Question on Work done by horse pulling a wagon.
In summary, the correct answer for the amount of work done by the horse pulling a 200-kg wagon 50 km along a level road with an effective coefficient of friction of 0.060 is 5.9*106. The equation used to calculate this is W = Fnet * d, where the force of friction is equal to µmg. The incorrect term of 200*9.8 was mistakenly included, leading to an incorrect calculation.
Daaniyaal
64
How much work did a horse do that pulled a 200-kg wagon 50 km without acceleration along a level road if the effective coefficient of friction was 0.060?
W=Fnet * d
Force of friction= µmg
W=200*9.8-(200*9.8*0.060)*50,000
=92120000
Correct answer is supposed to be 5.9*106
Your equation doesn't make sense. Where did that first term come from? The correct answer should just be the second term with a plus sign. If you recalculate the expression you gave, you will find that you evaluated it incorrectly.
Chet
Likes 1 person
Hi Daaniyaal! :smile:
work done is force "dot" displacement
what is the dot product of the vertical weight with the horizontal displacement? :wink:
I guess I unnecessarily put in the force needed to move the wagon without friction opposing the movement. Oopsies
:blushing:
I feel embarrassed >.>
Also, thank you :)
I would like to clarify that the correct unit for work is Joules (J) and not Newtons (N). The correct formula for work is W = F*d, where F is the force applied and d is the distance traveled. In this case, the force applied by the horse is the net force, which is the difference between the force of gravity (200*9.8 N) and the force of friction (0.060*200*9.8 N). Therefore, the work done by the horse can be calculated as:
W = (200*9.8 N - 0.060*200*9.8 N) * 50,000 m = 5.9*10^6 J
This is equivalent to the given answer of 5.9*10^6 J or 5.9 million Joules. It is important to use the correct units and formula when solving physics problems to ensure accurate results.
Related to Question on Work done by horse pulling a wagon.
What is work done by a horse pulling a wagon?
The work done by a horse pulling a wagon refers to the amount of force applied by the horse over a distance to move the wagon. This is a measure of the energy expended by the horse to move the wagon.
How is work done by a horse pulling a wagon calculated?
The work done by a horse pulling a wagon is calculated by multiplying the force applied by the distance traveled. In this case, the force is the pulling force of the horse and the distance is the distance covered by the wagon.
What factors affect the work done by a horse pulling a wagon?
The work done by a horse pulling a wagon can be affected by various factors such as the weight of the wagon, the terrain, the health and strength of the horse, and the speed at which the wagon is moving.
What are some real-life applications of work done by a horse pulling a wagon?
The work done by a horse pulling a wagon has been utilized in various industries such as transportation, agriculture, and construction. Before the invention of modern machines, horses were commonly used to pull wagons to transport goods and materials.
How does the work done by a horse pulling a wagon compare to other forms of work?
The work done by a horse pulling a wagon is a form of physical work or mechanical work, which involves the use of force to move an object over a distance. It is similar to other forms of work, such as pushing a cart or lifting weights, in that it requires the expenditure of energy to perform the task.
