Uchida
- 23
- 6
Hi,
Considering the question bellow from a government work selection process:Check the FALSE alternative on the use of thermodynamic properties.
dh = cp.dT
du = cv.dT
dh and du expressed as above are true whether or not the process is isobaric / isochoric.
Also, continuing with 1º Law of Thermodynamics:
𝛿q = du + 𝛿w = cp.dT = cv.dT + p.dv = dh
For a process with frontier work, p.dv is not necessarily isobaric. Nervertheless, dh = 𝛿q would still be valid, correct?
Therefore, in my view, both the statements of alternatives '1' and '2' are false.
However, in the answer to the question, only '2' is considered to be false.Where's my mistake?
Thank you.
- In a cylinder-piston type system, the variation of the enthalpy property (Δh) is usually applied to determine the heat (per kilogram) exchanged with the neighborhood (q = Δh), but only for processes under constant pressure.
- The product of specific heat at constant volume (Cv), by varying the temperature of a system (ΔT), is used to determine the variation of specific internal energy (Δu = Cv ΔT), but only when the volume is kept constant (isovolumetric process ) and when there is no phase change.
- For the ideal gas model, it is usual for the specific heat property at constant pressure Cp to be considered independent of the fluid pressure.
- For the ideal gas model model, the specific heat property at constant volume Cv is considered to be independent of the fluid pressure.
dh = cp.dT
du = cv.dT
Thank you.
