Question on the work done while charging up a capacitor.
In summary, the work done when charging up a capacitor is given by the equation dW=VdQ. However, this equation does not take into account the change in voltage (dV) as the charge (dQ) moves from one plate of the capacitor to the other. To account for this change, the correct equation is dW=(V+dV)dQ, which takes into account the change in voltage. This is because the equation V=W/Q only holds when the voltage is constant, but in the case of a charging capacitor, the voltage is not constant and depends on the charge. The incorrect equation, dW=VdQ+QdV, results from applying the product rule of differentiation without considering the changing
bubblewrap
134
So the work done when charging up a capacitor is ##dW=VdQ##
However, when we add a charge ##dQ## to the capacitor, ##V## also changes accordingly, so I was wondering why the work done wasn't written as ##dW=VdQ+QdV## (one that also takes into account t he change in ##V##).
Thanks in advance.
I think the correct equation for dW is ##dW=(V+dV)dQ=VdQ+dVdQ##. This is because the voltage changes to V+dV but remains constant and equal to V+dV as the charge dQ moves from one plate of the capacitor to the other.
But when we do a single (not double) integration on dVdQ the result is 0. That is ##\int dVdQ=0## I can expand for this if you want.
EDIT: Why the equation you wrote is not correct for the case of a charging capacitor:
It all starts from the equation ##V=W/Q##. If this equation was correct in all cases then we could simply handle it as follows ##W=VQ## and differentiating using the product rule of differentiation (and omitting the denominators ##dt##) we ll end up with ##dW=VdQ+QdV##. So at first place it seems that the equation you wrote is correct.
However the mistake lies at our starting point: The equation ##V=W/Q## does not hold for the case of a charging capacitor. This equation is true only if the voltage V is constant and independent of time t or the charge Q (as to why this is true we ll have to go back to electrostatics and studying the motion of a charged point particle which moves between two points of an electrostatic field that have potential difference V). In the case of a charging capacitor V is not constant in time and it depends on the charge Q in the capacitor plates, so this equation does not hold.
It holds though if we apply it for an infinitesimal time interval ##(t,t+dt)## for which we consider the voltage constant and equal to ##V## (or ##V+dV## as I wrote above). Then the infinitesimal work ##dW## for this infinitesimal time interval ##dt## during which the charge dQ moves from one plate of the capacitor to the other, is ##dW=(V+dV)dQ##. And from here we go back at the start of my message...
Related to Question on the work done while charging up a capacitor.
1. What is a capacitor?
A capacitor is an electronic component that stores electrical energy in an electric field. It is made up of two conductive plates separated by an insulating material, known as a dielectric.
2. How does a capacitor charge up?
A capacitor charges up when a voltage is applied across its plates. This causes electrons to flow from the negative plate to the positive plate, creating an electric field between the two plates.
3. What is the work done while charging up a capacitor?
The work done while charging up a capacitor is equal to the product of the voltage applied and the change in charge on the plates. This can be calculated using the formula W = 1/2 * CV2, where C is the capacitance and V is the voltage.
4. Why is the work done while charging up a capacitor important?
The work done while charging up a capacitor is important because it determines the amount of energy that the capacitor can store. This energy can then be released to power electronic devices or perform other functions.
5. How can the work done be increased while charging up a capacitor?
The work done can be increased by increasing the voltage applied to the capacitor or by increasing the capacitance of the capacitor. This can be achieved by using a larger capacitor or by adding capacitors in parallel.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
