Question regarding accellerating expansion of the universe.
In summary, scientists use relativistic corrections when measuring the expansion of the universe. However, this relativistic correction has only been applied to the apparent magnitude data. There is a challenge to the BB cosmology due to the recent discoveries that quasars may be part of the answer. Additionally, the CMB is the local signature of the ZPE EM fields and might not be the echo of the Big Bang.
hedons
40
How do scientists compensate for relativistic effects when measuring the expansion of the universe using type 1a supernove?
Thanks
Glenn
Astronomy news on Phys.org
Thanks
Glenn
Interesting question. I'm not an expert and would love to see a reply from someone more knowledgeable in this area, but from my reading of the literature the only relativistic correction applied to the data seems to be a time-dilation correction in the apparent magnitude data (see for example http://arxiv.org/abs/astro-ph/9805200).
Anybody else got any idea?
MF :smile:
I'm not an expert either but why is redshift supposed to determine recession velocity? Is redshift a reliable indicator of distance? Is the CMB radiation basically uniform in all directions?
These two discoveries might poses a challenge to the BB cosmology:
1) Can A 'Distant' Quasar Lie Within A Nearby Galaxy?
http://ucsdnews.ucsd.edu/newsrel/science/mcquasar.asp
2) Is the low-l microwave background cosmic?
http://www.arxiv.org/abs/astro-ph/0403353
I checked out all three links, but I couldn't access the first one X-43D provided. How fast does a supernova expand...ball park idea.
i couldn't find anything about your supernova, but here some background on the expansion of the universe (hubble constant). run with it. also go to your library and find the book "the whole shebang" by Timothy something, i read it not too long ago and it talked about some of that stuff.
Fibonacci
http://apod.gsfc.nasa.gov/apod/ap960513.html
my pet idea is Quasars are more then one black hole
and are a group of 2 or more black holes coming together
to form a supermassive black hole
so they could have very high speeds and red shifts
as they wiz around each other
and red shift canbe based on speed not distance
once they combine into a super massive single hole
the show is over no more quasar
only a resting massive black hole
Fibonacci
A last name would be very helpful if that's ok. :wink:
I'll see if I can find the book. Thanks. Couldn't access the link, stupid computer. :devil:
The quasars might be part of the answer. Something to think about. :rolleyes:
1) Here is the paper about the quasar in NGC 7319.
http://citebase.eprints.org/cgi-bin/citations?id=oai:arXiv.org:astro-ph/0409215
Don't expect standard cosmologists to spend much time considering its implications, at least in public. They have rejected every known example of interacting objects with discordant redshifts, and have labeled Arp, the Burbidges, et al as "cranks" for their efforts.
2) I believe that the CMB is the local signature of the ZPE EM fields, and that the strong dipole anisotropy is an artifact of our galaxy's proper motion through that field. Smaller anisotropies will be the result of smaller proper motions (galactic rotation, Sun's path through the galactic arm, Earth's path around the Sun, etc) Perhaps someday :mad:, the 2nd year WMAP data will be released. If in fact my ZPE model is correct, I predict that the data will show that the small-angle anisotropies do not agree with those of the 1st year data, and therefore the CMB is not the echo of the Big Bang, but is the local ground-state of the quantum vacuum. The longer the release is delayed, the more I suspect that the delay is due to a "problem" of this magnitude.
So if the big bang would not be the way the universe had begun, then what theory would best describe how our universe came to be?
How about a Universe that is infinite in extent, both spacially and temporally? It's a mind-blower for many folks (OK, I grew up in the '60s :smile:), because humans seem to naturally want to define our place relative to some beginning and some ending. It is just as likely (given our sample set of ONE universe) that the Universe is infinite in any respect, as it is that the Universe is finite in that respect.
If you mean the time dilation from cosmological redshift, then you just have to scale your light curves by 1+z, just as you do the spectrum. If you mean relativistic effects due to the compact objects, then it's not really necessary to consider it. The measurement of cosmological expansion can be done without understanding the physics of the supernova, you just have to verify observationally that they follow some sort of "standard candle" relationship.
Heard of Olber's paradox?
