HCB
- 10
- 7
- TL;DR
- Which voltage range (I believe in AC) is necessary and which chemicals are preferred as the electrolyte(s)?
First: this post is regarding the marking of stainless steel with an electrochemical process which involves one or more electrolytes in solution. I felt this area of the site sounded like an appropriate place to post this as it involves both materials and chemistry. My apologies if this isn't the right place.
Hello, All. I've been having fun as a semi-retired guy messing with various electrochemical processes, namely: anodizing aluminum and titanium, and rust removal on mild steel and other alloys which develop red iron oxide. I have a new shop building and I would really like to mark outlets with circuit information, mostly which circuit the outlet is connected to. Having the faceplate marked is my goal. I tried this almost 2 years ago when the first shop was put up (I set it on fire in May, a little over a year after it was built...not a good thing). What I tried then was masking the faceplate with painters' tape and having it turned into a stencil by a guy with a laser cabinet. The laser was far too weak to etch the galvanized coating but I wasn't worried, I thought I'd eat the galvanizing off with muriatic acid with the tape as the stencil. Wrong. Maybe it had a coating on it which the laser didn't remove. Regardless, it didn't work well for some reason and, maybe due to the acid, the painters' tape was a beast to remove. I abandoned the marking then. I could have him use some special spray-on product and then laser the design (almost like spray-on laser printer toner...sort of) for this go-around but I'd really like to do as much of the process as I can myself.
I have found commercial units which claim to mark, not etch, stainless steel through an electrochemical process. Cougartron, Etchdrop, Tigbrush are a few of the manufacturers. Not only am I not doing this for profit, I don't want to purchase a tool to do one job. Plus, I'm a DIY type and I feel this should be completely doable. I've not found much DIY information on this subject, however. There are plenty of videos and sources for information on *etching* various steels (very common in knife-making circles), but not a) *marking* and b) on stainless (well, not that I've found). All the machines I've seen online as well as the DIY etching use an absorbent material connected to one wire from a power supply, an electrolytic solution absorbed into said medium, and the other wire from the power supply connected to the workpiece; this is, that I've seen, not a bath process. The "wand" is dragged across the work piece while current is conducted across the electrolytic solution in the medium. In the videos I've watched about such commercial units, the marking takes a matter of seconds (less than 30), and appears to be a pretty dark black color. They claim it's very durable. Yes...marketing, but I'm hoping there's some truth there. The marketing materials I've read indicate that this process should be good for 300 and 400 series stainless steel.
Reading MSDS/SDS for the electrolyte solutions offered from some of the companies doesn't reveal much about their composition. The best I found was one with: NaCl, cobalt chloride, citric acid, and I believe it was calcium chloride. There are many electrolytes which can be used in the various "electrolysis" processes and, usually, seem more suited to one process than another (sulfuric acid for anodizing Al, trisodium phosphate for anodizing titanium, etc).
The general rule seems to be that, for marking instead of etching, AC is used. As I can get stainless steel outlet faceplates, I got a couple of pieces of stainless steel and did some tests today with various electrolytes and a 12vac wall wart. I tried a few combinations of citric acid, calcium chloride, NaCl, potassium chloride. Nothing worked very well. The best I got almost looked black when still wet but looked more like light brownish charcoal when it dried. I futzed around with different combinations but NaCl and citric acid gave me the best results of my poor attempts. After it was dry, it was not very durable and was easy to rub off partially with just a dry paper towel.
All that to get here: I would like to know about how stainless steel is marked with an electrochemical process, which voltage or range of voltages is appropriate, AC or DC (although I *think* it's going to be AC, if I knew so much, I wouldn't be here asking questions), which electrolytes are better suited to the process, what is the "black" color (which material like iron or magnetite, etc), and if there are stainless steel alloys which would be less well-suited for this process. If you can help with any of this information, I would appreciate it.
Thank you very much for your time.
(The copy of War and Peace above is due to many years of reading forums where people ask complex questions in one paragraph, if that, with no context.)
--HC
--HC
