Question on the relationship between intensity of sound, amplitude and 1/r^2
In summary, the conversation discusses the relationship between intensity, power, and amplitude of sound waves emitted from a speaker. It is concluded that as distance increases, the intensity at a specific point decreases, causing a decrease in power and amplitude. The total power from the source remains constant.
aznking1
Suppose sound wave is emitted uniformly in all directions by a speaker.
At a distance of 1.1m, the amplitude of it sound is 1.2x10^-8m
What is the amplitude of sound at a distance of 1.7m?
What I'm confused is why does the amplitude of sound change? Isn't intensity = Power/Area? So at a greater distance, it just means that intensity is lowered. But power from a source is always constant isn't that right? And since power is proportional to amplitude squared, why does the amplitude decrease? am i missing out something?
The answer is 7.8x10^-9 using the relationship of intensity proportional to amplitude^2 and 1/r^2 if you are curious.
Lower intensity at some specific point corresponds to a lower amplitude at that point. Meters as unit looks odd, I would expect Pa (pressure), but that should be irrelevant.
Constant in which way? I think you mean the total power here.
Ahh okay. I think i get it now after reading your post and thinking for so many hours.
Firstly, the formula intensity = power/area gives the power at a particular point. If we were to sum all the points ( surface area of a sphere), we would get the total power of the source, which is always constant
Hence, as distance increases, the intensity at a point decreases, meaning power at the specific point decreases, and so amplitude decreases, as you have mentioned.
Thank you! now i can get a good night's sleep haha... assuming i am correct
That is right.
Small issue: "Power at a specific point" is not meaningful. Intensity is. If you integrate that, you get a power.
I can explain the relationship between intensity of sound, amplitude, and 1/r^2 to help clarify your confusion. First, let's define some terms:
- Intensity of sound: This refers to the amount of sound energy passing through a unit area per unit time. It is measured in watts per square meter (W/m^2).
- Amplitude: This is the maximum displacement of a wave from its equilibrium position. In the case of sound waves, it is the maximum displacement of air molecules from their resting position.
- Distance (r): This refers to the distance between the sound source and the point at which the sound is being measured.
Now, let's consider the relationship between these three variables. As you correctly mentioned, intensity is equal to power (the rate at which energy is transferred) divided by area. This means that as the distance from the sound source increases, the intensity decreases because the same amount of energy is spread out over a larger area. This is known as the inverse square law, which states that the intensity of a sound wave is inversely proportional to the square of the distance from the source (1/r^2).
Now, let's consider the relationship between intensity and amplitude. Intensity is directly proportional to the square of the amplitude. This means that as the amplitude of a sound wave increases, the intensity also increases. However, this relationship only holds true if the distance from the sound source remains constant. As we established earlier, as the distance from the sound source increases, the intensity decreases due to the inverse square law. Therefore, even if the amplitude of the sound wave remains constant, the intensity will decrease as the distance increases.
In summary, the amplitude of a sound wave does not change, but the intensity does change as the distance from the source increases. This is due to the inverse square law, which takes into account both the amplitude and distance from the source. So at a distance of 1.7m, the amplitude of the sound wave will be 7.8x10^-9m, which is lower than the amplitude at 1.1m due to the decrease in intensity caused by the increase in distance. I hope this helps clarify the relationship between intensity, amplitude, and 1/r^2.
Related to Question on the relationship between intensity of sound, amplitude and 1/r^2
1. What is the relationship between intensity of sound and amplitude?
The intensity of sound is directly proportional to the square of the amplitude. This means that as the amplitude increases, the intensity of sound also increases by a factor of the square of the amplitude.
2. How does the distance from the source affect the intensity of sound?
The intensity of sound decreases as the distance from the source increases. This is known as the inverse square law, which states that the intensity of sound is inversely proportional to the square of the distance from the source.
3. Can the intensity of sound be measured?
Yes, the intensity of sound can be measured using a decibel meter. This device measures the sound pressure level and converts it to a decibel value, which is a unit used to represent the intensity of sound.
4. How does the intensity of sound affect hearing?
Exposure to high intensity sounds can cause damage to the delicate structures in the ear and can result in hearing loss. It is important to protect your ears from loud sounds and to limit exposure to high intensity sounds.
5. How does the relationship between intensity of sound and 1/r^2 apply in real-life situations?
The inverse square law can be observed in many real-life situations, such as standing further away from a loudspeaker at a concert, where the sound intensity decreases the further you are from the source. It also applies to other forms of energy, such as light and gravity.
14K