I disagree with your comment here - in fact there are very many humans who seem to naturally NOT want to define our place relative to some beginning or some ending - including some of the greatest names in historical science - both Newton and Einstein intuitively believed in a static, infinite universe (though Einstein, on deeper reflection, recanted). I would suggest that it is in fact naive intuition that leads to thinking of a universe infinite in both space and time.
Not sure I understand this, can you explain a little more?
If there is an additional relativistic effect on the redhsift (for example gravitational redshift, but I am not restricting myself to that alone) then this will surely be the same for all SN1a (if they are "standard candles" then any gravitational redshift for example will result in a similar magnitude gravitational redshift correction regardless of distance?) and therefore require a "constant correction" to all the SN1a redshift data rather than correction by a z-shift "factor"?
Yes, I have heard of Olber's paradox, and no, I do not think that it is naive intuition to believe that the Universe might be infinite in both space and time. These concepts do not follow from naive intuition, but arise from informed study. Newton believed that the Universe must be infinite, to prevent any gravitational instability that would have caused collapse, and Einstein introduced the CC in order to ensure that such a collapse would not happen. I might be a dummy, but these are a couple of pretty smart guys.
Hey, we all have naive intuitions, it's what we learn as we grow up. Please don't take it as an insult, I have many naive intuitions too, and I know its hard sometimes to fight against them. I never said that either Newton or Einstein were not smart, but like all of us they were not perfect and they also had naive intuitions. Newton never really thought through the implications of his infinite universe properly, I suspect he had a deep religious conviction that the universe was infinite and therefore selectively favoured such a model (I admit this is my personal opinion of his motivations).
The first implication of an infinite (in time and space) universe that Newton failed to address properly is the paradox of gravity. In an infinite universe filled with stars, the gravitational force becomes undefined because there is an infinite force in each direction. The net force on the Earth, for instance, is then not dominated by the Sun but by any asymmetry in the distribution of distant stars. In his correspondence with Newton, Richard Bentley had put his finger on the problem, although Newton had fobbed him off by claiming that the infinite forces from the distant stars exactly cancelled; essentially this was an appeal to his theorem that a uniform shell of matter had no gravitational force on objects within it. In fact this theorem cannot be extended to an infinite shell, and in any case it was obvious that the stars are not uniform in space. Newton's manuscripts show that he was worried enough by Bentley's question to set to work to compare the numbers of stars of different magnitudes with a model of stars uniformly distributed in space (this came to nothing because there was no quantitative definition of magnitudes). Finding no obvious solution, Newton chose not to publicise the problem and it was only re-discovered by Hugo Seeliger in 1895.
Secondly, in his correspondence with Bentley, Newton had claimed (correctly) that if matter was distributed evenly throughout infinite space, it would be highly unstable:
"And much harder it is to suppose that all ye particles in an infinite space should be so accurately poised one among another as to stand still in a perfect equilibrium. For I reckon this as hard as to make not one needle only but an infinite number of them (so many as there are particles in an infinite space) stand accurately poised upon their points."
Newton concluded from this that the particles would collapse into "an infinite number of great masses scattered at great distances from one to another... And thus might ye Sun and Fixt stars be formed...". Bentley took the argument a step further and argued that the stars themselves would collapse into each other without God's active intervention.
(Leibniz criticised Newton's cosmology for this very reason : "According to their Doctrine, God Almighty wants to wind up his Watch from Time to Time: Otherwise it would cease to move. He had not, it seems, sufficient Foresight to make it a perpetual Motion. Nay, the Machine of God's making is so imperfect, according to these Gentlemen, that he is obliged to clean it now and then...and even to mend it...")
And then there's Olber's famous paradox. You say you have heard of it - can you explain how you escape Olber's paradox in a universe infinite in space and time?
Cheers
MF :smile:
MF this is a great post. I nominate it for post of the month or something.
I really like the quotes from Newton correspondence with bentley, and most especially the Leibniz quote is priceless.
More power to you!
That's right. That was the second category I was talking about. Those things are irrelevant for the standard candle analysis.
