tusharkhaire
- 2
On what factors does the pressure in condenser of a rankine cycle depend?
The lesser the pressure in the condenser, the more expansion work will be done by the steam turbine. And depending on the pressure in the condenser, the temperature of the steam entering the condenser will depend. because lesser the pressure in the condenser, more will be the expansion work by turbine and hence lesser will be the temperature of the steam entering the condenser. And the pressure in the condenser must depend upon the temperature and amount of cooling water flowing through it. This is what i used to think.
But then i read in the textbook that the minimum temperature in the condenser is equal to the saturation pressure of the steam corresponding to the saturation temperature of the steam entering the condenser. So this got confusing. How the temperature of the steam leaving the turbine will decide the minimum possible pressure in the condenser?
Does'nt the temperature of the steam leaving the turbine itself is dependent on the pressure in the condenser? because that is why we would get greater work of turbine with lesser pressure in the condenser. please help me clear this concept.
THANK YOU !
THANK YOU !
