Question on the representation of Poincare algebra generators on fields
In summary, Polyrhythmic's derivation of the momentum operator differs from that of Maggiore by a minus sign, which leads to a incorrect result for the momentum and energy operators.
alexgs
23
Hi,
I am working through Maggiore's QFT book and have a small problem that is really bothering me.
It involves finding the representation of the Poincare algebra generators on fields. I always end up with a minus sign for my representation of a translation on fields compared to Maggiore (and everyone else). Here's what I do that gets the wrong answer:
For the Poincare transformation [itex] x^\mu \rightarrow x'^\mu = x^\mu + a^\mu [/itex], Maggiore says that any field transforms as [itex] \phi'(x') = \phi(x) [/itex] (Eq. 2.106).
The representation of a Poincare group element is [itex] \exp(-i a_\mu P^\mu) [/itex] (Eq. 2.96). I assume this is an operator that acts on a field and gives you the transformed (primed) field.
For the infinitesimal translation by [itex] a^\mu [/itex] and at fixed [itex]x[/itex] (Eq. 2.107):
[tex] \delta_0\phi \equiv \phi'(x) - \phi(x) = \phi(x-a) -\phi(x) = (-a^\mu \partial_\mu \phi) (x) ,[/tex]
and, by definition of what a generator is, this must also be equal to
[tex] \delta_0\phi = \left(\exp(-i a_\mu P^\mu) \phi - \phi \right)(x) = (-i a_\mu P^\mu \phi)(x) .[/tex]
By equating these two expressions for [itex] \delta_0\phi [/itex] I find that the representation of the generator on fields is
[tex] P^\mu = -i \partial^\mu .[/tex]
But this disagrees with the usual result (Eq. 2.110) by a minus sign.
Can anyone tell me what I'm doing wrong? My definition still obeys all the required commutation relations but it gives the wrong answer for the momentum and energy operators (i.e. an extra minus sign).
Any thoughts are much appreciated.
Thanks!
[itex]δ_0ϕ=(exp(−ia_μP^μ)ϕ−ϕ)(x)=(−ia_μP^μϕ)(x).[/itex]
This is flawed. Eq. 2.108 and 2.109 give the correct derivation.
Hi Polyrythmic. Can you explain why what I did is flawed?
I agree that the line you quoted is where my derivation differs from Maggiore's by a minus sign, which leads to the difference in my result for [itex] P^\mu [/itex]. I do not understand Maggiore's Eq. 2.108, which I will copy here:
[tex] \phi'(x'-a) = \exp(-i(-a_\mu)P^\mu) \phi'(x') = \exp(i a_\mu P^\mu) \phi(x) .[/tex]
In that equation it looks like the operator [itex]P^\mu[/itex] is operating on the 4-vector [itex] x'[/itex] and not on the field. But it is my understanding that we are trying to find the representation of the Poincare group on the field. I.e. the operator [itex]P^\mu[/itex] should act on the field, transforming one function [itex] \phi [/itex] to another.
If you could provide a more complete explanation that would be great.
Thanks.
Well, let's begin by considering what we want. We want to find an expression for the momentum operator by considering infinitesimal translations for a scalar field that obeys
[tex]\phi'(x')=\phi(x).[/tex]
The infinitesimal translation is given by
[tex]x^\mu\rightarrow x'^\mu=x^\mu+\epsilon^\mu.[/tex]
In order to do that, we begin by defining the infinitesimal change of the fields, as given by Eq. 2.107:
[tex]δ_0ϕ≡ϕ'(x)−ϕ(x)=ϕ'(x'−\epsilon)−ϕ(x)=(−\epsilon_μ∂^μϕ)(x).[/tex]
Next, we want to find an expression for [tex]ϕ'(x'−\epsilon)[/tex] that uses the momentum operator, so that we can relate it to the partial derivative that appears in Eq. 2.107. We can do this by recognizing that the generator of translations is given by the exponential of the momentum operator. This generator acts on the field itself, as given by Eq. 2.108:
[tex]ϕ'(x'−\epsilon)=exp(−i(−\epsilon_μ)P^μ)ϕ'(x')=exp(i\epsilon_μP^μ)ϕ(x).[/tex]
The additional minus sign comes from the fact that we now have a translation into negative epsilon direction, as given in the leftmost part of the last equation.
We can now expand the exponential into a taylor series and cut it after the first order (since we're dealing with infinitesimal translations). Inserting into 2.107 immediately leads to the result.
I am still confused because it looks like the operator [itex] P^\mu [/itex] is transforming the coordinate, not the function, in Polyrhythmic's last equation. Forgive me for making things painfully explicit but perhaps someone can spot the exact source of my confusion if I write everything out as clearly as I can.