That's just cosmological time dilation. Not only is the light redshifted, but the time interval is also dilated. It doesn't come up a lot because we don't usually measure time intervals in cosmology, but it's an issue for quasar variability and GRB studies. Here's an example paper on the subject.
Thanks for the reference, but I think we are talking at cross-purposes.
There should be at least 2 different gravitational relativistic effects?
One is gravitational time-dilation (addressed in the paper you reference).
The other is gravitational redshift (not addressed)
The gravitational redshift will be in addition to, but mixed up with, any cosmological expansion redshift.
But the gravitational redshift should be distance-independent, whereas the cosmological expansion redhsift will be distance dependent.
Therefore to get the correct distance-dependency out of the measured redshift, we would have to correct the measured z for the gravitational redshift, to get the correct cosmological expansion z.
This should be a fixed redshift correction, not a (1+z) multiplying factor?
MF :smile:
Not sure I follow. Here's the basic process that I'm picturing:
- Measure the redshift based on the spectrum (no time dilation correction).
- Measure the flux (no time dilation correction).
That used to be all that they did to get the distance and no time dilation correction was necessary, but they found out that it wasn't exactly a standard candle. They could more precisely measure the distance by fitting a relationship between luminosity and the timescale of the supernova burst. Thus,
- Measure the light curve (redshift-dependent time dilation correction required).
That is, the times they measured required a 1+z correction factor. They could use this to find the luminosity and the flux to find the distance. Then they just plot on a Hubble diagram and they're done.
Sorry, point taken. I was confusing gravitationally-induced time-dilation & redshift with velocity-induced time-dilation. Of course the gravitational effects on photon frequency will be negligible with the particular supernovae being studied (but might be significant for quasars?). Anyway, sorry for muddying the waters here.
By the way, there is an excellent review paper at http://www.publish.csiro.au/?act=view_file&file_id=AS03040.pdf
for anyone interested in a non-specialist account of cosmological expansion and all the associated measurement issues.
MF :smile:
Cheers
MF :smile:
Hi, MF! I am very pleased to encounter someone who will bother to study the motivations of the masters. Thank you for the elucidation.
Yes, you can escape Olber's paradox in an infinite Universe. In my model, light interacts with the EM fields of the quantum vacuum as it traverses space and is redshifted proportional to the density and extent of the EM fields that it traverses. Light emitted sufficiently far away from us is redshifted out of detectability, limiting the extent of the universe that we can see. Like any other wave, light cannot traverse the EM fields of the vacuum without "paying the fare".
Cosmological calculations use general relativity, which allows a lot more freedom in the choice of coordinate system than special relativity. Hence such things as length contraction and time dilation are not considered in the same way. Most cosmologists take a time coordinate as the proper time of objects moving with the expansion, which is incompatible with special relativity. I have argued that sometimes it might be better to think in terms of more 'special relativistic' coordinates, e.g. www.chronon.org/articles/milne_cosmology.html . However, many people don't like this.
The Whole Shebang is by Timothy Ferris. He is enthusiastic about the subject, but don't believe everything he writes - there are some very doubtful things in the book.
Interesting. What do you mean exactly by "redshifted out of detectability"?
Does this mean the photons are ultimately absorbed, or just that the redshift becomes very high (but the photons still continue on)?
Also, what happens to the fare that is paid? Does this end up in the cosmological taxman's purse never to be seen again, or is it recycled?
In other words, what happens to the energy lost by the photons as they interact with the EM fields of the quantum vacuum? Is this energy destroyed, or does it somehow end up in the quantum vacuum? (I think you can see where I am going with this...)
I see where you are going with this, and I have been there myself. (And have spent sleepless nights there, since I do something else for a living.) The light from distant sources is progressively redshifted to lower energies and longer wavelengths, to the point where they are indistinguishable from the ground state of the universe.
Let's use the analogy of AC electrical current. Through some mechanism, the AC fluctuations are attenuated progressively until the ripples are smoothed out, and at the end we have a DC signal, or a signal flat enough that it is impossible to distinguish from DC. In a normal audio circuit, we can use a rectifier to accomplish this in one shot - a brute-force process, and the approximation is useful. The difference here is that we are smoothing the signal in an almost infinite number of interactions, and the original signal is getting flatter and flatter until it is insensible to us as AC.
