Question on work,energy and power
  • Thread starter matsci0000
  • Tags
    Power
In summary, the work required to pull the hanging part of the chain onto the table is mgL/32, taking into account the distribution of mass and the role of center of mass in the problem.
matsci0000
Que- A uniform chain of length L and mass m is held on a smooth table with one-fourth of its length hanging over the edge. If g is the acceleration due to gravity, find the work required to pull the hanging part on the table.
CHECK MY SOLUTION---------AND POINT OUT MY MISTAKE.
Weight of the hanging part of the chain=mg/4
Therefore, work done=(mg/4)(L/4)
=mgL/16...Answer
I am getting this answer. But the correct answer is mgL/32.
Is there any role of center of mass in this question?:confused:
This is because the mg/4 isn't all concentrated at L/4 distance from the table. It requires less work because some of that mass is distributed closer to L/4 distance to the table. Intuitively, you can see that the total work should be half of what you computed since then, the "average" displacement of the chain (taking into account the mass distribution) is only L/8 away from the table. Mathematically, you need to compute this differently.
Hint: Are all parts of the hanging piece raised by the same distance?
Sure. Using the center of mass will allow you to get the answer quicker.
Moderator's Note: Multiple threads merged.
What is the significance of center of mass in this question?
You can use the center of mass as an average for all the work done. Less work is done at the top of the chain than the bottom of the chain. It will all even out if you just look at the center of the chain, that is the center of the hanging part of the chain.
Related to Question on work,energy and power
1. What is work?
Work is defined as the amount of force applied to an object over a certain distance. It is measured in joules (J) and is calculated by multiplying the force applied by the distance traveled in the direction of the force.
2. What is energy?
Energy is the ability to do work. There are many forms of energy, including kinetic, potential, thermal, and electromagnetic. It is measured in joules (J) and can be converted from one form to another.
3. What is power?
Power is the rate at which work is done or energy is transferred. It is measured in watts (W) and is calculated by dividing the amount of work done by the time it takes to do it. It represents how quickly work is being done.
4. How are work, energy, and power related?
Work and energy are directly related, as work is the transfer of energy from one form to another. Power is also related to work and energy, as it represents the rate at which energy is transferred or work is done.
5. Can work be negative?
Yes, work can be negative. This occurs when the force applied to an object is in the opposite direction of the displacement, resulting in the object losing energy instead of gaining it. Negative work is often seen in situations where friction is present.
9K
14K