We have a transformation [itex]\exp(-i a_\mu P^\mu) [/itex] that takes a function [itex] \phi [/itex] and turns it into a function [itex] \phi' [/itex], which is related to [itex] \phi [/itex] by
[tex] \phi'(x+a) = \phi(x), [/tex]
for any value of [itex]x[/itex]. Physically, the transformation shifts the shape of the function in the direction of [itex]a[/itex]. I.e. if [itex]\phi[/itex] had a spike at [itex]x=0[/itex], [itex]\phi'[/itex] has a spike at [itex]x=a[/itex].
I also write this relation as
[tex] \phi' = \exp(-i a_\mu P^\mu) \phi, [/tex]
i.e. the object [itex][\exp(-i a_\mu P^\mu) \phi][/itex] is a function.
Plugging in any value of [itex]x[/itex],
[tex] \phi'(x+a) = [\exp(-i a_\mu P^\mu) \phi](x+a) = \phi(x). [/tex]
This last equality is a self-contained definition for [itex]P^\mu[/itex]: if we expand [itex][\exp(-i a_\mu P^\mu) \phi](x+a)[/itex] to first order in [itex]a[/itex] we get
\begin{eqnarray}
\phi(x) &=&[(1 -i a_\mu P^\mu) \phi](x+a) \\
&=& [\phi - i a_\mu P^\mu \phi](x+a) \\
&=& \phi(x+a) -(i a_\mu P^\mu \phi)(x+a) \\
&=& \phi(x) +a^\mu \partial_\mu\phi(x) -(i a_\mu P^\mu \phi)(x).
\end{eqnarray}
Matching terms proportional to [itex]a^\mu[/itex] gives
\begin{equation}
P^\mu = -i \partial^\mu,
\end{equation}
the wrong answer...
I also tried reproducing Polyrhythmic's last equation: I think we would agree that
[tex]\phi'(x'-\epsilon) = \phi'(x) = \phi(x-\epsilon) .[/tex]
If this is to equal [itex] \exp(-i (-\epsilon_\mu) P^\mu) \phi(x)[/itex], then it seems that the operator [itex]P^\mu[/itex] needs to act on the argument [itex]x[/itex]. I.e. it appears you are defining [itex]P^\mu[/itex] to do the following:
[tex] [\exp(-i (-\epsilon_\mu) P^\mu) \phi](x) = \phi(x-\epsilon).[/tex]
This equation should hold for any value of [itex]x[/itex] and [itex]\epsilon[/itex]. So try plugging in [itex]x \rightarrow x+a[/itex] and [itex] \epsilon \rightarrow -a[/itex]:
[tex] [\exp(-i a_\mu P^\mu) \phi](x+a) = \phi(x+a+a).[/tex]
But this is different from the third equation in this post.
What is going wrong? Hopefully, I've thrown enough of my thoughts out there for someone to be able to identify a misconception I have. I'm betting it has to do with definitions. Let me know if you have any thoughts on the matter.
But [itex]x \rightarrow x+a[/itex] is not compatible with [itex] \epsilon \rightarrow -a[/itex]. For [itex]x \rightarrow x+a[/itex], you have to set [itex] \epsilon \rightarrow +a[/itex], then everything is consistent.
Not sure what you mean by "compatible" and "consistent". If you are saying that the equality with the substitutions you mention is consistent with the third equation of my post I'm pretty sure that's not true. The reason I suggested the substitutions I did was so that the left hand sides would both be [itex][\exp(-i a_\mu P^\mu)\phi](x+a)[/itex]. But then the right hand sides are different ([itex]\phi(x)[/itex] vs. [itex]\phi(x+2a)[/itex]).
But forget about that for a moment. Just take a look at my last post up to the point I "find" [itex]P^\mu = -i \partial^\mu[/itex]. Can anyone spot the problem with that derivation?
Sorry, I got something wrong, disregard my last post. However:
I don't see how this contradicts anything I've written so far, it's correct. The operator on the left hand side of this equation shifts the field, which is originally at x+a, to its value at x+2a. This is correct.
This equation is false. The middle part is neither equal to the right nor the left. A negative exponent shifts the field in the positive direction.
Everything is correct. The algebra of the translation group does not allows you to distinguish between [itex]P^{\mu}[/itex] and [itex]-P^{\mu}[/itex], so the sign of [itex](a.P)[/itex] in the unitary operator
[tex]U(a)=\exp (ia_{\mu}P^{\mu}),[/tex]
is a matter of convention.
sam
sam
But once you have chosen a certain convention you have to stick with it, this is where the mistake in the OP's calculation lies, why he arrives at the "wrong" result.
Yes but, there is no "wrong" result. What he needs to know is “the action on fields is inverse to that on points” :
[tex]\left( T . \phi \right) (x) = \phi ( T^{-1}. x) \ \ (1)[/tex]
The meaningful quantity here is the value [itex]\phi (x)[/itex] that the field takes at a point. This should be invariant, i.e., the transformed field at the transformed point [itex](T . \phi ) ( \bar{x} ) \equiv ( T . \phi ) ( T . x )[/itex] should be the same as the original field at the original point [itex]\phi (x)[/itex]. Thus
[tex](T . \phi ) ( T . x) = \phi (x)[/tex]
Since [itex] x = T^{-1}\bar{x}[/itex], then
[tex](T . \phi ) (\bar{x}) = \phi ( T^{-1}. \bar{x})[/tex]
Since this is true for any point, we can rename the point by [itex]\bar{x} = x[/itex] and arrive at eq(1).