If I put you and all your electrical test gear in a Faraday cage, and I charged that Faraday cage to 100,000 VDC, you would be able to perform experiments on local electrical circuits, magnetic fields, etc, and if you were smart enough, you would recover the entire the physical knowledge about the EM AC fields, BUT you would not know that your own ground potential was 100,000 V above my ground because I did not allow you access to my ground. We have an equivalent situation with the potential of the vacuum energy.
As for the energy lost by EM traversing the EM field of the quantum vacuum: The energy is not destroyed. Everybody pays to ride. The theoretical energy of the ZPE field is 120 OOM greater than we can measure (via the CC). The energy-state of the CMB is very low (2.73 degrees K), but it is everywhere and it is all-pervasive. Why does it surround us and where does it come from? These are the really important questions.
Please humour me for a moment.
As I am sure you are aware, Olber's paradox basically says that in a universe that is infinite in both space and time, with an infinite number of stars, then no matter which direction we look, our line of sight must end on a star. Even though these stars may be extremely far away, the consequence of this is that the night sky should be ablaze with light. And it is not.
When early cosmologists first came across Olber's paradox, one of the popular "solutions" proposed, to explain why the night sky was not ablaze with light, was because the universe contains dust, and that dust attenuates and even absorbs many of the photons on their travel from distant stars, so in fact the night sky looks dark because we are shielded from most of these photons by the absorbing dust. Intuitively, it seemed like a good suggestion.
But intuition forgot about the law of conservation of energy.
Problem is, in an infinite universe over an infinite length of time, each of these absorbing dust particles would eventually reach the same temperature as the stars themselves... and we once again should see the night sky ablaze with light. This put paid to the "dusty infinite universe" solution to Olber's paradox.
Why did I bother explaining all that?
Because it seems to me that you are now proposing a very similar solution, except instead of dust doing the attenuating or absorbing, it is the EM fields of empty space that is doing it?
The problem remains the same. If energy is conserved, then over an infinite time in an infinite space, the energy that is lost to these EM fields of empty space will mean the energy density of empty space will reach the same level as that of the stars...Now if this energy is somehow "locked up" in the EM fields of empty space then the energy density of empty space must itself become infinite (each volume of space absorbing a finite energy per unit time over an infinite time); alternatively the only way to avoid the energy density of empty space becoming infinite is if we allow it to constantly lose energy in some way (re-radiate?)... but then we are back to Olber's paradox...
MF :smile:
MF :smile:
Consider that if light is redshifted by interaction with the vacuum fields, it shifts downward in energy and is stretched in wavelength with every interaction. Light is sensible to us only as an EM wave. When the wavelength is sufficiently long that we can no longer sense the wave, it can no longer be differentiated from the ground state of the vacuum field, and it is incapable of performing work on that field. Let us assume that this redshifting mechanism places a limit of about 14Gly on the distance that any EM wave can travel in "empty" space before it is lengthened to undetectability. Assuming an infinite and (cosmologically) homogeneous and isotropic universe, no part of the the vacuum field can receive energy contributions from objects outside the 14Gly radius surrounding it.
Regarding the total energy of the field, quantum theory says that the total energy of the vacuum is 120 OOM too large to be attributable to the CC. 120 OOM is a VERY big deficit, but like my analogy above with the Faraday cage, if that huge energy level is the ground state of our universe, we will never be able to sense it without access to some higher or lower-energy reference frame. Is the energy lost to redshifting constantly being reradiated? How about if it is being reradiated by the vacuum at frequencies corresponding to about 2.7 degrees K? Just a thought...
By the way, there are comments made at times regarding the "discredited" aether concept, which I take to heart because I am so firmly wedded to the concept that the EM field of the vacuum IS the aether and that it is required for EM propagation. Here is what Einstein had to say about that.
http://www.tu-harburg.de/rzt/rzt/it/Ether.html
Note the summation (emphasis mine):
Einstein said:
Recapitulating, we may say that according to the general theory of relativity space is endowed with physical qualities; in this sense, therefore, there exists an ether. According to the general theory of relativity space without ether is unthinkable; for in such space there not only wonld be no propagation of light, but also no possibility of existence for standards of space and time (measuring-rods and clocks), nor therefore any space-time intervals in the physical sense. But this ether may not be thought of as endowed with the quality characteristic of ponderable media, as consisting of parts which may be tracked through time. The idea of motion may not be applied to it.
