Question regarding sun/moon angle
  • Thread starter vanburen_boy
  • Tags
    Angle
In summary, the arc angle when looking at the sun and moon is approximately the same, leading to the possibility of lunar and solar eclipses. This is due to the gradual increase in the moon's orbit, with its average distance from Earth increasing by roughly 3 centimetres per year. However, there is no known advantage to this arrangement and it is simply a coincidence. The idea that this arrangement was preordained for survival purposes is not scientifically supported.
vanburen_boy
I just want to start off by saying that my knowledge of Astronomy (and physics, for that matter) is pretty limited, so please don't laugh too hard if I make an ass of myself.
I'm taking the first Astronomy course at my University, and today my professor briefly mentioned that the arc angle when looking at the sun is .5 inches and it is the exact same for the moon (I may be off on the measurement, but that's not the point I'm driving at). Because this is so, a lunar (and/or?) solar eclipse is possible.
As someone who probably thinks too often in Darwinian terms, I asked my professor what the natural advantage of this is. He said it was a good question, but he did not know the answer.
Does this help anything (sun, moon, the 'orbit' itself, earth, etc.) in any way? Long ago, was there perhaps some sieving process which left us with a moon that could block out the sun so as to help itself and/or the moon (or something else)?
So basically, why is it that the moon and sun have the same arc angles? Is it just random chance? Is it because it helped it to survive over billions of years? I know that I might be applying this thinking to too broad of a question, but I just can't convince myself it happened by accident. Or maybe it did...
If there is no answer for this question I would appreciate an educated assumption. Yours would certainly be better than mine.
Thanks for your time.
Astronomy news on Phys.org
As far as I know it's just a matter of dumb luck: the orbit of the moon is getting wider over time - very very gradually, due to the transfer of angular momentum from the rotation of the Earth th the orbital velocity of the moon. It leads to the average earth-moon distance (measured over the course of one moon orbit) increasing by roughly 3 centimetres per year. Hence, in a couple of tens of millions of years all solar eclipses will either be partial eclipses or annular eclipses. :)
To give a more specific answer: I don't think there is any 'advantage' (to anyone or anything) to the moon having approximately the same angular size as the sun, seen from Earth - at least, I can't think of one at all. It hasn't always been the case (the moon used to be more close by) and it won't remain the case either. We're lucky to be living in this period so we can enjoy the best total solar eclipses!
Just FYI: The " symbol does not mean inches in this context. 0.5" would mean 0.5 arcseconds or seconds of arc. As you have correctly stated, arcseconds and arcminutes are units of angular measure. There are 60 arcminutes (symbol ') in one degree, and 60 arcseconds in one arcminute.
Furthermore, the angular diameter of the sun is more like 30' (thirty arcminutes), so I'm not sure where you got 0.5" from.
EDIT: Oh sorry. You said in your original post that the number may have been off but that wasn't the point you were driving at. Sorry I missed that.
Well, lunar and solar eclipses would still occur. The sun just wouldn't be perfectly obscured (if the lunar disc were smaller). In this case, we might not call it an eclipse, but a transit (e.g. when Venus passes in front of the sun, we call it a transit). Furthermore, if the lunar disc were *larger*, then clearly solar eclipses would still occur (perhaps total eclipses would be even more frequent).
Ummmm...if you are thinking in *Darwinian* terms, then you should be thinking about how human characteristics have evolved to take advantage of our natural surroundings, NOT how our natural surroundings may have been prearranged to be advantageous to us.
That would imply that the arrangement of bodies in the solar system did not occur as a result of the physical laws governing the system (gravity) but was preordained by some intelligence. This is not scientific.
In a manner of speaking, yes. The reason why the Sun, Earth and Moon are in the relative positions that they occupy today is because of physics. The reason why the sun and moon appear the same size from Earth is because they are occupying those positions and happen to have the sizes that they do. The fact that the relative distances of the sun and moon from the Earth result in them appearing the same size is therefore indeed coincidence.
Helped WHAT to survive?
This is the wrong way round! There are theories that our moon is necessary for long term life on Earth by stabilising the tilt, producing tides and protecting Earth from impacts.
That theory has taken a bit of a dive since the discovery of extremo-philes which suggest that life will pretty much always find a way!
mgb_phys said:
... by stabilising the tilt, producing tides and protecting Earth from impacts.
but the higher life-forms, mgb, the higher
we aren't extremo-philes, we're pretty soft actually
we like our stabilized tilt, steady temperature regimes etc.
We manage to live in L.A. and Toronto (well perhaps not higher life forms!) so we are prretty adaptable.
Related to Question regarding sun/moon angle
1. What causes the difference in the angle of the sun and moon in the sky?
The angle of the sun and moon in the sky is determined by the tilt of Earth's axis. This tilt causes the sun's rays to hit the Earth's surface at different angles throughout the year, resulting in changing angles of the sun and moon in the sky.
2. Why does the angle of the sun and moon appear to change throughout the day?
The angle of the sun and moon appears to change throughout the day because of the rotation of the Earth. As the Earth rotates, the sun and moon appear to move across the sky, resulting in changing angles of their positions.
3. How does the angle of the sun and moon affect the seasons?
The angle of the sun and moon has a significant impact on the seasons. When the sun's rays hit the Earth at a more direct angle, it creates warmer temperatures and longer days, resulting in summer. When the sun's rays hit the Earth at a more indirect angle, it creates cooler temperatures and shorter days, resulting in winter.
4. Can the angle of the sun and moon affect the tides?
Yes, the angle of the sun and moon can affect the tides. The gravitational pull of the moon and sun on Earth's oceans causes the tides. The angle of the sun and moon can influence the strength and height of the tides depending on their positions in relation to the Earth.
5. How does the angle of the sun and moon change during a solar or lunar eclipse?
During a solar eclipse, the moon passes between the sun and Earth, blocking the sun's rays from reaching the Earth at a certain angle. This results in a shadow being cast on the Earth, causing a decrease in sunlight and a change in the angle of the sun in the sky. In a lunar eclipse, the Earth passes between the sun and moon, casting a shadow on the moon and changing its angle in the sky.