I agree, that's true.
Some basic questions:
When you write [itex](T.\phi)(x)[/itex] is this the same as [itex][\exp(-i a_\mu P^\mu)\phi](x)[/itex]? And if so, would [itex]T^{-1}.x = x-a[/itex] or [itex]x+a[/itex]?
If you can write [itex]T.\phi[/itex] in terms of [itex]P^\mu[/itex], is that enough to get the form of [itex]P^\mu[/itex] using samalkhaiat's Eq.1? If so, can someone write it out explicitly?
If [itex]P^\mu = +i\partial^\mu[/itex] then it seems
[tex] [\exp(-i a_\mu P^\mu)\phi](x) = \phi(x+a). [/tex]
Is this saying that the shape of the transformed field is shifted in the direction [itex]-a[/itex] compared to the original field? This seems to be the opposite of the convention where [itex]\phi'(x') = \phi(x)[/itex] and [itex]x \rightarrow x'=x+a[/itex]. There, the shape of [itex]\phi'[/itex] is shifted in the direction of [itex]+a[/itex].
As I told you before, your calculation was correct, and you are needlessly confusing yourself. Ok, forget about the text you are using and follow the simple stuff below;
Consider the following infinitesimal coordinates transformation
[tex]x \rightarrow g.x = x + a,[/tex]
and its inverse
[tex]x \rightarrow g^{-1}. x = x - a.[/tex]
According to Wigner, scalar field (which plays the role of “wave function” in here) transforms by (linear) unitary representation U of g. That is
[tex]\bar{\phi}(\bar{x}) = \left(U(g) . \phi \right) ( \bar{x}) = \phi (x),[/tex]
or, which is the same thing
[tex]\bar{\phi}(x) = \left(U(g) . \phi \right) (x) = \phi (g^{-1}. x). \ \ (1)[/tex]
Now, introduce some hermitian operator P and write
[tex]U(g) = \exp ( - i a . P ) \approx 1 - i a . P \ \ (2)[/tex]
(Nothing prevent you from choosing U with opposite sign for [itex](a . P)[/itex])
With this choice of [itex]U(g)[/itex], the infinitesimal form of (1) leads to
[tex]\delta \phi (x) = - i a . P \phi(x) = - a . \partial \phi (x).[/tex]
Thus we are led to the differential realization
[tex]i P = \partial . \ \ (3)[/tex]
The question “does this have the wrong sign?” is meaningless because both [itex](P)[/itex] and [itex](-P)[/itex] satisfy the same algebra. However, your metric signature determined which sign of P is appropriate for energy-momentum operator. So, if your metric is [itex](-1, +1, +1, +1)[/itex], you should use (3) as your energy-momentum operator. And, if your metric has the signature [itex](+1, -1, -1, -1)[/itex], then [itex](-P)[/itex] is the energy-momentum operator.
Now, if (for some reason) you want to express the coordinates transformation in terms of the operator P as given in (3), do the following, since [itex]\partial_{c}x^{a} = \delta^{a}_{c}[/itex], then
[tex]g . x^{a} = x^{a} + a^{c}\partial_{c}x^{a} = (1 + i a . P) x^{a},[/tex]
and
[tex]g^{-1}. x = (1 - i a . P) x.[/tex]
sam
Thanks. That makes a lot of sense. So just define P with a + or - so as to give the usual operator from regular quantum mechanics (P^i = -i d/dx^i, for i=1,2,3). The unitary operator that shifts the field for that choice of P is [itex]exp(+i a_\mu P^\mu)[/itex] (using the +,-,-,- metric).
Related to Question on the representation of Poincare algebra generators on fields
1. What is the Poincare algebra?
The Poincare algebra is a mathematical structure that describes the symmetries of space and time, including translations, rotations, and boosts. It is named after the French mathematician Henri Poincare.
2. What are Poincare algebra generators?
Poincare algebra generators are operators that generate the symmetries of the Poincare algebra. These operators act on fields, which are mathematical representations of physical quantities.
3. How are Poincare algebra generators represented on fields?
Poincare algebra generators are represented on fields through commutation relations. These relations describe how the generators act on the fields and how they relate to each other.
4. What is the significance of the representation of Poincare algebra generators on fields?
The representation of Poincare algebra generators on fields is significant because it allows us to study the symmetries of space and time in a mathematical framework. This representation also has important applications in quantum field theory and particle physics.
5. Are there any limitations to the representation of Poincare algebra generators on fields?
There are some limitations to the representation of Poincare algebra generators on fields. For example, in certain cases, the representation may not be unique, and different choices can lead to different physical predictions. Additionally, this representation may not fully capture the symmetries of certain physical systems, leading to the need for more complex mathematical structures.
