Question on universailty classes
  • Thread starter mavipranav
  • Tags
    Classes
In summary, the critical exponents for a specific model, such as the Ising model, can vary depending on the lattice structure it is solved on. However, the dimensionality of the lattice does play a role in determining the critical exponents. The lattice structure may also have an impact, but it is difficult to determine this directly from the model. Ultimately, the long distance limit of the model must be taken into consideration when evaluating the critical exponents.
mavipranav
25
Hi
When a particular model (say Ising) is solved on a particular lattice (say 2D triangular), do the critical exponents of the same model fall within the same universality class (have same critical exponents) as when solved on a different lattice (say 3D cubic)?
Thanks,
Mavi
I found out one part of the answer: changing the dimensionality of the lattice will change the critical exponents for the same model (say Ising). So the modified question would be whether the exponents change while changing the lattice structure (say square to triangle) for the same model in a given dimension?
Mavi
Guessing another part of the answer: it seems that since the continuum limit or the lattice limit must yield the same critical exponents (due to scaling invariance after graining), the lattice structure itself must not matter for the exponents. I wonder if this reasoning is correct.
Mavi
For the ferromagnetic Ising model case, outside of the dimensionality, it would be fair to assume that the lattice does not matter. There is no guarantee on this though. For a dramatic example, it should be fairly clear that the physical properties of an antiferromagnetic Ising model with be strongly dependent on the lattice geometry.
The problem with your argument is that you are assuming that given a model on an arbitrary lattice (with fixed dimensionality) you'll always arrive at the same long distance limit. It is difficult to show such a thing directly from a given model, mostly since the coarse graining procedure must done within some approximation (which may or may not be justified).
Related to Question on universailty classes
What are the most common classes offered at universities?
The most common classes offered at universities vary depending on the institution and the program of study. However, some of the most frequently offered classes include English composition, college algebra, biology, psychology, and economics.
How many classes do students typically take per semester at university?
The number of classes students take per semester at university can vary, but the average is usually around 4-5 classes. This may also depend on the student's workload, major, and personal preferences.
What are general education classes and why are they required at universities?
General education classes are courses that cover a broad range of subjects outside of a student's major. These classes are required to provide students with a well-rounded education and to develop critical thinking and communication skills that are essential in any career.
How do university classes differ from high school classes?
University classes are typically more advanced and specialized than high school classes. They require a higher level of critical thinking, independent learning, and self-motivation. University classes also often have larger class sizes and may have more rigorous assignments and exams.
Can students take classes outside of their major at university?
Yes, students can usually take classes outside of their major at university. This is often encouraged as it allows students to explore different subjects and potentially discover new interests. However, there may be certain requirements or prerequisites for taking classes outside of one's major.