"Ponderable media" indeed! It barely can be sensed at all.
But, moving fingers point has not been addressed. Olbers paradox cannot be avoided in a universe that is spatially and temporally infinite. The energy of captured photons must either be reemitted or converted to mass. New laws of physics are otherwise required to replace the law of energy conservancy.
While I squirm at the term 'ether', such arguments inevitably become semantical. Whatever qualities may be inherent to empty space, they bear no resemblance to the 'luminiferous aether' that Einstein sent to its final resting place. This is the most notable comment by Einstein in the quotation you cited:
In other words, it does not possesses any of the qualities typical of a physical media - like a gas, fluid or solid. It also does not constitute any kind of 'rest frame' to which other properties of the universe may be compared. If you follow Einsteins remarks in their entirety, you come to the realization that Einstein's new 'ether' is the gravitational field, without which spacetime ceases to exist.
Just for clarification: if one considers that space expands, the integral of the total flux does not diverge in a spatially and temporally infinite universe. On the other hand, if the light sources follow a fractal distribution with fractal dimension < 2 (which is actually not the case on all scales), then the integral of the total flux is always convergent.
If the energy captured from the photons is re-emitted at very long wavelengths, it will be insensible to us as heat. It will be impossible for us to separate it from the ground state of the vacuum. Olber's paradox is problematic when you expect tit-for-tat re-radiation wavelengths, but it breaks down completely at long wavelengths corresponding to low temperatures.
Read more closely. He posited the existence of TWO ethers. A dynamical gravitational ether, and an EM ether which he held to be absolutely necessary for the propagation of EM waves, but stripped of all other qualities which had been ascribed to it. My view is that the gravitational and EM ethers are one and the same, and that "ether" (the ZPE field) is polarized by the presence of mass. This is the mechanism by which gravitational lensing (refraction of EM waves) occurs.
By the way, I'm almost out of pickled squirrel heads. Can you send me some more?
http://www.customcreaturetaxidermy.com/specimens/images/6hh-.jpg
Yummm! :-p
If I understand you correctly, you are suggesting that photons do lose energy (to the "vacuum field") by some yet-to-be-specified process as they travel through space, but there is some kind of threshold energy per photon, below which the photons no longer interact with either the "vacuum field" or our detectors. Once each photon has been redshifted to this very long wavelength it then continues traveling through space "ad infinitum" without losing any more energy. Is that it?
Problem with this is, when combined with your assumption of an infinitely old universe of infinite size (back to Olber's paradox again), this implies that everything in the universe is bathed in an infinitely dense flux of these low-energy photons (think about it - from every point in the universe you have line-of-sight in every direction to a source of these low energy photons).
The only way to avoid ending up with this infinite flux density is to postulate that the universe is either finite in age or finite in extent.
MF
:smile:
Thanks
Glenn
There is a new idea that has been banded around for the last couple of years, it has its fruits here:http://arxiv.org/abs/astro-ph/0504252
and this companion paper:http://arxiv.org/abs/astro-ph/0504253
You may find this extremely interesting.
  • #31
There is no "threshold", it's just that longer and longer wavelengths travel through the vacuum fields with less and less interference.
Let's use the analogy of an electrical signal. We have a detector (AC voltmeter) that allows us to sense signals above and below ground in a copper conductor. If there is an AC signal on the conductor, our meter can detect it. If, however, the AC is of sufficiently long wavelength, it becomes indistinguishable from DC, and at some point (depending on the averaging time that our meter uses to measure AC) it cannot be detected by our meter. Let's say that the total peak-to-peak voltage of this signal is 120 volts, spanning the range from -60V relative to ground to +60V relative to ground. You could superimpose a million of these "slow" AC signals on that conductor, in their natural distributions (because they do not arrive phase-synchronized) and those signals would be entirely invisible to our meter. They would be impossible to recognize, since they would average out to the ground state at which our meter is referenced.
