A Question on Zeno time derivation
  • A
  • Thread starter Thread starter Mainframes
    Derivation
Mainframes
Hi,
I'm trying to follow the derivation of the Zeno time from two sources and am struggling. I think I'm missing some sort of algebraic trick and any tips would be appreciated. A bit more detail below.
In the attached paper \citep{Facchi_2008}, the Zeno time (equation (6)) is derived from equation (4) and equation (5), but I don't see how.
In the second attached paper \citep{PhysRevA.89.042116}, the Zeno time is derived in equation (1.6) though I cannot even see how how equation (1.3) is derived (let alone the Zeno time).
REFERENCES
@article{Facchi_2008,
doi = {10.1088/1751-8113/41/49/493001},
url = {https://dx.doi.org/10.1088/1751-8113/41/49/493001},
year = {2008},
month = {oct},
publisher = {},
volume = {41},
number = {49},
pages = {493001},
author = {P Facchi and S Pascazio},
title = {Quantum Zeno dynamics: mathematical and physical aspects},
journal = {Journal of Physics A: Mathematical and Theoretical},
@article{PhysRevA.89.042116,
title = {Classical limit of the quantum Zeno effect by environmental decoherence},
author = {Bedingham, D. and Halliwell, J. J.},
journal = {Phys. Rev. A},
volume = {89},
issue = {4},
pages = {042116},
numpages = {17},
year = {2014},
month = {Apr},
publisher = {American Physical Society},
doi = {10.1103/PhysRevA.89.042116},
url = {https://link.aps.org/doi/10.1103/PhysRevA.89.042116}
Hint: ##P## and ##Q## are projectors, i.e. ##P^2=P##, ##Q^2=Q##, ##PQ=QP=0##.
Thank you very much for your reply. I did try using those relationships (and I understand why they are true), however, I still could not get the algebra to work.
Furthermore, in equation (1.3) of the below extract frrom \citep{PhysRevA.89.042116}, I cannot even see how the ##\epsilon^2## term on the RHS of the equation (1.3) is possible. The reason for this is that I believe any ##\epsilon^2## term on the LHS would be of the form ##\frac{\epsilon^2}{\hbar^2}##.
This, together with my inability to get the algebra to match, led me to believe I am missing something else fundamental.
First observe that from ##P=|\psi_0\rangle\langle\psi_0|## we have
$$P|\psi_0\rangle = |\psi_0\rangle , \;\;\; Q|\psi_0\rangle = 0.$$
The goal is to compute
$$\tau_Z^{-2} = \langle\psi_0|H^2| \psi_0\rangle - \langle\psi_0|H| \psi_0\rangle^2.$$
The second term is proportional to
$$\langle\psi_0|H| \psi_0\rangle^2=
\langle\psi_0|H| \psi_0\rangle \langle\psi_0|H| \psi_0\rangle
= \langle\psi_0|HPH| \psi_0\rangle ,$$
while the first term is
$$\langle\psi_0|H^2| \psi_0\rangle = \langle\psi_0| PH(Q+P)HP | \psi_0\rangle$$
$$=\langle\psi_0| PHQHP | \psi_0\rangle + \langle\psi_0| PHPHP | \psi_0\rangle$$
$$=\langle\psi_0| PHQQHP | \psi_0\rangle + \langle\psi_0| HPH | \psi_0\rangle$$
$$=\langle\psi_0| H_{int}^2 | \psi_0\rangle + \langle\psi_0| H | \psi_0\rangle^2 .$$
Combining all this we get
$$\tau_Z^{-2} = \langle\psi_0| H_{int}^2 | \psi_0\rangle$$
which is Eq. (6).
Likes Lord Jestocost and Nugatory
while the first terms is
which is Eq. (6).
This is brilliant. Thank you so much for this (it has certainly Demystified the result to me)
Likes Demystifier
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
