Thanks fzero! Since both - Trimok and you - suggested to look at Polchinksi I will do so :) To the Library...!
Related to Question on Tachyon Correlator (Green Schwarz Witten)
1. What is a tachyon correlator?
A tachyon correlator is a mathematical quantity that describes the relationship between tachyon fields, which are hypothetical particles that travel faster than the speed of light. It is closely related to the concept of a tachyon condensate, which is a collection of tachyons that may have a stabilizing effect on the theory in which they exist.
2. Who developed the concept of tachyon correlators?
The concept of tachyon correlators was first introduced by physicists Michael Green, John Schwarz, and Edward Witten in their groundbreaking 1987 paper "Superstring Theory". In this paper, they proposed a new type of string theory that included tachyons as fundamental particles.
3. How do tachyon correlators relate to string theory?
In string theory, tachyon correlators are used to describe the interactions between tachyon fields and other particles. They are an important tool for understanding the dynamics of string theory and have been used to make predictions about the behavior of tachyons in various scenarios.
4. What is the significance of tachyon correlators in physics?
Tachyon correlators are significant in physics because they help us understand the behavior of tachyons, which are a fundamental part of many theoretical frameworks, such as string theory and certain cosmological models. They also provide a way to test the validity of these theories by making predictions about the behavior of tachyons that can be observed in experiments.
5. Are there any practical applications of tachyon correlators?
At this point, there are no known practical applications of tachyon correlators. They are mainly used as a theoretical tool for understanding and testing different aspects of string theory and other theoretical models. However, as our understanding of these concepts continues to evolve, it is possible that tachyon correlators may have practical applications in the future.
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Beyond the Standard Models