We can only sense EM waves relative to the ground state of the media through which they propagate. If light interacts with the EM fields of the quantum vacuum and loses energy in the process, it will be redshifted into undetectability (relative to the ground state), and Olber's Paradox is gone, leaving open the possibility of a temporally and spacially infinite U.
  • #32
We need to get this straight. Are you saying that each photon continues to lose energy to this "vacuum field", regardless of photon wavelength? It must be the case either that the photons are ultimately absorbed after a finite time or they continue indefinitely, each losing energy but never quite ending up with zero energy.
Either way, you have a problem, because energy is not destroyed. If they are ultimately absorbed then we are back to the "dusty universe" version of Olber's paradox - the absorbing medium (in an infinite universe of infinite extent) must become as hot as the stars themselves. If they continue indefinitely then we have the problem I highlighted in my previous post - every point in the universe must be bathed in an infinite flux-density of high-wavelength photons.
Which paradox would you prefer?
All this shows is that an AC detector is insensitive to DC. What relevance does this have to the problem that your cosmology implies we should all be bathed in an infinite flux-density of photons?
Do you agree that your cosmology implies that we should all be sitting in a bath of infinite flux-density long-wavelength photons?
MF
:smile:
  • #33
Lets move away from the photon model and consider EM as waves propagating through Einstein's ether (link to the 1920 talk is posted above). EM waves lose energy to the field and decrease in frequency as a result. Ultimately, they become insensible to us as EM waves because their frequency is so low.
There is no problem with Olber's Paradox, because in an infinite Universe the vacuum field in any location can only interact with EM within its visible universe, in other words with light that comes from near enough not to have been shifted into insensibility by interaction with billions of light years of the vacuum field.
MF
:smile:
No, this cosmology implies that EM waves from far enough away are redshifted into indetectability, and that the average effect of these very long waves is indistinguishable from the ground state of the vacuum field. EM is only sensible to us when it oscillates with respect to the EM field. If you think of this as waves in a field instead of a individual photons shooting around, it makes perfect sense.
  • #34
OK, I finally see. Your argument rests on the basis that your redshifted photons have 100% wavelike properties, and (because they “are insensible to us”) they never take on particle-like properties. This means they are not only insensible to us, but must also be insensible to everything else in the universe.
Interesting idea.
MF
:smile:
  • #35
Interesting idea.
MF
:smile:
That's pretty much the case, although I would sharpen the explanation just a bit and say that all EM exhibits wave properties, EM signals NEED an aether (vacuum EM field) through which it can propagate, and the interaction of the EM waves with the propagating fields results in a very gradual reduction of the energy of the wave.
I know I posted the link to Einstein's 1920 Leyden address above, but here it is again.
By 1920, Einstein had convinced himself that an EM ether (the spelling in the translated talk) was absolutely essential to the transmission of light through "empty" space. He was also convinced that a gravitational ether was absolutely required. The difference is that his gravitational ether was dynamical, as required, but he could not make GR accommodate a dynamical EM ether, so he stripped it of ALL properties except the ability to transmit EM. I think he made a critical mistake here, and that the gravitational and EM ethers are the same - the EM field of the vacuum.
In my ZPE gravitation model, the EM fields of the vacuum are the ground state of our universe, and they can be polarized/densified by the presence of mass. Since they are the EM aether, EM propagating through these fields can be slowed, refracted, etc, just like light is slowed, refracted, etc by propagating through transparent media in classical optics. My entire motivation when I started studying this a year ago was to model gravitational lensing in terms of classical optics. I found intersections between the classical aethers and ZPE fields, and then started modeling densification and polarization in terms of a differential in the gravitational infall rates of matter and antimatter. If the Athena project ever manages to produce experimentally useful quantities of anti-hydrogen, we will know very quickly if this model has legs. If the model is supported, there may be no need for gravitons, Higgs bosons, dark matter, dark energy, etc. The observed properties of the universe may perfectly consistent with an infinite steady-state universe, with which Einstein would have been quite comfortable.
